gemini post returns response 200, but the result is empty
vigyanabikshu
Postby vigyanabikshu » Tue Feb 04, 2025 3:19 pm
I am trying to get response from gemini. post returns response 200, but the result is empty!. ca_certificate problem ?
// Send HTTP POST request to the Gemini API
void send_gemini_request(void) {
char question[200] = "What is Todays Significance?";
ESP_LOGI(TAG, "Asking Your Question: %s", question);
esp_http_client_config_t config = {
.url = "https://generativelanguage.googleapis.c ... ntent?key=" GEMINI_API_KEY,
.method = HTTP_METHOD_POST,
.cert_pem = postman_root_cert_pem_start, // Add server certificate if required
.buffer_size = 2048, // Increase buffer size if needed
.disable_auto_redirect = false,
.keep_alive_enable = true,
.user_agent = "ESP32",
ESP_LOGI(TAG, "URL: %s", config.url);
// Prepare the payload
// char payload[512];
const char *payload = "{"
"\"contents\": [{"
"\"parts\": [{"
"\"text\": \"What is Todays Significance?\""
"\"generationConfig\": {"
"\"maxOutputTokens\": 800"
//snprintf(payload, sizeof(payload), "{\"contents\": [{\"parts\":[{\"text\":%s}]}],\"generationConfig\": {\"maxOutputTokens\": %s}}", question, GEMINI_MAX_TOKENS);
ESP_LOGI(TAG, "Payload: %s", payload);
// Set headers
esp_http_client_set_header(client, "Content-Type", "application/json");
esp_http_client_set_header(client, "Authorization", GEMINI_API_KEY);
esp_http_client_set_method(client, HTTP_METHOD_POST);
// Send the request
esp_http_client_set_post_field(client, payload, strlen(payload));
esp_err_t err = esp_http_client_perform(client);
if (err == ESP_OK) {
int status_code = esp_http_client_get_status_code(client);
ESP_LOGI(TAG, "Status Code: %d", status_code);
if (status_code == 200) {
long contentlength = esp_http_client_get_content_length(client);
ESP_LOGI(TAG, "Received Content Length: %ld", contentlength);
if(contentlength>0){
char* response = malloc(contentlength + 1);
esp_http_client_read(client, response, esp_http_client_get_content_length(client));
response[esp_http_client_get_content_length(client)] = '\0';
ESP_LOGI(TAG, "response: %s", payload);
ESP_LOGE(TAG, "HTTP request failed with status code: %d", status_code);
ESP_LOGE(TAG, "HTTP request failed: %s", esp_err_to_name(err));
esp_http_client_cleanup(client);
I (12184) mbedtls: ssl_msg.c:4206 <= read record
I (12194) mbedtls: ssl_msg.c:5867 <= read
I (12204) GEMINI_EXAMPLE: Status Code: 200
I (12204) GEMINI_EXAMPLE: Received Content Length: -1
I (12214) GEMINI_EXAMPLE: response: {"contents": [{"parts": [{"text": "What is Todays Significance?"}]}],"generationConfig": {"maxOutputTokens": 800}}
MicroController
Re: gemini post returns response 200, but the result is empty
Postby MicroController » Tue Feb 04, 2025 6:10 pm
esp_http_client_get_content_length()
Returns:
(-1) Chunked transfer
vigyanabikshu
Postby vigyanabikshu » Fri Feb 07, 2025 1:29 am
In Arduino, the below code works fine and get result from gemini
if (https.begin("https://generativelanguage.googleapis.c ... ntent?key=" + (String)Gemini_Token)) { // HTTPS
https.addHeader("Content-Type", "application/json");
String payload = String("{\"contents\": [{\"parts\":[{\"text\":" + res + "}]}],\"generationConfig\": {\"maxOutputTokens\": " + (String)Gemini_Max_Tokens + "}}");
Serial.println("Payload: " +payload);
//Serial.print("[HTTPS] GET...\n");
// start connection and send HTTP header
int httpCode = https.POST(payload);
Serial.println(httpCode);
// httpCode will be negative on error
// file found at server
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
String payload = https.getString();
//Serial.println(payload);
DynamicJsonDocument doc(4096);
deserializeJson(doc, payload);
String Answer = doc["candidates"][0]["content"]["parts"][0]["text"];
// For Filtering our Special Characters, WhiteSpaces and NewLine Characters
Answer.trim();
String filteredAnswer = "";
for (size_t i = 0; i < Answer.length(); i++) {
char c = Answer;
if (isalnum(c) || isspace(c)) {
filteredAnswer += c;
filteredAnswer += ' ';
Answer = filteredAnswer;
int answerLength = Answer.length();
int filteredAnswerLength = filteredAnswer.length();
Serial.println("Answer length: " + String(answerLength));
Serial.println("Filtered answer length: " + String(filteredAnswerLength));
Serial.println("");
Serial.println("Here is your Answer: ");
Serial.println("");
Serial.println(Answer);
Serial.printf("[HTTPS] GET... failed, error: %s\n", https.errorToString(httpCode).c_str());
https.end();
Serial.printf("[HTTPS] Unable to connect\n");
MicroController
Postby MicroController » Fri Feb 07, 2025 8:28 am
The point is that esp_http_client_get_content_length() can return -1 (when the server uses chunked transfer to send the data), and you cannot rely on esp_http_client_get_content_length() returning > 0, i.e. the content length being known in advance.
vigyanabikshu
Postby vigyanabikshu » Fri Feb 07, 2025 2:23 pm
Thanks for your kind reply. I tried receiving chunked data, but still nothing receiving
if (err != ESP_OK) {
ESP_LOGE(TAG, "Failed to perform HTTP request");
cJSON_Delete(root);
return err;
}else{
char buffer[MAX_HTTP_OUTPUT_BUFFER] = {0};
int total_read = 0;
int read_len;
// Read response in chunks
do {
read_len = esp_http_client_read(client, buffer, MAX_HTTP_OUTPUT_BUFFER - 1);
if (read_len > 0) {
buffer[read_len] = '\0'; // Null-terminate for safe logging
total_read += read_len;
ESP_LOGI(TAG, "%s", buffer); // Print chunk
} while (read_len > 0);
ESP_LOGI(TAG, "Total Response Size: %d bytes", total_read);
markdh102
Postby markdh102 » Fri Feb 07, 2025 3:25 pm
Change your
to
while (total_read == 0 || read_len > 0)
Also be worth adding a timeout clause in the do loop to exit after 5s for example if nothing has been received.
Users browsing this forum: Baidu [Spider] and 3 guests
