mb_tcp_slave and wifi_station, first project
marekdor
Postby marekdor » Wed Feb 05, 2025 3:53 pm
I'm trying to get my first project in ESP-IDF done, which is modbus TCP on top of WiFi. I'm not yet proficient in this particular framework so I decided to start from examples offered by this framework. So I have taken wifi station, and confirmed it does work with my network. Then I have taken mb_server_tcp, that uses simplified networking support, and it also did work. Now As I need robust support of networking stack I wanted to combine these 2 projects, and here my struggle starts. So Below is my code. Basically After wifi connection is established I have added corresponding function from modbus project (but skipping init_services() and all nvs_flash_init().
/* WiFi station Example
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#include "protocol_examples_common.h"
#include "mbcontroller.h"       // for mbcontroller defines and api
#include "modbus_params.h"      // for modbus parameters structures
#define MB_TCP_PORT_NUMBER      (CONFIG_FMB_TCP_PORT_DEFAULT)
#define MB_MDNS_PORT            (502)
/* The examples use WiFi configuration that you can set via project configuration menu
   If you'd rather not, just change the below entries to strings with
   the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID      CONFIG_ESP_WIFI_SSID
#define EXAMPLE_ESP_WIFI_PASS      CONFIG_ESP_WIFI_PASSWORD
#define EXAMPLE_ESP_MAXIMUM_RETRY  CONFIG_ESP_MAXIMUM_RETRY
#if CONFIG_ESP_WIFI_AUTH_OPEN
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_OPEN
#elif CONFIG_ESP_WIFI_AUTH_WEP
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WEP
#elif CONFIG_ESP_WIFI_AUTH_WPA_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA_WPA2_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WAPI_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WAPI_PSK
#endif
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
esp_err_t slave_destroy(void);
esp_err_t destroy_services(void);
esp_err_t slave_init(mb_communication_info_t* comm_info);
void slave_operation_func(void *arg);
/* The event group allows multiple bits for each event, but we only care about two events:
 * - we are connected to the AP with an IP
 * - we failed to connect after the maximum amount of retries */
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT      BIT1
static const char *TAG = "wifi station";
static int s_retry_num = 0;
static void event_handler(void* arg, esp_event_base_t event_base,
                                int32_t event_id, void* event_data)
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
        if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
            esp_wifi_connect();
            s_retry_num++;
            ESP_LOGI(TAG, "retry to connect to the AP");
            xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
        ESP_LOGI(TAG,"connect to the AP fail");
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
        ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
        s_retry_num = 0;
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
void wifi_init_sta(void)
    s_wifi_event_group = xEventGroupCreate();
    esp_netif_create_default_wifi_sta();
    esp_event_handler_instance_t instance_any_id;
    esp_event_handler_instance_t instance_got_ip;
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
                                                        ESP_EVENT_ANY_ID,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_any_id));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
                                                        IP_EVENT_STA_GOT_IP,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_got_ip));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = EXAMPLE_ESP_WIFI_SSID,
            .password = EXAMPLE_ESP_WIFI_PASS,
            /* Setting a password implies station will connect to all security modes including WEP/WPA.
             * However these modes are deprecated and not advisable to be used. Incase your Access point
             * doesn't support WPA2, these mode can be enabled by commenting below line */
	     .threshold.authmode = ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD,
	     .sae_pwe_h2e = WPA3_SAE_PWE_BOTH,
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    /* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
     * number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
            WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
            pdFALSE,
            pdFALSE,
            portMAX_DELAY);
    /* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
     * happened. */
    if (bits & WIFI_CONNECTED_BIT) {
        ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
                 EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
    } else if (bits & WIFI_FAIL_BIT) {
        ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
        ESP_LOGE(TAG, "UNEXPECTED EVENT");
    /* The event will not be processed after unregister */
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
    vEventGroupDelete(s_wifi_event_group);
void app_main(void)
    //Initialize NVS
    ESP_ERROR_CHECK(ret);
    ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
    wifi_init_sta();
        mb_communication_info_t comm_info = { 0 };
#if !CONFIG_EXAMPLE_CONNECT_IPV6
    comm_info.ip_addr_type = MB_IPV4;
#else
    comm_info.ip_addr_type = MB_IPV6;
#endif
    comm_info.ip_mode = MB_MODE_TCP;
    comm_info.ip_port = MB_TCP_PORT_NUMBER;
    ESP_ERROR_CHECK(slave_init(&comm_info));
    // The Modbus slave logic is located in this function (user handling of Modbus)
    slave_operation_func(NULL);
    ESP_ERROR_CHECK(slave_destroy());
    ESP_ERROR_CHECK(destroy_services());
So after i want to call slave_init() I am getting these errors in the Monitor terminal
I (1589) wifi:<ba-add>idx:0 (ifx:0, 44:d9:e7:5f:76:a0), tid:0, ssn:0, winSize:64
I (1629) wifi:AP's beacon interval = 102400 us, DTIM period = 3
I (2579) esp_netif_handlers: sta ip: 10.0.38.24, mask: 255.255.255.0, gw: 10.0.38.1
I (2579) wifi station: got ip:10.0.38.24
I (2579) wifi station: connected to ap SSID:Dzik password:MyWifiPassword
E (2589) MB_CONTROLLER_SLAVE: mbc_tcp_slave_setup(61): mb incorrect iface address.
E (2589) MB_CONTROLLER_SLAVE: mbc_slave_setup(133): Slave setup failure error=(0x102).
E (2599) SLAVE_TEST: slave_init(325): mbc_slave_setup fail, returns(0x103).
ESP_ERROR_CHECK failed: esp_err_t 0x103 (ESP_ERR_INVALID_STATE) at 0x400886a8
Does anyone know what I could be missing here ? Thank you
nopnop2002
Contact:
Re: mb_tcp_slave and wifi_station, first project
Postby nopnop2002 » Tue Feb 11, 2025 8:20 am
Will you get the same error even if you change it like this?
#if 0
#else
#endif
#endif
ESP_alisitsyn
Contact:
Postby ESP_alisitsyn » Fri Feb 14, 2025 8:42 am
Please check your code in the
slave_init()
function. You do not provide it here but it does not initialize the slave interface correctly https://docs.espressif.com/projects/esp ... ialization.
This is a reason for your failure.
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User and 10 guests
