前提:
1.esp32s3-kervo-2 v3开发板在esp-idf v5.4版本去编译烧录check_display_led_example.c示例,在monitor的时候,发现audio_board_led_init函数初始化失败,打印日志如下所示:
I (242) sleep_gpio: Configure to isolate all GPIO pins in sleep state
I (249) sleep_gpio: Enable automatic switching of GPIO sleep configuration
I (256) main_task: Started on CPU0
I (286) main_task: Calling app_main()
I (230) spi_flash: detected chip: gd
I (232) spi_flash: flash io: dio
W (235) ADC: legacy driver is deprecated, please migrate to `esp_adc/adc_oneshot.h`
I (286) CHECK_DISPLAY_LED: [ 1 ] Create display service instance
E (286) CHECK_DISPLAY_LED: audio_board_led_init fail
I (286) main_task: Returned from app_main()
问题:
请问一下check_display_led_example.c是可以在esp32s3-kervo-2 v3上跑的,但是初始化会失败?可以怎么去解决这个问题?谢谢
esp32s3-kervo-2 v3运行check_display_led_example.c无法初始化成功
tianrongqin
