EspRFTestTool_v3.6_Manual with ESP32-H2-MINI-1
Posted: Tue Dec 03, 2024 3:55 pm
We are in the process of certifying (CE-certification) a device which includes an ESP32-H2-MINI.
Everything works fine, e.g. upload own programs or erasing flash with esptool:
But when using EspRFTestTool_v3.6_Manual the upload of the test-firmware seems to work, but at the end testing is not possible:
In the logging of EspRFTestTool_v3.6_Manual you can notice various strange messages:
- MAC is 00:00:00:00:00:00
- It expects a ESP32-H2-beta2
- It expects chip id 14 but the ESP32-H2 seems to notify 16.
Is the test-firmware for the ESP32-H2 in the package of EspRFTestTool_v3.6_Manual not up-to-date and does work with the latest ESPP32-H2-production-version (we assume which is the "ESP32-H2 (revision v0.1)" we have)?
How is the correct usage of EspRFTestTool_v3.6_Manual with ESP32-H2-MINI-1 ("ESP32-H2 (revision v0.1)")?
Best regards,
Martin
iot4you SL
esptool.py v4.8.1
Serial port COM14
Connecting...
Detecting chip type... ESP32-H2
Chip is ESP32-H2 (revision v0.1)
Features: BLE, IEEE802.15.4
Crystal is 32MHz
MAC: 74:4d:bd:ff:fe:63:36:d6
BASE MAC: 74:4d:bd:63:36:d6
MAC_EXT: ff:fe
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 1.3s
Hard resetting via RTS pin...
Best regards,
Martin
iot4you SL
