Stereo DAC via DMA
sergyegorov
Stereo DAC via DMA
Postby sergyegorov » Fri Feb 21, 2025 2:56 pm
Hi guys! It must be some stupid mistake! But I can't find it!... So the following program supposed to send sawtooth signal to DAC1 and sine wave to DAC2 via DMA. But I have sine wave on BOTH pins GPIO25 and GPIO26! (ESP32 Wemos LoLin32 with ESP32-D0WD CPU) Appreciate for any help!!!!
#include "driver/i2s.h"
#define SAMPLE_RATE 400000
#define WAVEFORM_SAMPLES 256
uint8_t stereo_buffer[WAVEFORM_SAMPLES * 2];
uint8_t wave_data1[WAVEFORM_SAMPLES];
uint8_t wave_data2[WAVEFORM_SAMPLES];
void generateWaveforms() {
  for (int i = 0; i < WAVEFORM_SAMPLES; i++) {
    wave_data1[i] = (uint8_t)((255 * i) / WAVEFORM_SAMPLES);
    wave_data2[i] = (uint8_t)(127.5 * (1 + sin(2 * 3.14159 * i / WAVEFORM_SAMPLES)));
    stereo_buffer[i * 2] = wave_data1[i];      // DAC1
    stereo_buffer[i * 2 + 1] = wave_data2[i];  // DAC2
  generateWaveforms();
  i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN),
    .sample_rate = SAMPLE_RATE,
    .bits_per_sample = I2S_BITS_PER_SAMPLE_8BIT,
    .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
    .communication_format = I2S_COMM_FORMAT_I2S_MSB,
    .intr_alloc_flags = 0,
    .dma_buf_count = 8,
    .dma_buf_len = WAVEFORM_SAMPLES * 2,
    .use_apll = false,
  i2s_set_pin(I2S_NUM_0, NULL);
  i2s_set_dac_mode(I2S_DAC_CHANNEL_BOTH_EN);
  i2s_set_sample_rates(I2S_NUM_0, i2s_config.sample_rate);
  size_t bytes_written;
  i2s_write(I2S_NUM_0, stereo_buffer, sizeof(stereo_buffer), &bytes_written, portMAX_DELAY);
ted123
Re: Stereo DAC via DMA
Postby ted123 » Tue Jun 24, 2025 2:47 pm
Did you solved the problem ?
