CPU_FREQ_MAX always held by rtos0 / rtos1 power management locks? And other oddities.
expresspotato
Postby expresspotato » Mon Jan 13, 2025 4:41 pm
Just wondering if this is the normal behaviour. We're trying to do frequency scaling to save some power, but noticed right off the bat that rtos0 and rtos1 both hold a CPU_FREQ_MAX power management lock, in what appears to be anytime they exit their idle hook.
Wouldn't that imply they anytime code is running it's always at CPU_FREQ_MAX anytime the given core is not idle, and not suspended by light sleep?
Some other oddities:
1) Checking the cpu frequency using ets_get_cpu_frequency(), always reveals the CPU is running at 240 Mhz... Even if there are no locks, by commenting out the acquire / release in pm_impl.c.
2) The power management information statement shows APB_MAX of 240... Odd, I thought the APB max is 80 Mhz?
I (1240) pm: Frequency switching config: CPU_MAX: 240, APB_MAX: 240, APB_MIN: 80, Light sleep: ENABLED
Regards,
esp_pm_config_esp32_t pm_config;
pm_config.light_sleep_enable = true;
pm_config.min_freq_mhz = 80;
pm_config.max_freq_mhz = 240;
esp_err_t ret_pm_config;
ret_pm_config = esp_pm_configure(&pm_config);
ESP_ERROR_CHECK(ret_pm_config);
while (true){
	uint32_t value = 0;
	ESP_ERROR_CHECK(esp_clk_tree_src_get_freq_hz(SOC_MOD_CLK_CPU, 0, &value));
	ESP_LOGW(TAG, "Cpu Freq: %lu", value);
	esp_pm_dump_locks(stdout);
	vTaskDelay(pdMS_TO_TICKS(1000 * 5));
I (11) boot: ESP-IDF v5.1.5-dirty 2nd stage bootloader
I (11) boot: compile time Jan 13 2025 09:15:55
I (11) boot: Multicore bootloader
I (15) boot: chip revision: v3.1
I (19) qio_mode: Enabling default flash chip QIO
I (24) boot.esp32: SPI Speed      : 80MHz
I (29) boot.esp32: SPI Mode       : QIO
I (33) boot.esp32: SPI Flash Size : 8MB
I (38) boot: Enabling RNG early entropy source...
I (43) boot: Partition Table:
I (47) boot: ## Label            Usage          Type ST Offset   Length
I (54) boot:  0 efuse            efuse            01 05 0000b000 00002000
I (62) boot:  1 emul_efuse       efuse            01 05 0000d000 00002000
I (69) boot:  2 otadata          OTA data         01 00 0000f000 00002000
I (77) boot:  3 phy_init         RF data          01 01 00011000 00001000
I (84) boot:  4 nvs_keys         NVS keys         01 04 00012000 00001000
I (1050) cpu_start: Pro cpu start user code
I (1050) cpu_start: cpu freq: 240000000 Hz
I (1050) cpu_start: Application information:
I (1054) cpu_start: Project name:     liberty
I (1059) cpu_start: App version:      Liberty One
I (1064) cpu_start: Compile time:     Jan 13 2025 09:15:23
I (1070) cpu_start: ELF file SHA256:  4fe14240638da244...
I (1076) cpu_start: ESP-IDF:          v5.1.5-dirty
I (1082) cpu_start: Min chip rev:     v3.0
I (1086) cpu_start: Max chip rev:     v3.99
I (1091) cpu_start: Chip rev:         v3.1
I (1096) heap_init: Initializing. RAM available for dynamic allocation:
I (1104) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (1110) heap_init: At 3FFB7CD8 len 00000328 (0 KiB): DRAM
I (1116) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (1122) heap_init: At 3FFC2358 len 0001DCA8 (119 KiB): DRAM
I (1128) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1135) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1141) heap_init: At 40090004 len 0000FFFC (63 KiB): IRAM
I (1148) esp_psram: Adding pool of 2048K of PSRAM memory to heap allocator
I (1156) spi_flash: detected chip: generic
I (1160) spi_flash: flash io: qio
I (1175) pm: Frequency switching config: CPU_MAX: 240, APB_MAX: 240, APB_MIN: 40, Light sleep: DISABLED
I (1223) coexist: coex firmware version: 27d8387
I (1229) app_start: Starting scheduler on CPU0
I (1234) app_start: Starting scheduler on CPU1
I (1234) main_task: Started on CPU0
I (1244) main_task: Calling app_main()
W (1244) ******** LIBERTY MAIN START (1.055) ********
I (1254) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1259) pm: Frequency switching config: CPU_MAX: 240, APB_MAX: 240, APB_MIN: 80, Light sleep: ENABLED
W (1269) LIBERTY: Cpu Freq: 240
Lock stats:
Name            Type            Arg    Active
lib_no_sleep    NO_LIGHT_SLEEP  0      0
rtos1           CPU_FREQ_MAX    0      0
rtos0           CPU_FREQ_MAX    0      1
W (6299) LIBERTY: Cpu Freq: 240
Lock stats:
W (11314) LIBERTY: Cpu Freq: 240
Lock stats:
With the locks in pm_impl.c commented out for testing, the CPU still appears to be running at 240 Mhz.
W (446705) LIBERTY: Cpu Freq: 240000000
Lock stats:
rtos1           APB_FREQ_MAX    0      0
rtos0           APB_FREQ_MAX    0      0
benboppo
Re: CPU_FREQ_MAX always held by rtos0 / rtos1 power management locks? And other oddities.
Postby benboppo » Mon Jul 07, 2025 11:24 pm
I am also seeing rtos0/rtos1 holding CPU_FREQ_MAX lock. I think that behavior should be configurable since I have some tasks that would run fine at 80Mhz and do not need the max frequency.
The docs at https://docs.espressif.com/projects/esp ... ement.html do not specify that all FreeRTOS tasks get CPU_FREQ_MAX either.
shushenghong
Postby shushenghong » Wed Sep 03, 2025 12:56 am
i also see this, why rtos0 always acquire CPU_FREQ_MAX lock?
Lock stats:
mpi_cpu         CPU_FREQ_MAX    0      0
mpi_sleep       NO_LIGHT_SLEEP  0      0
i2s_driver      APB_FREQ_MAX    0      0
I2C_0           NO_LIGHT_SLEEP  0      0
wifi            APB_FREQ_MAX    0      0
Users browsing this forum: Amazon [Bot], Bytespider, ChatGPT-User, Google [Bot], pdragun, Semrush [Bot] and 1 guest
