How can i use defined(ARDUINO_T-BEAM) when the '-' character is not accepted by compiler?
serialrf433
Postby serialrf433 » Sun Feb 23, 2025 2:06 pm
Hello. The file boards.txt have many different boards defined. Some of them have a name with a '-' inside like the t-beam. When i write software and want to check the board, i would like to use for example the defined(ARDUINO_T-BEAM). But that is not possible. The compiler does not accept '-' in defined().
Thats how the compiler error looks like:
error: missing binary operator before token "BEAM"
   42 |   #elif defined(ARDUINO_T-BEAM)
Could someone tell me how this can be used in such a use case? I searched for some time but was not able to find an answer.
lbernstone
Re: How can i use defined(ARDUINO_T-BEAM) when the '-' character is not accepted by compiler?
Postby lbernstone » Mon Feb 24, 2025 3:25 am
It is ARDUINO_TBEAM. You can look through boards.txt for the .board entry, which is what gets appended to ARDUINO_. You can also see this in the variants directory.
Users browsing this forum: Applebot, Qwantbot and 1 guest
