Time needed to A2DP connection
AndreaS73
Postby AndreaS73 » Fri Dec 06, 2024 7:59 am
Using the Arduino framework with this library:
https://github.com/pschatzmann/ESP32-A2DP
it requires more than 21 seconds to connect to my Bluetooth speaker. Of course I won't compare the performances with a personal computer that requires less than 1 second, but I'm wondering if using ESP-IDF framework instead would lead to reduce that time.
Ivan32
Re: Time needed to A2DP connection
Postby Ivan32 » Thu May 22, 2025 2:58 pm
We have the same issue. ESP32 always takes 30 to 40 seconds to connect to audio sink. Because of this issue, we are moving to another microchip vendor.
Also see this threads:
https://github.com/espressif/esp-idf/issues/15913
viewtopic.php?t=45508
