Wi-Fi Connection Issues on ESP32-WROOM-32D: "Incorrect Password"
pcdevs
Postby pcdevs » Thu Jan 23, 2025 11:35 am
Hello everybody!
I am facing an issue with ESP32-WROOM-32D modules related to Wi-Fi connection. On some modules (not all), I receive the error "Incorrect password" when trying to connect Android devices to the network generated by the ESP32. The issue is intermittent and seems to be related to the firmware or memory.
Interestingly, after several attempts to reflash the ESP32, the password starts working normally again. This leads me to believe the problem might be related to the module's memory, although I always erase it before flashing new firmware.
Commands Used for Flashing:
I am using esptool.py for flashing, and the commands are as follows:
Memory Erase:
esptool.py erase_flash
Firmware Flashing:
esptool.py --chip esp32 --port "COM3" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size 4MB 0x1000 bootloader.bin 0x8000 partitions.bin 0xe000 boot_app0.bin 0x10000 firmware.bin
ESP32-WROOM-32D Module Specifications:
IDF Version: v4.0.1
AT Version: 2.1.0.0
Firmware P/N: ESP32U012
Has anyone faced a similar issue with the ESP32?
Is there any additional step I should consider during the flashing or configuration of the module?
Could this be a specific issue with the firmware version or AT commands?
Thank you in advance for any guidance or tips to help resolve this issue!
esp-at
Re: Wi-Fi Connection Issues on ESP32-WROOM-32D: "Incorrect Password"
Postby esp-at » Wed Mar 19, 2025 9:53 am
Hi, it sounds like a phy calibration issue. could you pelase send the `AT+RESTORE` command to erase the phy calibration data and auto do phy calibration, to see this issue still exists.
Typically, when the device moves to a new environment, should do a full rf calibration.
https://docs.espressif.com/projects/esp ... ation.html
