WT-ETH01 failed to initialize ethernet
Melek_Cherif
Postby Melek_Cherif » Mon Dec 09, 2024 2:59 pm
Hello, I am having the same problem with two wt-eth01 modules (v1.4). After uploading the basic example of ethernet and some debugs. I am always encountering this error:
E (2211) esp.emac: emac_esp32_init(371): reset timeout
E (2211) esp_eth: esp_eth_driver_install(228): init mac failed
I tried different configurations for the clock and physical address but still having the same problem. Actually, I am starting to doubt the hardware capability
ondrej
Re: WT-ETH01 failed to initialize ethernet
Postby ondrej » Tue Dec 10, 2024 9:19 am
You have problems with REF RMII CLK. Is this https://github.com/ldijkman/WT32-ETH01- ... ematic.pdf your board? If so, you need to enable external oscillator prior Ethernet init.
angelov
Postby angelov » Tue Dec 17, 2024 9:37 pm
Can you please provide direction as to how I would go about "Enabling" the external Oscillator? Are there programming steps, or hardware pins that need to be pulled low or high?
I would appreciate if you could provide some clarity, as I have had the exact same issues with any code that I have tried to program on m WT32-ETH01 board.
ondrej
Postby ondrej » Thu Dec 19, 2024 7:14 am
User "nopnop2002" suggests to use Ethernet driver reset pin configuration, see https://github.com/espressif/esp-idf/issues/15004 It's little bit hacky but should do the job.
Clearer approach is presented at https://github.com/espressif/esp-eth-dr ... ain.c#L195. Remove everything except of GPIO setting starting at https://github.com/espressif/esp-eth-dr ... ain.c#L240
It's for different driver but the idea should be clear.
Or just set GPIO which enables the oscillator at the start of your main.
Users browsing this forum: Applebot and 9 guests
