Problem Details:
OTA update writes the new firmware to ota_1 and marks it as the boot partition successfully.
Calls to esp_ota_get_boot_partition() confirm that the boot partition has been updated to ota_1 post-update.
On reboot, the ESP32 always boots from ota_0 (instead of ota_1 as intended)
Environment:
Board: ESP32-S3-WROOM-2-N32R8V (32MB Flash, 8MB PSRAM Octal)
Platform: PlatformIO (VSCode)
Framework: Arduino
Partition Table:
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xE000, 0x2000,
app0, app, ota_0, 0x10000, 0xBB0000,
app1, app, ota_1, 0xBC0000, 0xBB0000,
nvm, data, nvs, 0x1770000, 0x890000,
The following analysis has been conducted:
1. Find the current boot partition (before update)
esp_ota_get_boot_partition()2. Check if ota partition is bootable
if (_partitionIsBootable(_partition) == true) {
Serial.println("[Updater] Partition is bootable.");
}3. Checked the ota partition's address
Serial.println("[Updater] New partition address: " + String(_partition->address));4. Verified result on setting boot partition
esp_err_t result = esp_ota_set_boot_partition(_partition);5. Forced the ota partition to mark app as valid after verification.
if (esp_partition_verify(_partition)) {
// Mark the newly flashed partition as valid, if partition is valid
esp_err_t err = esp_ota_mark_app_valid_cancel_rollback();
if (err != ESP_OK) {
Serial.println("[Updater] Error: Partition not valid.");
Serial.println("[Updater] Error marking app valid! Code: " + String(err));
Serial.println("[Updater] Partition is valid.");
Serial.println("[Updater] App marked as valid. OK! Code: " + String(err));
}6. Read-out the contents of ota_data partition
The following data is stored in the otadata partition (address: 0xE000, length 0x2000)
01 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 9A 98 43 47Question
How come that my ESP32 is still booting from partition app0 after reboot / power cycle?
The serial output confirms:
Currently running from partition: Type: 0, Subtype: 16, Address: 0x10000Thanks a lot for your help!
