MCU: ESP32-WROOM-32E
My goal is to have two ESP32s communicate via Bluetooth. I am using this master and slave code from GitHub to allow communication, but the two MCUs never connect.
To determine if the devices could be detected, I ran the bt_classic_device_discovery built-in example. When running it on the ESP32 that connects to COM5, the program runs successfully and I am able to detect my ESP32_SLAVE device. However, when running the program on the ESP32 connected to COM3, I get the following error:
#3error Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
Both devices have Bluetooth enabled because when either one connects to COM5, I do not get the above error, but when they connect to COM3, I do.
I was wondering what steps I should take to debug.
Thanks.
Error: Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
RobotDragon0
Re: Error: Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
only the ESP32 supports Bluetooth Classic 4.2 see https://gist.github.com/sekcompsci/2bf3 ... 4fa819f421
have a look at BLE - File>Examples>BLE>UART
probably simpler to use WiFI e.g. ESP-NOW https://randomnerdtutorials.com/esp-now ... duino-ide/
lbernstone
Set your core debug level to verbose. In the output, you should have a section for chip info. Make sure it shows Classic BT. Mine looks like this for a Pico-v3 board. Communication over BLE is preferable to classic (due to the LE part).
07:44:30.078 -> Chip Info:
07:44:30.078 -> ------------------------------------------
07:44:30.078 -> Model : ESP32
07:44:30.078 -> Package : PICO-V3-02
07:44:30.112 -> Revision : 3.00
07:44:30.112 -> Cores : 2
07:44:30.112 -> CPU Frequency : 240 MHz
07:44:30.112 -> XTAL Frequency : 40 MHz
07:44:30.112 -> Features Bitfield : 0x000000b3
07:44:30.112 -> Embedded Flash : Yes
07:44:30.145 -> Embedded PSRAM : Yes
07:44:30.145 -> 2.4GHz WiFi : Yes
07:44:30.145 -> Classic BT : Yes
07:44:30.145 -> BT Low Energy : Yes
07:44:30.145 -> IEEE 802.15.4 : No
Users browsing this forum: Bing [Bot], ChatGPT-User and 1 guest
