problems with UDP Mode 2
RecursiveError
Postby RecursiveError » Sun Dec 15, 2024 11:12 pm
I'm trying to set up a UDP listener where I'll receive packets on port 1234 and reply to whoever sent it
the problem is that it seems that mode 2 has no effect, the IP and the remote port does not change, the only way to modify them is to send AT+CIPSEND
Here are the commands I used: (ESP-AT 3.4.0.0)
AT+CIPSTART=3,"UDP","255.255.255.255",1234,1234,2
3,CONNECT
OK
AT+CIPSTATE?
+CIPSTATE:3,"UDP","255.255.255.255",1234,1234,0
OK
+IPD,3,7
AT+CIPSTATE?
OK
AT+CIPRECVDATA=3,7
+CIPRECVDATA:7,"192.168.15.61",49587,TESTE
OK
AT+CIPSTATE?
OK
AT+CIPSEND=3,3,"192.168.15.61",49587
OK
Recv 3 bytes
SEND OK
AT+CIPSTATE?
+CIPSTATE:3,"UDP","192.168.15.61",49587,1234,0
OK
the documentation says:
2: Each time UDP data is received, the <"remote host"> and <remote port> will be changed to the IP address and port of the device that sends the data."
Am I doing something wrong?
esp-at
Re: problems with UDP Mode 2
Postby esp-at » Thu Mar 20, 2025 9:40 am
thanks for your feedback! you are right, it should be a bug when passive mode is enabled. will fix it in next version.
esp-at
Postby esp-at » Fri Mar 28, 2025 5:12 am
