ESP32-U4WDH 'No serial data received'
Vitaly
Postby Vitaly » Tue Jan 21, 2025 7:57 pm
When power is supplied, there is no message in the monitor.
After a hardware reset, there is no message in the monitor.
No response to TX
Power supply: 3.3v/0.6a
Adapter: CP2102
I bought 25 chips, assembled 3 identical devices - all three are silent.
I can't figure out what I'm doing wrong.
Sketches attached
[/attachment]
Re: ESP32-U4WDH 'No serial data received'
Postby Sprite » Wed Jan 22, 2025 12:50 am
I strongly suggest you go over the esp32 hardware design guidelines and see if your schematics match that. For instance, it says:
External Crystal Clock Source (Compulsory)
The ESP32 firmware only supports 40 MHz crystal.
and that is just one of a bunch of things I see you not doing in your schematic.
Vitaly
Postby Vitaly » Wed Jan 22, 2025 10:07 am
So, in the absence of an external crystal 40MHz, it is impossible to read the chip ID? The internal 8 MHz generator does not support the serial port?
Vitaly
Postby Vitaly » Wed Jan 22, 2025 10:20 am
So, thanks for the consultation, I am satisfied
