Hello everyone,
i'm working on a little project. I want to use a LS055R1SX04 (used without backlight in UV 3D-Printers) LCD to expose pcb designs on raw pcbs.
Right now i use a HDMI to MIPI converter PCB but i hope that i can use the MIPI-DSI Interface of the ESP32-P4.
For my use case there is no need for fast fps i just need the resolution.
The LS055R1SX04 and LS055R1SX03 both have a resolution of 1440(H)×2560(V) Pixel.
I searched in the documentation but i could not find any information about the maximum supported resolution?
ESP32P4 - Maximal supported resolution via MIPI-DSI?
Re: ESP32P4 - Maximal supported resolution via MIPI-DSI?
I cannot speak for Espressif as I don't work for them. I am just reporting what I have seen in the header files,.
So there are at least enough bits for this resolution, But there is no information in the headers if there is a valid range.
I am although not sure if there is a mode, like in the LCD module, where these parameters are ignored and it will just send whatever comes from the DMA channel.
struct {
/** htotal : R/W; bitpos: [11:0]; default: 800;
* this field configures the total length of one line (by pixel num) for dpi output,
* must meet: reg_htotal > reg_hdisp+reg_hsync+reg_hbank
uint32_t htotal:12;
uint32_t reserved_12:4;
/** hdisp : R/W; bitpos: [27:16]; default: 640;
* this field configures the length of valid pixel data (by pixel num) for dpi output
uint32_t hdisp:12;
uint32_t reserved_28:4;
};Code: Select all
struct {
/** vtotal : R/W; bitpos: [11:0]; default: 525;
* this field configures the total length of one frame (by line) for dpi output, must
* meet: reg_vtotal > reg_vdisp+reg_vsync+reg_vbank
uint32_t vtotal:12;
/** vdisp : R/W; bitpos: [27:16]; default: 480;
* this field configures the length of valid line (by line) for dpi output
uint32_t vdisp:12;
Hey and thanks a lot for the fast answer!
That is very good to know, but i struggle now after i received the datasheets for the displays.
Looks like both use 2 channel MIPI-DSI with 4 lanes per channel and it even looks like this is the only supported mode.
With a bit luck i find a mode in the 329 page driver specification to push the image in the gram over a single line.
Last possible option is to use a RGB to DSI converter ic and use a cheaper ESP32-S3.
More work for the next year...
I believe espressif recently released drivers supporting mipi to hdmi converter which should support resolutions up to 1920x1080, so in theory this resolution is reachable.
johnboiles
I'm having success with 1920x1080. It's definitely possible!
Users browsing this forum: Bing [Bot] and 2 guests
