What could be the reason for this? Does usage of BLE get in the way somehow? I checked the coex documentation, and it looks like it shouldn't. Could it be a power thing as my application is probably using a bit more power than just the station example?
This is reproducible, as it happens every time. I have tried this with different access points as well.
Note that this does NOT happen on a different board (which is the same custom design that we have for the S3)
Success logs for standard station application
I (924) main_task: Calling app_main()
V (934) partition: Loading the partition table
V (934) mmap: actual_mapped_len is 0x10000
V (944) calculated md5: 0x3fca3588 f4 ad 4f 45 38 56 4b 5d 74 35 b6 2c 75 b6 95 24 |..OE8VK]t5.,u..$|
V (954) stored md5: 0x3c0c8070 f4 ad 4f 45 38 56 4b 5d 74 35 b6 2c 75 b6 95 24 |..OE8VK]t5.,u..$|
V (964) partition: Partition table MD5 verified
I (994) wifi station: ESP_WIFI_MODE_STA
D (994) esp_netif_lwip: LwIP stack has been initialized
D (994) esp_netif_lwip: esp-netif has been successfully initialized
D (994) event: running task for loop 0x3fca6400
D (1004) event: created task for loop 0x3fca6400
D (1004) event: created event loop 0x3fca6400
D (1004) esp_netif_lwip: check: remote, if=0x3fca3500 fn=0x42010c88
V (1014) esp_netif_objects: esp_netif_add_to_list_unsafe 0x3fca7328
D (1024) esp_netif_objects: esp_netif_add_to_list_unsafe netif added successfully (total netifs: 1)
D (1034) esp_netif_lwip: call api in lwip: ret=0x0, give sem
I (1034) pp: pp rom version: e7ae62f
I (1044) net80211: net80211 rom version: e7ae62f
D (1044) nvs: nvs_open_from_partition misc 1
I (1064) wifi:wifi driver task: 3fca9cf4, prio:23, stack:6656, core=0
V (1064) esp_adapter: thread sem create: sem=0x3fca9e4c
V (1064) esp_adapter: thread sem get: sem=0x3fca9e4c
D (1064) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 8 bit
D (1074) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 0 bit
D (1084) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 24 bit
D (1084) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 16 bit
D (1094) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 8 bit
D (1104) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 0 bit
D (1104) nvs: nvs_open_from_partition nvs.net80211 1
D (1114) nvs: nvs_get opmode 1
D (1114) nvs: nvs_get_str_or_blob sta.ssid
D (1124) nvs: nvs_get sta.authmode 1
D (1124) nvs: nvs_get_str_or_blob sta.pswd
D (1134) nvs: nvs_get_str_or_blob sta.pmk
D (1134) nvs: nvs_get sta.chan 1
D (1134) nvs: nvs_get auto.conn 1
D (1144) nvs: nvs_get bssid.set 1
D (1144) nvs: nvs_get_str_or_blob sta.bssid
D (1144) nvs: nvs_get sta.lis_intval 2
D (1154) nvs: nvs_get sta.phym 1
D (1154) nvs: nvs_get sta.phybw 1
D (1154) nvs: nvs_get_str_or_blob sta.apsw
D (1164) nvs: nvs_get_str_or_blob sta.apinfo
D (1174) nvs: nvs_get sta.scan_method 1
D (1174) nvs: nvs_get sta.sort_method 1
D (1174) nvs: nvs_get sta.minrssi 1
D (1174) nvs: nvs_get sta.minauth 1
D (1184) nvs: nvs_get sta.pmf_e 1
D (1184) nvs: nvs_get sta.pmf_r 1
D (1184) nvs: nvs_get sta.btm_e 1
D (1194) nvs: nvs_get sta.rrm_e 1
D (1194) nvs: nvs_get sta.mbo_e 1
D (1194) nvs: nvs_get_str_or_blob ap.ssid
D (1204) nvs: nvs_get_str_or_blob ap.passwd
D (1204) nvs: nvs_get_str_or_blob ap.pmk
D (1214) nvs: nvs_get ap.chan 1
D (1214) nvs: nvs_get ap.authmode 1
D (1214) nvs: nvs_get ap.hidden 1
D (1224) nvs: nvs_get ap.max.conn 1
D (1224) nvs: nvs_get bcn.interval 2
D (1224) nvs: nvs_get ap.phym 1
D (1234) nvs: nvs_get ap.phybw 1
D (1234) nvs: nvs_get ap.sndchan 1
D (1234) nvs: nvs_get ap.pmf_e 1
D (1244) nvs: nvs_get ap.pmf_r 1
D (1244) nvs: nvs_get ap.p_cipher 1
D (1244) nvs: nvs_get lorate 1
D (1254) nvs: nvs_get_str_or_blob country
D (1254) nvs: nvs_get ap.ftm_r 1
D (1254) nvs: nvs_get sta.ft 1
D (1264) nvs: nvs_get sta.owe 1
D (1264) nvs: nvs_get sta.trans_d 1
D (1264) nvs: nvs_get sta.sae_h2e 1
D (1274) nvs: nvs_get sta.sae_pk_mode 1
D (1274) nvs: nvs_get sta.bss_retry 1
D (1284) nvs: nvs_get_str_or_blob sta.owe_data
D (1284) nvs: nvs_get sta.he_dcm 1
D (1284) nvs: nvs_get sta.he_dcm_c_tx 1
D (1294) nvs: nvs_get sta.he_dcm_c_rx 1
D (1294) nvs: nvs_get sta.he_mcs9_d 1
D (1304) nvs: nvs_get sta.he_su_b_d 1
D (1304) nvs: nvs_get sta.he_su_b_f_d 1
D (1304) nvs: nvs_get sta.he_mu_b_f_d 1
D (1314) nvs: nvs_get sta.he_cqi_f_d 1
D (1314) nvs: nvs_get_str_or_blob sta.sae_h2e_id
D (1324) nvs: nvs_get ap.sae_h2e 1
D (1324) nvs: nvs_get_str_or_blob ap.pmk_info
D (1324) nvs: nvs_get nan.phym 1
D (1334) nvs: nvs_set ap.sndchan 1 1
I (1334) wifi:wifi firmware version: 3ce09e5
I (1334) wifi:wifi certification version: v7.0
I (1344) wifi:config NVS flash: enabled
I (1344) wifi:config nano formating: disabled
I (1354) wifi:Init data frame dynamic rx buffer num: 32
I (1354) wifi:Init static rx mgmt buffer num: 5
I (1364) wifi:Init management short buffer num: 32
I (1364) wifi:Init dynamic tx buffer num: 32
I (1364) wifi:Init static tx FG buffer num: 2
I (1374) wifi:Init static rx buffer size: 1600
I (1374) wifi:Init static rx buffer num: 10
I (1384) wifi:Init dynamic rx buffer num: 32
V (1384) wifi:hint=255, act_dur=<0,120>, pas_dur=360, nchans=14 history_num=0
V (1394) esp_adapter: thread sem get: sem=0x3fca9e4c
I (1394) wifi_init: rx ba win: 6
I (1404) wifi_init: tcpip mbox: 32
I (1404) wifi_init: udp mbox: 6
I (1404) wifi_init: tcp mbox: 6
I (1414) wifi_init: tcp tx win: 5760
I (1414) wifi_init: tcp rx win: 5760
I (1424) wifi_init: tcp mss: 1440
I (1424) wifi_init: WiFi IRAM OP enabled
I (1424) wifi_init: WiFi RX IRAM OP enabled
V (1434) esp_adapter: thread sem get: sem=0x3fca9e4c
D (1434) nvs: nvs_get opmode 1
V (1444) esp_adapter: thread sem get: sem=0x3fca9e4c
D (1444) wifi:clear blacklist
D (1454) nvs: nvs_get_str_or_blob sta.ssid
D (1454) nvs: nvs_get sta.pmf_e 1
V (1454) esp_adapter: thread sem get: sem=0x3fca9e4c
I (1464) phy_init: phy_version 670,b7bc9b9,Apr 30 2024,10:54:13
D (1464) phy_init: loading PHY init data from application binary
D (1474) nvs: nvs_open_from_partition phy 0
D (1474) nvs: nvs_get cal_version 4
V (1484) phy_init: phy_get_rf_cal_version: 670
D (1484) nvs: nvs_get_str_or_blob cal_mac
D (1494) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 8 bit
D (1494) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 0 bit
D (1504) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 24 bit
D (1514) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 16 bit
D (1524) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 8 bit
D (1524) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 0 bit
D (1534) nvs: nvs_get_str_or_blob cal_data
D (1544) nvs: nvs_close 3
D (1544) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 8 bit
D (1544) efuse: In EFUSE_BLK1__DATA1_REG is used 8 bits starting with 0 bit
D (1554) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 24 bit
D (1564) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 16 bit
D (1564) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 8 bit
D (1574) efuse: In EFUSE_BLK1__DATA0_REG is used 8 bits starting with 0 bit
D (1594) temperature_sensor: range changed, change to index 2
V (1614) wifi:ht20 freq=2412, chan=1
D (1614) wifi:filter: set rx policy=0
I (1614) wifi:mode : sta (68:b6:b3:35:d6:4c)
I (1614) wifi:enable tsf
D (1614) wifi:filter: set rx policy=1
D (1614) wifi:connect status 0 -> 0
D (1614) event: running post WIFI_EVENT:2 with handler 0x42013824 and context 0x3fca7524 on loop 0x3fca6400
D (1624) wifi_init_default: wifi_start esp-netif:0x3fca7328 event-id2
D (1634) wifi_init_default: WIFI mac address: 68 b6 b3 35 d6 4c
V (1644) esp_adapter: thread sem create: sem=0x3fcb06d4
V (1644) esp_adapter: thread sem get: sem=0x3fcb06d4
D (1654) esp_netif_lwip: check: remote, if=0x3fca7328 fn=0x4201064c
D (1654) esp_netif_lwip: call api in lwip: ret=0x0, give sem
I (1654) wifi station: wifi_init_sta finished.
D (1664) esp_netif_handlers: esp_netif action has started with netif0x3fca7328 from event_id=2
D (1674) esp_netif_lwip: check: remote, if=0x3fca7328 fn=0x42010f48
D (1684) esp_netif_lwip: esp_netif_start_api 0x3fca7328
D (1684) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3fca7328
D (1694) esp_netif_lwip: check: local, if=0x3fca7328 fn=0x420116f0
D (1704) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fca7328
V (1704) esp_netif_lwip: esp_netif_is_netif_up esp_netif:0x3fca7328
D (1714) esp_netif_lwip: call api in lwip: ret=0x0, give sem
D (1724) event: running post WIFI_EVENT:2 with handler 0x42009640 and context 0x3fcaffcc on loop 0x3fca6400
V (1734) esp_adapter: thread sem get: sem=0x3fcb06d4
D (1734) wifi:Start wifi connect
D (1734) wifi:connect status 0 -> 0
D (1744) wifi:connect chan=0
D (1744) wifi:first chan=3
D (1744) wifi:connect status 0 -> 1
D (1754) wifi:filter: set rx policy=3
D (1754) wifi:clear scan ap list
D (1754) wifi:start scan: type=0x50f, priority=2, cb=0x42030110, arg=0x0, ss_state=0x1, time=1776124, index=0
V (1764) wifi:inter_channel_timeout: arg=0x0, ss_state=0x1
D (1774) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
V (1774) wifi:change: chan<3,0>, dur<0,120>
V (1784) wifi:ht20 freq=2422, chan=3
V (1784) wifi:enter start op, arg=0x3fc9d42a
V (1784) wifi:scan operation: state=0x3, chan<3,0>, arg=0x3fc9d42a, status=0
V (1794) wifi:scan specific ssid=NEXSENS_GUEST
V (1794) wifi:start max timer
D (1804) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
V (1804) wifi:updated connection retries to 0
D (1814) wpa: rsn_ie - hexdump(len=22):
D (1814) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (1824) wpa: 00 0f ac 02 0c 00
D (1824) wifi:profile match: ss_state=0x7
V (1824) wifi:scan histroy table is not full yet, add
V (1834) wifi:add ssid=NEXSENS_GUEST, chan=3 to scan history
D (1834) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
V (1844) wifi:updated connection retries to 0
D (1844) wpa: rsn_ie - hexdump(len=22):
D (1854) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (1854) wpa: 00 0f ac 02 0c 00
D (1854) wifi:profile match: ss_state=0x7
V (1864) wifi:update scan history ssid=NEXSENS_GUEST, channel=3
D (1874) wifi:scan end: arg=0x0, status=0, ss_state=0x7
D (1874) wifi:find first mathched ssid, scan done
V (1874) wifi:back home chan=<1,0>, current chan=<3,0>
V (1884) wifi:ht20 freq=2412, chan=1
D (1884) wifi:filter: set rx policy=4
D (1894) wifi:first chan=1
V (1894) wifi:scan_done: arg=0x0, status=0, cur_time=1911779, scan_id=128, scan state=0
V (1904) wifi:call scan_done cb, arg=0x0
D (1904) wifi:handoff_cb: status=0
V (1904) wifi:best bss has set.
D (1904) wifi:ap found, mac=42:94:ed:69:5b:f4
V (1914) wifi:bssid=42:94:ed:69:5b:f4, LR=0
D (1914) wifi:new_bss=0x3fc9d728, cur_bss=0x0, new_chan=<3,0>, cur_chan=1
D (1924) wifi:filter: set rx policy=5
D (1924) wpa: WPA: set AP RSNXE - hexdump(len=0):
I (1934) wifi:new:<3,0>, old:<1,0>, ap:<255,255>, sta:<3,0>, prof:1
V (1934) wifi:ht20 freq=2422, chan=3
D (1944) wifi:connect_op: status=0, auth=5, cipher=3
D (1944) wifi:auth mode is not none
D (1944) wifi:connect_bss: auth=1, reconnect=0
I (1954) wifi:state: init -> auth (b0)
D (1954) wifi:start 1s AUTH timer
D (1964) wifi:clear scan ap list
D (1964) wifi:recv disassoc: reason=8
I (1964) wifi:state: auth -> init (8a0)
D (1974) wifi:stop beacon and connect timers
D (1974) wifi:connect status 1 -> 4
D (1974) wifi:reason: auth fail(202)
D (1984) wifi:add bssid 42:94:ed:69:5b:f4 to blacklist, cnt=0
D (1984) wifi:stop CSA timer
V (1984) wifi:bss connection retry cnt=0
D (1994) wifi:remove 42:94:ed:69:5b:f4 from rc list
I (1994) wifi:new:<3,0>, old:<3,0>, ap:<255,255>, sta:<3,0>, prof:1
D (2004) wifi:filter: set rx policy=8
D (2004) wpa: ELOOP: wpa_sm_notify_disassoc:2271 called to remove timer handler=0x4205dda8, removed count=0
D (2014) wpa: WPA: Clear old PMK and PTK
D (2024) wifi:Try to connect with next matched AP
V (2024) wifi:best bss has set.
D (2024) wifi:ap found, mac=42:94:ed:58:4a:49
V (2034) wifi:bssid=42:94:ed:58:4a:49, LR=0
D (2034) wifi:new_bss=0x3fc9dae8, cur_bss=0x0, new_chan=<3,0>, cur_chan=3
D (2044) wifi:filter: set rx policy=5
D (2044) wpa: WPA: set AP RSNXE - hexdump(len=0):
I (2054) wifi:new:<3,0>, old:<3,0>, ap:<255,255>, sta:<3,0>, prof:1
D (2054) wifi:connect_op: status=0, auth=5, cipher=3
D (2064) wifi:auth mode is not none
D (2064) wifi:connect_bss: auth=1, reconnect=0
I (2064) wifi:state: init -> auth (b0)
D (2074) wifi:start 1s AUTH timer
D (2074) wifi:recv auth: seq=2, status=0
I (2074) wifi:state: auth -> assoc (0)
D (2084) wifi:restart connect 1s timer for assoc
D (2094) wifi:recv assoc: type=0x10
D (2104) wifi:filter: set rx policy=6
I (2104) wifi:state: assoc -> run (10)
D (2104) wifi:connect status 4 -> 1
D (2104) wifi:start 10s connect timer for 4 way handshake
D (2104) wpa: WPA: Association event - clear replay counter
D (2114) wpa: WPA: Clear old PTK
V (2114) wifi:wpa_psk start
D (2114) wpa: IEEE 802.1X RX: version=2 type=3 length=95
V (2124) wpa: WPA: RX EAPOL-Key - hexdump(len=99):
V (2124) wpa: 02 03 00 5f 02 00 8a 00 10 00 00 00 00 00 00 00
V (2134) wpa: 01 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f
V (2144) wpa: 98 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24
V (2144) wpa: a8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2154) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2164) wpa: 00 00 00
D (2164) wpa: EAPOL-Key type=2
D (2174) wpa: key_info 0x8a (ver=2 keyidx=0 rsvd=0 Pairwise Ack)
D (2174) wpa: key_length=16 key_data_length=0
D (2184) wpa: replay_counter - hexdump(len=8):
D (2184) wpa: 00 00 00 00 00 00 00 01
D (2184) wpa: key_nonce - hexdump(len=32):
D (2194) wpa: 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f 98
D (2204) wpa: 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24 a8
D (2204) wpa: key_iv - hexdump(len=16):
D (2214) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (2214) wpa: key_rsc - hexdump(len=8):
D (2224) wpa: 00 00 00 00 00 00 00 00
D (2224) wpa: key_id (reserved) - hexdump(len=8):
D (2234) wpa: key_mic - hexdump(len=16):
D (2234) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (2244) wpa: WPA 1/4-Way Handshake
D (2244) wpa: RSN: msg 1/4 key data - hexdump(len=0):
D (2254) wpa: WPA: Renewed SNonce - hexdump(len=32):
D (2254) wpa: db f3 e3 c4 ad e5 19 a7 56 af 4e 98 9c a5 0c 7e
D (2264) wpa: 0a e5 2a f8 a1 2f f5 0c 22 29 75 28 f5 e6 70 d0
D (2264) gdma: new group (0) at 0x3fcb11a8
D (2274) gdma: new pair (0,0) at 0x3fcb0938
D (2274) gdma: new tx channel (0,0) at 0x3fcb1174
D (2284) gdma: new rx channel (0,0) at 0x3fcb11ec
D (2284) gdma: tx channel (0,0), (1:32) bytes aligned, burst enabled
D (2294) gdma: rx channel (0,0), (1:32) bytes aligned, burst disabled
D (2304) wpa: WPA: PTK derivation - A1=68:b6:b3:35:d6:4c A2=42:94:ed:58:4a:49
V (2304) wpa: WPA: PMK - hexdump(len=32):
V (2314) wpa: c5 5c 4b 2d af 33 f4 2d 54 e2 d2 08 51 da 4e c0
V (2314) wpa: c1 23 c8 e1 b8 3c c0 f8 9e 83 de 3c 55 14 5f 76
D (2324) wpa: WPA: PTK - hexdump(len=48):
D (2324) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (2334) wpa: 4e c1 2e 27 69 58 f7 45 a4 a9 37 8b b1 dd 68 0a
D (2334) wpa: 41 4f 85 e1 d2 5f e3 37 f7 59 92 82 c4 81 ac 20
D (2344) wpa: WPA: KCK - hexdump(len=16):
D (2344) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (2354) wpa: WPA: KEK - hexdump(len=16):
D (2354) wpa: 4e c1 2e 27 69 58 f7 45 a4 a9 37 8b b1 dd 68 0a
D (2364) wpa: WPA: TK - hexdump(len=16):
D (2364) wpa: 41 4f 85 e1 d2 5f e3 37 f7 59 92 82 c4 81 ac 20
V (2374) wpa: WPA: WPA IE for msg 2/4
- hexdump(len=22):
V (2374) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
V (2384) wpa: 00 0f ac 02 00 04
D (2384) wpa: WPA Send EAPOL-Key 2/4
D (2394) wpa: WPA: KCK - hexdump(len=16):
D (2394) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (2404) wpa: WPA: Derived Key MIC - hexdump(len=16):
D (2404) wpa: 54 6b 68 43 fa 6d 4e 1f c0 c2 9c 2c 93 5c 85 8b
V (2414) wpa: WPA: TX EAPOL-Key - hexdump(len=121):
V (2414) wpa: 01 03 00 75 02 01 0a 00 00 00 00 00 00 00 00 00
V (2424) wpa: 01 db f3 e3 c4 ad e5 19 a7 56 af 4e 98 9c a5 0c
V (2434) wpa: 7e 0a e5 2a f8 a1 2f f5 0c 22 29 75 28 f5 e6 70
V (2434) wpa: d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2444) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2444) wpa: 00 54 6b 68 43 fa 6d 4e 1f c0 c2 9c 2c 93 5c 85
V (2454) wpa: 8b 00 16 30 14 01 00 00 0f ac 04 01 00 00 0f ac
V (2454) wpa: 04 01 00 00 0f ac 02 00 04
V (2464) wifi:wpa_psk handle succeed
V (2464) wifi:wpa_psk start
D (2464) wpa: IEEE 802.1X RX: version=2 type=3 length=95
V (2474) wpa: WPA: RX EAPOL-Key - hexdump(len=99):
V (2484) wpa: 02 03 00 5f 02 00 8a 00 10 00 00 00 00 00 00 00
V (2484) wpa: 02 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f
V (2494) wpa: 98 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24
V (2494) wpa: a8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2504) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2514) wpa: 00 00 00
D (2514) wpa: EAPOL-Key type=2
D (2524) wpa: key_info 0x8a (ver=2 keyidx=0 rsvd=0 Pairwise Ack)
D (2524) wpa: key_length=16 key_data_length=0
D (2534) wpa: replay_counter - hexdump(len=8):
D (2534) wpa: 00 00 00 00 00 00 00 02
D (2544) wpa: key_nonce - hexdump(len=32):
D (2544) wpa: 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f 98
D (2554) wpa: 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24 a8
D (2554) wpa: key_iv - hexdump(len=16):
D (2564) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (2564) wpa: key_rsc - hexdump(len=8):
D (2574) wpa: 00 00 00 00 00 00 00 00
D (2574) wpa: key_id (reserved) - hexdump(len=8):
D (2584) wpa: key_mic - hexdump(len=16):
D (2584) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (2594) wpa: WPA 1/4-Way Handshake
D (2594) wpa: RSN: msg 1/4 key data - hexdump(len=0):
D (2604) wpa: WPA: PTK derivation - A1=68:b6:b3:35:d6:4c A2=42:94:ed:58:4a:49
V (2604) wpa: WPA: PMK - hexdump(len=32):
V (2614) wpa: c5 5c 4b 2d af 33 f4 2d 54 e2 d2 08 51 da 4e c0
V (2614) wpa: c1 23 c8 e1 b8 3c c0 f8 9e 83 de 3c 55 14 5f 76
D (2624) wpa: WPA: PTK - hexdump(len=48):
D (2624) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (2634) wpa: 4e c1 2e 27 69 58 f7 45 a4 a9 37 8b b1 dd 68 0a
D (2644) wpa: 41 4f 85 e1 d2 5f e3 37 f7 59 92 82 c4 81 ac 20
D (2644) wpa: WPA: KCK - hexdump(len=16):
D (2654) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (2654) wpa: WPA: KEK - hexdump(len=16):
D (2664) wpa: 4e c1 2e 27 69 58 f7 45 a4 a9 37 8b b1 dd 68 0a
D (2664) wpa: WPA: TK - hexdump(len=16):
D (2674) wpa: 41 4f 85 e1 d2 5f e3 37 f7 59 92 82 c4 81 ac 20
V (2674) wpa: WPA: WPA IE for msg 2/4
- hexdump(len=22):
V (2684) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
V (2684) wpa: 00 0f ac 02 00 04
D (2694) wpa: WPA Send EAPOL-Key 2/4
D (2694) wpa: WPA: KCK - hexdump(len=16):
D (2694) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (2704) wpa: WPA: Derived Key MIC - hexdump(len=16):
D (2714) wpa: b0 6d a8 34 c6 c8 69 e2 65 19 67 10 bb 96 cd 87
V (2714) wpa: WPA: TX EAPOL-Key - hexdump(len=121):
V (2724) wpa: 01 03 00 75 02 01 0a 00 00 00 00 00 00 00 00 00
V (2724) wpa: 02 db f3 e3 c4 ad e5 19 a7 56 af 4e 98 9c a5 0c
V (2734) wpa: 7e 0a e5 2a f8 a1 2f f5 0c 22 29 75 28 f5 e6 70
V (2734) wpa: d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2744) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2754) wpa: 00 b0 6d a8 34 c6 c8 69 e2 65 19 67 10 bb 96 cd
V (2754) wpa: 87 00 16 30 14 01 00 00 0f ac 04 01 00 00 0f ac
V (2764) wpa: 04 01 00 00 0f ac 02 00 04
V (2764) wifi:wpa_psk handle succeed
D (2774) wpa: 2/4 txcb, flags=0, txfail 0
V (2774) wifi:wpa_psk start
D (2774) wpa: IEEE 802.1X RX: version=2 type=3 length=151
V (2784) wpa: WPA: RX EAPOL-Key - hexdump(len=155):
V (2784) wpa: 02 03 00 97 02 13 ca 00 10 00 00 00 00 00 00 00
V (2794) wpa: 03 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f
V (2794) wpa: 98 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24
V (2804) wpa: a8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2814) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (2814) wpa: 00 78 a3 01 91 00 f5 11 b7 38 6e d3 a1 d4 05 7a
V (2824) wpa: 6a 00 38 43 e5 12 ae be 0b bf 5d 5d 8e 03 0a 29
V (2824) wpa: 42 ab eb c1 1f b0 b2 90 4b f8 00 3f 0b b9 28 4d
V (2834) wpa: 49 5f a3 8f 24 a1 47 28 27 5b 5c 3f 9c c8 06 49
V (2844) wpa: 52 9e 12 91 b7 18 2b 63 8c c6 98
D (2844) wpa: EAPOL-Key type=2
D (2844) wpa: key_info 0x13ca (ver=2 keyidx=0 rsvd=0 Pairwise Install Ack MIC Secure Encr)
D (2854) wpa: key_length=16 key_data_length=56
D (2864) wpa: replay_counter - hexdump(len=8):
D (2864) wpa: 00 00 00 00 00 00 00 03
D (2864) wpa: key_nonce - hexdump(len=32):
D (2874) wpa: 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f 98
D (2884) wpa: 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24 a8
D (2884) wpa: key_iv - hexdump(len=16):
D (2884) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (2894) wpa: key_rsc - hexdump(len=8):
D (2894) wpa: 00 00 00 00 00 00 00 00
D (2904) wpa: key_id (reserved) - hexdump(len=8):
D (2904) wpa: 00 00 00 00 00 00 00 00
D (2914) wpa: key_mic - hexdump(len=16):
D (2914) wpa: 78 a3 01 91 00 f5 11 b7 38 6e d3 a1 d4 05 7a 6a
D (2924) wpa: RSN: encrypted key data - hexdump(len=56):
D (2924) wpa: 43 e5 12 ae be 0b bf 5d 5d 8e 03 0a 29 42 ab eb
D (2934) wpa: c1 1f b0 b2 90 4b f8 00 3f 0b b9 28 4d 49 5f a3
D (2934) wpa: 8f 24 a1 47 28 27 5b 5c 3f 9c c8 06 49 52 9e 12
D (2944) wpa: 91 b7 18 2b 63 8c c6 98
V (2944) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (2954) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (2964) intr_alloc: Connected src 77 to int 17 (cpu 0)
D (2974) wpa: WPA: decrypted EAPOL-Key key data - hexdump(len=48):
D (2974) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (2984) wpa: 00 0f ac 02 0c 00 dd 16 00 0f ac 01 02 00 51 37
D (2984) wpa: 6b 22 3f ad 16 07 ce 3a be f6 01 e7 62 2e dd 00
D (2994) wpa: WPA 3/4-Way Handshake
D (2994) wpa: WPA: RSN IE in EAPOL-Key - hexdump(len=22):
D (3004) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (3004) wpa: 00 0f ac 02 0c 00
D (3014) wpa: WPA: GTK in EAPOL-Key - hexdump(len=24):
D (3014) wpa: dd 16 00 0f ac 01 02 00 51 37 6b 22 3f ad 16 07
D (3024) wpa: ce 3a be f6 01 e7 62 2e
D (3024) wpa: WPA: IE KeyData - hexdump(len=48):
D (3034) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (3034) wpa: 00 0f ac 02 0c 00 dd 16 00 0f ac 01 02 00 51 37
D (3044) wpa: 6b 22 3f ad 16 07 ce 3a be f6 01 e7 62 2e dd 00
D (3044) wpa: WPA: RSC - hexdump(len=8):
D (3054) wpa: 00 00 00 00 00 00 00 00
D (3054) wpa: RSN: received GTK in pairwise handshake - hexdump(len=18):
D (3064) wpa: 02 00 51 37 6b 22 3f ad 16 07 ce 3a be f6 01 e7
D (3064) wpa: 62 2e
D (3074) wpa: tx 4/4 txcb_flags=8192
D (3074) wpa: WPA Send EAPOL-Key 4/4
D (3074) wpa: WPA: KCK - hexdump(len=16):
D (3084) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (3084) wpa: WPA: Derived Key MIC - hexdump(len=16):
D (3094) wpa: fe 96 e9 ae 07 79 cd 75 a4 89 06 e4 af 70 44 09
V (3094) wpa: WPA: TX EAPOL-Key - hexdump(len=99):
V (3104) wpa: 01 03 00 5f 02 03 0a 00 00 00 00 00 00 00 00 00
V (3114) wpa: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3114) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3124) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3134) wpa: 00 fe 96 e9 ae 07 79 cd 75 a4 89 06 e4 af 70 44
V (3144) wpa: 09 00 00
V (3144) wifi:wpa_psk handle succeed
D (3144) wpa: 2/4 txcb, flags=8192, txfail 0
V (3154) wifi:wpa_psk start
D (3154) wpa: IEEE 802.1X RX: version=2 type=3 length=151
V (3154) wpa: WPA: RX EAPOL-Key - hexdump(len=155):
V (3164) wpa: 02 03 00 97 02 13 ca 00 10 00 00 00 00 00 00 00
V (3164) wpa: 04 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f
V (3174) wpa: 98 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24
V (3184) wpa: a8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3184) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3194) wpa: 00 2a b1 f9 ab 37 ec fa 2d 18 8b 7f 06 c4 9c b3
V (3194) wpa: 37 00 38 43 e5 12 ae be 0b bf 5d 5d 8e 03 0a 29
V (3204) wpa: 42 ab eb c1 1f b0 b2 90 4b f8 00 3f 0b b9 28 4d
V (3214) wpa: 49 5f a3 8f 24 a1 47 28 27 5b 5c 3f 9c c8 06 49
V (3214) wpa: 52 9e 12 91 b7 18 2b 63 8c c6 98
D (3224) wpa: EAPOL-Key type=2
D (3224) wpa: key_info 0x13ca (ver=2 keyidx=0 rsvd=0 Pairwise Install Ack MIC Secure Encr)
D (3234) wpa: key_length=16 key_data_length=56
D (3234) wpa: replay_counter - hexdump(len=8):
D (3244) wpa: 00 00 00 00 00 00 00 04
D (3244) wpa: key_nonce - hexdump(len=32):
D (3254) wpa: 43 89 63 b3 c4 64 2c 5d 9c 90 4f 97 11 4f 3f 98
D (3254) wpa: 82 6f 7e 6e d9 d8 82 ce e1 49 9d a8 16 1e 24 a8
D (3264) wpa: key_iv - hexdump(len=16):
D (3264) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (3274) wpa: key_rsc - hexdump(len=8):
D (3274) wpa: 00 00 00 00 00 00 00 00
D (3274) wpa: key_id (reserved) - hexdump(len=8):
D (3284) wpa: 00 00 00 00 00 00 00 00
D (3284) wpa: key_mic - hexdump(len=16):
D (3294) wpa: 2a b1 f9 ab 37 ec fa 2d 18 8b 7f 06 c4 9c b3 37
D (3294) wpa: RSN: encrypted key data - hexdump(len=56):
D (3304) wpa: 43 e5 12 ae be 0b bf 5d 5d 8e 03 0a 29 42 ab eb
D (3314) wpa: c1 1f b0 b2 90 4b f8 00 3f 0b b9 28 4d 49 5f a3
D (3314) wpa: 8f 24 a1 47 28 27 5b 5c 3f 9c c8 06 49 52 9e 12
D (3324) wpa: 91 b7 18 2b 63 8c c6 98
D (3324) wpa: WPA: decrypted EAPOL-Key key data - hexdump(len=48):
D (3334) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (3334) wpa: 00 0f ac 02 0c 00 dd 16 00 0f ac 01 02 00 51 37
D (3344) wpa: 6b 22 3f ad 16 07 ce 3a be f6 01 e7 62 2e dd 00
D (3344) wpa: WPA 3/4-Way Handshake
D (3354) wpa: WPA: RSN IE in EAPOL-Key - hexdump(len=22):
D (3354) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (3364) wpa: 00 0f ac 02 0c 00
D (3364) wpa: WPA: GTK in EAPOL-Key - hexdump(len=24):
D (3374) wpa: dd 16 00 0f ac 01 02 00 51 37 6b 22 3f ad 16 07
D (3374) wpa: ce 3a be f6 01 e7 62 2e
D (3384) wpa: WPA: IE KeyData - hexdump(len=48):
D (3384) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (3394) wpa: 00 0f ac 02 0c 00 dd 16 00 0f ac 01 02 00 51 37
D (3394) wpa: 6b 22 3f ad 16 07 ce 3a be f6 01 e7 62 2e dd 00
D (3404) wpa: WPA: RSC - hexdump(len=8):
D (3404) wpa: 00 00 00 00 00 00 00 00
D (3414) wpa: RSN: received GTK in pairwise handshake - hexdump(len=18):
D (3414) wpa: 02 00 51 37 6b 22 3f ad 16 07 ce 3a be f6 01 e7
D (3424) wpa: 62 2e
D (3424) wpa: tx 4/4 txcb_flags=8192
D (3434) wpa: WPA Send EAPOL-Key 4/4
D (3434) wpa: WPA: KCK - hexdump(len=16):
D (3434) wpa: 24 e3 69 46 aa 90 27 57 eb 25 4d 47 b2 35 4f 08
D (3444) wpa: WPA: Derived Key MIC - hexdump(len=16):
D (3454) wpa: eb c6 d3 c6 a7 16 e9 3b da 6c 50 7d c0 ba f1 12
V (3454) wpa: WPA: TX EAPOL-Key - hexdump(len=99):
V (3464) wpa: 01 03 00 5f 02 03 0a 00 00 00 00 00 00 00 00 00
V (3464) wpa: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3474) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3484) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (3494) wpa: 00 eb c6 d3 c6 a7 16 e9 3b da 6c 50 7d c0 ba f1
V (3494) wpa: 12 00 00
V (3494) wifi:wpa_psk handle succeed
V (3504) wifi:sta recv dup seq=48 tid=6, discard
D (3504) wpa: WPA: Installing PTK to the driver.
D (3514) wpa: WPA: Group Key - hexdump(len=16):
D (3514) wpa: 51 37 6b 22 3f ad 16 07 ce 3a be f6 01 e7 62 2e
D (3524) wpa: WPA: Judge GTK: (keyidx=2 len=16).
D (3524) wpa: WPA: Installing GTK to the driver (keyidx=2 tx=0 len=16).
D (3534) wpa: WPA: RSC - hexdump(len=6):
D (3534) wpa: 00 00 00 00 00 00
D (3544) wpa: WPA: Key negotiation completed with 42:94:ed:58:4a:49 [PTK=CCMP GTK=CCMP]
I (3544) wifi:connected with NEXSENS_GUEST, aid = 1, channel 3, BW20, bssid = 42:94:ed:58:4a:49
I (3554) wifi:security: WPA2-PSK, phy: bgn, rssi: -62
D (3564) wifi:remove all except 42:94:ed:58:4a:49 from rc list
D (3564) wifi:clear blacklist
D (3574) nvs: nvs_set sta.chan 1 3
D (3574) nvs: nvs_set_blob sta.apinfo 700
D (3584) wifi:filter: set rx policy=7
I (3584) wifi:pm start, type: 1
I (3584) wifi:dp: 1, bi: 102400, li: 3, scale listen interval from 307200 us to 307200 us
I (3594) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000
D (3604) wifi:Send sta connected event
D (3604) wifi:connect status 1 -> 5
D (3604) wifi:obss scan is disabled
D (3614) wifi:start obss scan: obss scan is stopped
D (3614) event: running post WIFI_EVENT:4 with handler 0x42013854 and context 0x3fca7584 on loop 0x3fca6400
V (3624) esp_adapter: thread sem get: sem=0x3fcb06d4
I (3624) wifi:AP's beacon interval = 102400 us, DTIM period = 3
D (3634) wifi:set max rate: from <rate=130, phy=3, sig=0> to <rate=144, phy=3 sig=0>
D (3644) wifi:sig_b=0, sig_g=0, sig_n=0, max_b=22, max_g=108, max_n=144
D (3644) wifi:update trc
D (3654) esp_netif_handlers: esp_netif action connected with netif0x3fca7328 from event_id=4
D (3654) esp_netif_lwip: check: remote, if=0x3fca7328 fn=0x42011320
D (3664) esp_netif_lwip: esp_netif_up_api esp_netif:0x3fca7328
D (3674) esp_netif_lwip: check: local, if=0x3fca7328 fn=0x420116f0
D (3674) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fca7328
V (3684) esp_netif_lwip: esp_netif_is_netif_up esp_netif:0x3fca7328
D (3694) esp_netif_lwip: call api in lwip: ret=0x0, give sem
D (3694) esp_netif_lwip: check: remote, if=0x3fca7328 fn=0x420111dc
D (3704) esp_netif_lwip: esp_netif_dhcpc_start_api esp_netif:0x3fca7328
D (3714) esp_netif_lwip: esp_netif_start_ip_lost_timer esp_netif:0x3fca7328
D (3714) esp_netif_lwip: if0x3fca7328 start ip lost tmr: no need start because netif=0x3fca73ac interval=120 ip=0
D (3724) esp_netif_lwip: starting dhcp client
D (3734) esp_netif_lwip: call api in lwip: ret=0x0, give sem
D (3734) wifi:eb is dhcp or dns sport = 68, dport = 67
D (3744) event: running post WIFI_EVENT:4 with handler 0x42009640 and context 0x3fcaffcc on loop 0x3fca6400
D (4234) wifi:eb is dhcp or dns sport = 68, dport = 67
I (4854) wifi:<ba-add>idx:0 (ifx:0, 42:94:ed:58:4a:49), tid:0, ssn:0, winSize:64
D (4864) wifi:eb is dhcp or dns sport = 68, dport = 67
D (5234) wifi:eb is dhcp or dns sport = 68, dport = 67
D (6234) esp_netif_lwip: esp_netif_internal_dhcpc_cb lwip-netif:0x3fca73ac
D (6234) esp_netif_lwip: if0x3fca7328 ip changed=1
D (6234) event: running post IP_EVENT:0 with handler 0x42013678 and context 0x3fca7658 on loop 0x3fca6400
D (6244) wifi_init_default: Got IP wifi default handler entered
D (6244) esp_netif_handlers: esp_netif action got_ip with netif0x3fca7328 from event_id=0
I (6254) esp_netif_handlers: sta ip: 192.168.2.6, mask: 255.255.255.0, gw: 192.168.2.1
D (6264) event: running post IP_EVENT:0 with handler 0x42009640 and context 0x3fcaffec on loop 0x3fca6400
I (6274) wifi station: got ip:192.168.2.6
I (6274) wifi station: connected to ap SSID:NEXSENS_GUEST password:mypassword
I (6284) main_task: Returned from app_main()
```Failure logs from my application
N2912703D (17:33:06.447) esp_netif_lwip: LwIP stack has been initialized
D (17:33:06.447) esp_netif_lwip: esp-netif has been successfully initialized
D (17:33:06.448) event: running task for loop 0x3fcda380
D (17:33:06.448) event: created task for loop 0x3fcda380
D (17:33:06.448) event: created event loop 0x3fcda380
D (17:33:06.449) esp_netif_lwip: check: remote, if=0x3fcca208 fn=0x4205d72c
V (17:33:06.449) esp_netif_objects: esp_netif_add_to_list_unsafe 0x3fce2edc
D (17:33:06.450) esp_netif_objects: esp_netif_add_to_list_unsafe netif added successfully (total netifs: 1)
D (17:33:06.450) esp_netif_lwip: call api in lwip: ret=0x0, give sem
I (17:33:06.451) pp: pp rom version: e7ae62f
I (17:33:06.452) net80211: net80211 rom version: e7ae62f
D (17:33:06.452) nvs: nvs_open_from_partition misc 1
I (59825) wifi:wifi driver task: 3fce5988, prio:23, stack:6656, core=0
V (17:33:06.454) esp_adapter: thread sem create: sem=0x3fce5aec
V (17:33:06.454) esp_adapter: thread sem get: sem=0x3fce5aec
D (17:33:06.455) nvs: nvs_open_from_partition nvs.net80211 1
D (17:33:06.456) nvs: nvs_get opmode 1
D (17:33:06.457) nvs: nvs_get_str_or_blob sta.ssid
D (17:33:06.457) nvs: nvs_get sta.authmode 1
D (17:33:06.458) nvs: nvs_get_str_or_blob sta.pswd
D (17:33:06.458) nvs: nvs_get_str_or_blob sta.pmk
D (17:33:06.458) nvs: nvs_get sta.chan 1
D (17:33:06.459) nvs: nvs_get auto.conn 1
D (17:33:06.459) nvs: nvs_get bssid.set 1
D (17:33:06.460) nvs: nvs_get_str_or_blob sta.bssid
D (17:33:06.460) nvs: nvs_get sta.lis_intval 2
D (17:33:06.460) nvs: nvs_get sta.phym 1
D (17:33:06.461) nvs: nvs_get sta.phybw 1
D (17:33:06.461) nvs: nvs_get_str_or_blob sta.apsw
D (17:33:06.461) nvs: nvs_get_str_or_blob sta.apinfo
D (17:33:06.462) nvs: nvs_get sta.scan_method 1
D (17:33:06.463) nvs: nvs_get sta.sort_method 1
D (17:33:06.463) nvs: nvs_get sta.minrssi 1
D (17:33:06.463) nvs: nvs_get sta.minauth 1
D (17:33:06.464) nvs: nvs_get sta.pmf_e 1
D (17:33:06.464) nvs: nvs_get sta.pmf_r 1
D (17:33:06.464) nvs: nvs_get sta.btm_e 1
D (17:33:06.465) nvs: nvs_get sta.rrm_e 1
D (17:33:06.465) nvs: nvs_get sta.mbo_e 1
D (17:33:06.465) nvs: nvs_get_str_or_blob ap.ssid
D (17:33:06.466) nvs: nvs_get_str_or_blob ap.passwd
D (17:33:06.466) nvs: nvs_get_str_or_blob ap.pmk
D (17:33:06.466) nvs: nvs_get ap.chan 1
D (17:33:06.467) nvs: nvs_get ap.authmode 1
D (17:33:06.467) nvs: nvs_get ap.hidden 1
D (17:33:06.467) nvs: nvs_get ap.max.conn 1
D (17:33:06.467) nvs: nvs_get bcn.interval 2
D (17:33:06.468) nvs: nvs_get ap.phym 1
D (17:33:06.468) nvs: nvs_get ap.phybw 1
D (17:33:06.468) nvs: nvs_get ap.sndchan 1
D (17:33:06.468) nvs: nvs_get ap.pmf_e 1
D (17:33:06.469) nvs: nvs_get ap.pmf_r 1
D (17:33:06.469) nvs: nvs_get ap.p_cipher 1
D (17:33:06.469) nvs: nvs_get lorate 1
D (17:33:06.469) nvs: nvs_get_str_or_blob country
D (17:33:06.470) nvs: nvs_get ap.ftm_r 1
D (17:33:06.470) nvs: nvs_get sta.ft 1
D (17:33:06.470) nvs: nvs_get sta.owe 1
D (17:33:06.471) nvs: nvs_get sta.trans_d 1
D (17:33:06.471) nvs: nvs_get sta.sae_h2e 1
D (17:33:06.471) nvs: nvs_get sta.sae_pk_mode 1
D (17:33:06.472) nvs: nvs_get sta.bss_retry 1
D (17:33:06.472) nvs: nvs_get_str_or_blob sta.owe_data
D (17:33:06.472) nvs: nvs_get sta.he_dcm 1
D (17:33:06.473) nvs: nvs_get sta.he_dcm_c_tx 1
D (17:33:06.473) nvs: nvs_get sta.he_dcm_c_rx 1
D (17:33:06.473) nvs: nvs_get sta.he_mcs9_d 1
D (17:33:06.473) nvs: nvs_get sta.he_su_b_d 1
D (17:33:06.474) nvs: nvs_get sta.he_su_b_f_d 1
D (17:33:06.474) nvs: nvs_get sta.he_mu_b_f_d 1
D (17:33:06.474) nvs: nvs_get sta.he_cqi_f_d 1
D (17:33:06.474) nvs: nvs_get_str_or_blob sta.sae_h2e_id
D (17:33:06.475) nvs: nvs_get ap.sae_h2e 1
D (17:33:06.475) nvs: nvs_get_str_or_blob ap.pmk_info
D (17:33:06.475) nvs: nvs_get nan.phym 1
D (17:33:06.476) nvs: nvs_set ap.sndchan 1 1
I (59848) wifi:wifi firmware version: 3ce09e5
I (59848) wifi:wifi certification version: v7.0
I (59848) wifi:config NVS flash: enabled
I (59848) wifi:config nano formating: disabled
I (59848) wifi:Init data frame dynamic rx buffer num: 32
I (59849) wifi:Init static rx mgmt buffer num: 5
I (59849) wifi:Init management short buffer num: 32
I (59849) wifi:Init static tx buffer num: 8
I (59850) wifi:Init tx cache buffer num: 32
I (59850) wifi:Init static tx FG buffer num: 2
I (59850) wifi:Init static rx buffer size: 2212
I (59851) wifi:Init static rx buffer num: 8
I (59851) wifi:Init dynamic rx buffer num: 32
V (59851) wifi:hint=255, act_dur=<0,120>, pas_dur=360, nchans=14 history_num=0
V (17:33:06.481) esp_adapter: thread sem get: sem=0x3fce5aec
I (17:33:06.482) wifi_init: rx ba win: 16
I (17:33:06.482) wifi_init: tcpip mbox: 32
I (17:33:06.482) wifi_init: udp mbox: 6
I (17:33:06.483) wifi_init: tcp mbox: 6
I (17:33:06.483) wifi_init: tcp tx win: 5744
I (17:33:06.483) wifi_init: tcp rx win: 5744
I (17:33:06.483) wifi_init: tcp mss: 1436
I (17:33:06.484) wifi_init: WiFi/LWIP prefer SPIRAM
V (17:33:06.484) esp_adapter: thread sem get: sem=0x3fce5aec
D (17:33:06.484) nvs: nvs_get opmode 1
V (17:33:06.485) esp_adapter: thread sem get: sem=0x3fce5aec
D (59857) wifi:clear blacklist
D (17:33:06.486) nvs: nvs_set_blob sta.ssid 36
D (17:33:06.490) nvs: nvs_set_blob sta.pswd 65
D (17:33:06.491) nvs: nvs_set bssid.set 1 0
D (17:33:06.492) nvs: nvs_set sta.lis_intval 2 3
D (17:33:06.492) nvs: nvs_set sta.chan 1 0
D (17:33:06.493) nvs: nvs_set sta.scan_method 1 0
D (17:33:06.493) nvs: nvs_set sta.sort_method 1 0
D (17:33:06.494) nvs: nvs_set sta.minrssi 1 -127
D (17:33:06.494) nvs: nvs_set sta.minauth 1 3
D (17:33:06.495) nvs: nvs_set_blob sta.apsw 2
D (17:33:06.497) nvs: nvs_set sta.pmf_e 1 1
D (17:33:06.497) nvs: nvs_set sta.pmf_r 1 0
D (17:33:06.498) nvs: nvs_set sta.rrm_e 1 0
D (17:33:06.498) nvs: nvs_set sta.btm_e 1 0
D (17:33:06.499) nvs: nvs_set sta.mbo_e 1 0
D (17:33:06.499) nvs: nvs_set sta.ft 1 0
D (17:33:06.500) nvs: nvs_set sta.owe 1 0
D (17:33:06.500) nvs: nvs_set sta.bss_retry 1 0
D (17:33:06.500) nvs: nvs_set sta.trans_d 1 0
D (17:33:06.501) nvs: nvs_set sta.sae_h2e 1 2
D (17:33:06.501) nvs: nvs_set sta.sae_pk_mode 1 0
D (17:33:06.502) nvs: nvs_set_blob sta.sae_h2e_id 32
D (17:33:06.502) nvs: nvs_set_blob sta.apinfo 700
V (17:33:06.503) esp_adapter: thread sem get: sem=0x3fce5aec
V (59875) wifi:ht20 freq=2412, chan=1
D (59876) wifi:filter: set rx policy=0
I (59877) wifi:mode : sta (68:b6:b3:35:d6:4c)
I (59878) wifi:enable tsf
D (59878) wifi:filter: set rx policy=1
D (59878) wifi:connect status 0 -> 0
D (17:33:06.508) event: running post WIFI_EVENT:2 with handler 0x4205ff20 and context 0x3fcd7248 on loop 0x3fcda380
D (17:33:06.508) wifi_init_default: wifi_start esp-netif:0x3fce2edc event-id2
D (17:33:06.509) wifi_init_default: WIFI mac address: 68 b6 b3 35 d6 4c
V (17:33:06.509) esp_adapter: thread sem create: sem=0x3fcee43c
V (17:33:06.510) esp_adapter: thread sem get: sem=0x3fcee43c
D (17:33:06.510) esp_netif_lwip: check: remote, if=0x3fce2edc fn=0x4205ce54
D (17:33:06.511) esp_netif_lwip: call api in lwip: ret=0x0, give sem
D (17:33:06.511) esp_netif_handlers: esp_netif action has started with netif0x3fce2edc from event_id=2
D (17:33:06.512) esp_netif_lwip: check: remote, if=0x3fce2edc fn=0x4205d9bc
D (17:33:06.512) esp_netif_lwip: esp_netif_start_api 0x3fce2edc
D (17:33:06.513) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3fce2edc
D (17:33:06.513) esp_netif_lwip: check: local, if=0x3fce2edc fn=0x4205df7c
D (17:33:06.514) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3fce2edc
V (17:33:06.514) esp_netif_lwip: esp_netif_is_netif_up esp_netif:0x3fce2edc
D (17:33:06.515) esp_netif_lwip: call api in lwip: ret=0x0, give sem
D (17:33:06.515) event: running post WIFI_EVENT:2 with handler 0x42021584 and context 0x3fce3f60 on loop 0x3fcda380
V (17:33:06.516) esp_adapter: thread sem get: sem=0x3fcee43c
D (59887) wifi:Start wifi connect
D (59887) wifi:connect status 0 -> 0
D (59887) wifi:connect chan=0
V (59888) wifi:nvs=0, ssid=NEXSENS_GUEST, channel=3
V (59888) wifi:ssid=NEXSENS_GUEST match nvs 0, channel=3
D (59888) wifi:first chan=3
D (59888) wifi:connect status 0 -> 1
D (59888) wifi:filter: set rx policy=3
D (59888) wifi:clear scan ap list
D (59889) wifi:start scan: type=0x50f, priority=2, cb=0x42083efc, arg=0x0, ss_state=0x1, time=59890600, index=0
V (59889) wifi:inter_channel_timeout: arg=0x0, ss_state=0x1
D (59889) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
V (59890) wifi:change: chan<3,0>, dur<0,240>
V (59890) wifi:ht20 freq=2422, chan=3
V (59891) wifi:enter start op, arg=0x3fcaadaa
V (59891) wifi:scan operation: state=0x3, chan<3,0>, arg=0x3fcaadaa, status=0
V (59891) wifi:scan specific ssid=NEXSENS_GUEST
V (59891) wifi:start max timer
wifi_init_sta finished.D (59905) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
V (59906) wifi:updated connection retries to 0
D (17:33:06.535) wpa: rsn_ie - hexdump(len=22):
D (17:33:06.536) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (17:33:06.537) wpa: 00 0f ac 02 0c 00
D (59908) wifi:profile match: ss_state=0x7
V (59908) wifi:scan histroy table is not full yet, add
V (59908) wifi:add ssid=NEXSENS_GUEST, chan=3 to scan history
D (59909) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
V (59910) wifi:updated connection retries to 0
D (17:33:06.539) wpa: rsn_ie - hexdump(len=22):
D (17:33:06.540) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
D (17:33:06.540) wpa: 00 0f ac 02 0c 00
D (59912) wifi:profile match: ss_state=0x7
V (59912) wifi:update scan history ssid=NEXSENS_GUEST, channel=3
D (59912) wifi:scan end: arg=0x0, status=0, ss_state=0x7
D (59913) wifi:find first mathched ssid, scan done
V (59913) wifi:back home chan=<1,0>, current chan=<3,0>
V (59913) wifi:ht20 freq=2412, chan=1
D (59914) wifi:filter: set rx policy=4
D (59914) wifi:first chan=1
V (59914) wifi:scan_done: arg=0x0, status=0, cur_time=59916271, scan_id=128, scan state=0
V (59915) wifi:call scan_done cb, arg=0x0
D (59915) wifi:handoff_cb: status=0
V (59915) wifi:best bss has set.
D (59915) wifi:ap found, mac=42:94:ed:58:4a:49
V (59915) wifi:bssid=42:94:ed:58:4a:49, LR=0
D (59916) wifi:new_bss=0x3fcab0a8, cur_bss=0x0, new_chan=<3,0>, cur_chan=1
D (59916) wifi:filter: set rx policy=5
D (17:33:06.545) wpa: WPA: set AP RSNXE - hexdump(len=0):
I (59917) wifi:new:<3,0>, old:<1,0>, ap:<255,255>, sta:<3,0>, prof:1
V (59917) wifi:ht20 freq=2422, chan=3
D (59917) wifi:connect_op: status=0, auth=5, cipher=3
D (59918) wifi:auth mode is not none
D (59918) wifi:connect_bss: auth=1, reconnect=0
I (59919) wifi:state: init -> auth (b0)
D (59919) wifi:start 1s AUTH timer
D (59920) wifi:clear scan ap list
D (59928) wifi:recv auth: seq=2, status=0
I (59928) wifi:state: auth -> assoc (0)
D (59929) wifi:restart connect 1s timer for assoc
D (59940) wifi:recv assoc: type=0x10
D (59941) wifi:filter: set rx policy=6
I (59941) wifi:state: assoc -> run (10)
D (59942) wifi:start 10s connect timer for 4 way handshake
D (17:33:06.571) wpa: WPA: Association event - clear replay counter
D (17:33:06.572) wpa: WPA: Clear old PTK
V (59957) wifi:wpa_psk start
D (17:33:06.587) wpa: IEEE 802.1X RX: version=2 type=3 length=95
V (17:33:06.587) wpa: WPA: RX EAPOL-Key - hexdump(len=99):
V (17:33:06.588) wpa: 02 03 00 5f 02 00 8a 00 10 00 00 00 00 00 00 00
V (17:33:06.588) wpa: 01 24 00 94 dc 12 aa 3b a0 e0 ea 81 c8 e2 dc cb
V (17:33:06.588) wpa: ac ae 28 e4 3a ae d5 47 6f 8e be d6 a9 93 a9 bc
V (17:33:06.589) wpa: c5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (17:33:06.589) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (17:33:06.590) wpa: 00 00 00
D (17:33:06.590) wpa: EAPOL-Key type=2
D (17:33:06.590) wpa: key_info 0x8a (ver=2 keyidx=0 rsvd=0 Pairwise Ack)
D (17:33:06.591) wpa: key_length=16 key_data_length=0
D (17:33:06.591) wpa: replay_counter - hexdump(len=8):
D (17:33:06.591) wpa: 00 00 00 00 00 00 00 01
D (17:33:06.591) wpa: key_nonce - hexdump(len=32):
D (17:33:06.592) wpa: 24 00 94 dc 12 aa 3b a0 e0 ea 81 c8 e2 dc cb ac
D (17:33:06.592) wpa: ae 28 e4 3a ae d5 47 6f 8e be d6 a9 93 a9 bc c5
D (17:33:06.592) wpa: key_iv - hexdump(len=16):
D (17:33:06.593) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (17:33:06.593) wpa: key_rsc - hexdump(len=8):
D (17:33:06.593) wpa: key_id (reserved) - hexdump(len=8):
D (17:33:06.594) wpa: 00 00 00 00 00 00 00 00
D (17:33:06.594) wpa: key_mic - hexdump(len=16):
D (17:33:06.594) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (17:33:06.594) wpa: WPA 1/4-Way Handshake
D (17:33:06.595) wpa: RSN: msg 1/4 key data - hexdump(len=0):
D (17:33:06.595) wpa: WPA: Renewed SNonce - hexdump(len=32):
D (17:33:06.595) wpa: f4 e1 1d a1 be 90 3e f3 98 d5 8b 48 e9 1b d9 06
D (17:33:06.596) wpa: 93 d7 21 b6 43 6a ee df ec 5e e0 4d c1 de d9 0c
D (17:33:06.596) gdma: new pair (0,1) at 0x3c141180
D (17:33:06.597) gdma: new tx channel (0,1) at 0x3c141140
D (17:33:06.597) gdma: new rx channel (0,1) at 0x3c1411ac
D (17:33:06.598) gdma: tx channel (0,1), (1:32) bytes aligned, burst enabled
D (17:33:06.598) gdma: rx channel (0,1), (1:32) bytes aligned, burst disabled
D (17:33:06.599) wpa: WPA: PTK derivation - A1=68:b6:b3:35:d6:4c A2=42:94:ed:58:4a:49
V (17:33:06.600) wpa: WPA: PMK - hexdump(len=32):
V (17:33:06.600) wpa: c5 5c 4b 2d af 33 f4 2d 54 e2 d2 08 51 da 4e c0
V (17:33:06.601) wpa: c1 23 c8 e1 b8 3c c0 f8 9e 83 de 3c 55 14 5f 76
D (17:33:06.601) wpa: WPA: PTK - hexdump(len=48):
D (17:33:06.601) wpa: 85 fb af 37 fc 83 83 7f 4f 7d cc df 1e a2 2a e8
D (17:33:06.602) wpa: 52 20 b1 a4 18 eb af b3 5a b4 b0 1c 77 59 73 80
D (17:33:06.602) wpa: 62 e2 28 c8 aa 17 cf 4b fc 37 d2 7e f6 e0 92 17
D (17:33:06.602) wpa: WPA: KCK - hexdump(len=16):
D (17:33:06.603) wpa: 85 fb af 37 fc 83 83 7f 4f 7d cc df 1e a2 2a e8
D (17:33:06.603) wpa: WPA: KEK - hexdump(len=16):
D (17:33:06.603) wpa: 52 20 b1 a4 18 eb af b3 5a b4 b0 1c 77 59 73 80
D (17:33:06.603) wpa: WPA: TK - hexdump(len=16):
D (17:33:06.604) wpa: 62 e2 28 c8 aa 17 cf 4b fc 37 d2 7e f6 e0 92 17
V (17:33:06.604) wpa: WPA: WPA IE for msg 2/4
- hexdump(len=22):
V (17:33:06.604) wpa: 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00
V (17:33:06.605) wpa: 00 0f ac 02 00 04
D (17:33:06.605) wpa: WPA Send EAPOL-Key 2/4
D (17:33:06.606) wpa: WPA: KCK - hexdump(len=16):
D (17:33:06.606) wpa: 85 fb af 37 fc 83 83 7f 4f 7d cc df 1e a2 2a e8
D (17:33:06.606) wpa: WPA: Derived Key MIC - hexdump(len=16):
D (17:33:06.607) wpa: 73 fe 8b 47 d8 26 c0 95 28 24 21 ec 69 93 f3 c8
V (17:33:06.607) wpa: WPA: TX EAPOL-Key - hexdump(len=121):
V (17:33:06.607) wpa: 01 03 00 75 02 01 0a 00 00 00 00 00 00 00 00 00
V (17:33:06.608) wpa: 01 f4 e1 1d a1 be 90 3e f3 98 d5 8b 48 e9 1b d9
V (17:33:06.608) wpa: 06 93 d7 21 b6 43 6a ee df ec 5e e0 4d c1 de d9
V (17:33:06.608) wpa: 0c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (17:33:06.609) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (17:33:06.609) wpa: 00 73 fe 8b 47 d8 26 c0 95 28 24 21 ec 69 93 f3
V (17:33:06.609) wpa: c8 00 16 30 14 01 00 00 0f ac 04 01 00 00 0f ac
V (17:33:06.610) wpa: 04 01 00 00 0f ac 02 00 04
V (59981) wifi:wpa_psk handle succeed
V (59981) wifi:tx process: alloc static tx buf, pb=0x0 l=135 hdr=0 data=135
D (17:33:06.611) wpa: 2/4 txcb, flags=0, txfail 0
V (59987) wifi:wpa_psk start
D (17:33:06.616) wpa: IEEE 802.1X RX: version=2 type=3 length=151
V (17:33:06.617) wpa: WPA: RX EAPOL-Key - hexdump(len=155):
V (17:33:06.617) wpa: 02 03 00 97 02 13 ca 00 10 00 00 00 00 00 00 00
V (17:33:06.617) wpa: 02 24 00 94 dc 12 aa 3b a0 e0 ea 81 c8 e2 dc cb
V (17:33:06.618) wpa: ac ae 28 e4 3a ae d5 47 6f 8e be d6 a9 93 a9 bc
V (17:33:06.618) wpa: c5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (17:33:06.618) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
V (17:33:06.619) wpa: 00 6a 60 46 ee 3e e2 4d e8 88 69 ed cd a9 c7 e8
V (17:33:06.619) wpa: 46 00 38 b8 7b d3 11 88 32 a3 55 19 9b 49 a4 a3
V (17:33:06.619) wpa: 99 0f 37 76 0b ba 67 e1 5e 28 1d 06 08 ba 29 ef
V (17:33:06.619) wpa: e0 5a f5 d6 62 f2 b7 23 02 f0 37 5d ba b6 fb 98
V (17:33:06.620) wpa: c7 93 7a 7c 7e 8d f8 4a 35 aa 27
D (17:33:06.621) wpa: EAPOL-Key type=2
D (17:33:06.621) wpa: key_info 0x13ca (ver=2 keyidx=0 rsvd=0 Pairwise Install Ack MIC Secure Encr)
D (17:33:06.622) wpa: key_length=16 key_data_length=56
D (17:33:06.622) wpa: replay_counter - hexdump(len=8):
D (17:33:06.622) wpa: 00 00 00 00 00 00 00 02
D (17:33:06.623) wpa: key_nonce - hexdump(len=32):
D (17:33:06.623) wpa: 24 00 94 dc 12 aa 3b a0 e0 ea 81 c8 e2 dc cb ac
D (17:33:06.623) wpa: ae 28 e4 3a ae d5 47 6f 8e be d6 a9 93 a9 bc c5
D (17:33:06.623) wpa: key_iv - hexdump(len=16):
D (17:33:06.624) wpa: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D (17:33:06.624) wpa: key_rsc - hexdump(len=8):
D (17:33:06.624) wpa: key_id (reserved) - hexdump(len=8):
D (17:33:06.625) wpa: 00 00 00 00 00 00 00 00
D (17:33:06.625) wpa: key_mic - hexdump(len=16):
D (17:33:06.625) wpa: 6a 60 46 ee 3e e2 4d e8 88 69 ed cd a9 c7 e8 46
D (17:33:06.625) wpa: RSN: encrypted key data - hexdump(len=56):
D (17:33:06.626) wpa: b8 7b d3 11 88 32 a3 55 19 9b 49 a4 a3 99 0f 37
D (17:33:06.626) wpa: 76 0b ba 67 e1 5e 28 1d 06 08 ba 29 ef e0 5a f5
D (17:33:06.626) wpa: d6 62 f2 b7 23 02 f0 37 5d ba b6 fb 98 c7 93 7a
D (17:33:06.627) wpa: 7c 7e 8d f8 4a 35 aa 27
V (59998) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (59998) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
E
abort() was called at PC 0x42067d44 on core 0
Backtrace: 0x40375992:0x3fce54b0 0x4038161d:0x3fce54d0 0x40386a7d:0x3fce54f0 0x42067d44:0x3fce5570 0x42067863:0x3fce5590 0x4205e492:0x3fce55b0 0x4205e5ad:0x3fce55d0 0x4205ea1f:0x3fce55f0 0x420ad6ed:0x3fce5640 0x420d9c01:0x3fce5740 0x420dafba:0x3fce5770 0x420db135:0x3fce57c0 0x420dc831:0x3fce57e0 0x420d9497:0x3fce5800
ELF file SHA256: 8ea9da0af6752613
Rebooting...
ESP-ROM:esp32s3-20210327
