Switch or temperature device using on other nodes and their devices
BerndN
Postby BerndN » Sat Jan 18, 2025 3:16 pm
Is it possible to use a switch device state or a temperature device value on devices that are on another node and how?
ahsrabrifat
Re: Switch or temperature device using on other nodes and their devices
Postby ahsrabrifat » Mon Jan 20, 2025 1:45 pm
You can achieve this by using MQTT. Configure both nodes to connect to the same MQTT broker.The node with the switch or temperature sensor publishes the data to an MQTT topic. For example, the temperature sensor node publishes to home/room1/temperature.The other node subscribes to the same topic to receive updates in real-time. Use the received value to control the state or make decisions.
Piyush
Postby Piyush » Mon Jan 20, 2025 5:42 pm
In the context of ESP RainMaker, node to node direct communication is not possible. You can, however, create automations using the RainMaker phone apps, so that events on one node can trigger actions on others.
