LittleFS for ESP32-WROOM
kan.deng@qq.com
Postby kan.deng@qq.com » Wed Jan 08, 2025 5:47 am
How to configure and program LittleFS in platoformio to run on a ESP32-WROOM chip?
I did the following, but failed.
Can anyone give me a hint how to solve the problem?
Step 1. configure platformio.ini
Notice that: board_build.filesytem = littlefs
[env:esp32dev]
platform = espressif32
board = esp32dev
framework = arduino
board_build.partitions = default_4MB.csv
;board_build.flash_mode = dio
;board_build.f_flash = 80000000L
Step 2. create a partition table, default_4MB.csv
Notice that we created a partition called "littlefs",
# Name,   Type, SubType, Offset,  Size, Flags
nvs,      data, nvs,     0x9000,  0x5000,
otadata,  data, ota,     0xe000,  0x2000,
app0,     app,  ota_0,   0x10000, 0x140000,
app1,     app,  ota_1,   0x150000,0x140000,
littlefs,   data, littlefs,  0x290000,0x160000,
coredump, data, coredump,0x3F0000,0x10000,
Step 3. create "data" file folder
Notice that in "data" folder, there is a file "index.html", and a subdirectory "subdir" which contains another file "test.txt"
project_home/data/
                      index.html
                      subdir/test.txt
Step 4. Build the filesystem image, and upload the filesystem image to ESP32-WROOM, using Platformio tools.
Notice that in the log, platformio create a filesystem image called "" and uploaded it successfully.
Building FS image from 'data' directory to .pio/build/esp32dev/spiffs.bin
/index.html
/subdir/test.txt
Looking for upload port...
Auto-detected: /dev/ttyUSB0
Uploading .pio/build/esp32dev/spiffs.bin
Step 5. We wrote a C++ program to use LittleFS
#include <LittleFS.h>
void EmbeddedFS::setup_embeddedfs() {
    // LittleFS.begin(bool formatOnFail, const char *basePath, uint8_t maxOpenFiles, const char *partitionLabel)
    if (!LittleFS.begin(true, "/littlefs", 10U, "littlefs")) {
    // if (!SPIFFS.begin(true, "/spiffs", 10U, "spiffs")) {
    // if (!SPIFFS.begin(true)) {
        Serial.printf("\n[WARN] LittleFS mount failed. \n");
        return;
    else {
        Serial.printf("\n[INFO] Successfully mounts LittleFS at '%s'. \n",
            LittleFS.mountpoint()
    // Verify that the LittleFS file system works well.
    // List file directory with 3 levels.
    list_dir("/", 3);
void EmbeddedFS::list_dir(String dir_name, int levels) {
    const char *_dir_name = dir_name.c_str();
    Serial.printf("\n[INFO] Listing directory: '%s'\n", dir_name);
    Serial.printf("-- Notice that SPIFSS doesn't recognize directories, but it can find the files inside subdirs. --\n\n");
    // File root = SPIFFS.open(_dir_name);
    File root = LittleFS.open(_dir_name);
    if (!root) {
        Serial.printf("\n[WARN] Failed to open directory: %s.\n", _dir_name);
        return;
    if (!root.isDirectory()) {
        Serial.printf("\n[WARN] '%s' not a directory. \n", _dir_name);
        return;
    File file = root.openNextFile();
    while (file) {
        if (file.isDirectory()) {
            Serial.print("  DIR : ");
            Serial.println(file.name());
            if (levels) {
                list_dir(file.path(), levels - 1);
            Serial.printf("  FILE: '%s', SIZE: %d \n", file.name(), file.size());
Step 6. Compile, upload the programs and run them on ESP32-WROOM
Following is the execution result, which contains bugs.
[INFO] Successfully mounts LittleFS at '/littlefs'.
[INFO] Listing directory: '/'
[    64][E][vfs_api.cpp:23] open(): File system is not mounted
[WARN] Failed to open file '/subdir/test.txt' for writing.
[    74][E][vfs_api.cpp:23] open(): File system is not mounted
[WARN] Failed to open file '/subdir/test.txt' for reading.
Step 7. Change begin()
We changed LittleFS.begin(true, "/littlefs", 10U, "littlefs") to LittleFS.begin(true, "/littlefs", 10U, "spiffs"),
More severe bugs are thrown, as following,
 E (20) esp_littlefs: partition "spiffs" could not be found
 E (20) esp_littlefs: Failed to initialize LittleFS
 [    51][E][LittleFS.cpp:79] begin(): Mounting LittleFS failed! Error: 261
Can anyone give us a hint how to fix the bug? Many thanks.
lbernstone
Re: LittleFS for ESP32-WROOM
Postby lbernstone » Wed Jan 08, 2025 8:10 pm
TL;DR. Make sure all your variables are valid at the time you instantiate the class, and you don't have anything local that needs to be persistent.
If you don't need Arduino FS compatibility, I'd recommend just using the POSIX vfs layer.
