DSP support for ESP32C6 risk-V architecture
Devtry
Postby Devtry » Wed Feb 26, 2025 12:02 pm
I downloaded the ESP-DSP package from
GITHUB:
https://github.com/espressif/esp-dsp
and it is quite well put together. In the
directories available therein I was able to
find the following processors supported
within this DSP package:
* The extension (_ae32) for ESP32 chip.
* The extension (_aes3) for ESP32s3 processor.
* The extension (_arp4) for esp32p4 processor.
* The extension (_ansi) is ANSI C
I am planning to use the risk-V based esp32c6
processor, is there any optimzed assembly code for
the risk-V architecture ?
Thanks.
Re: DSP support for ESP32C6 risk-V architecture
Postby Sprite » Thu Feb 27, 2025 12:15 am
I don't think so. All the other chips have some kind of SIMD instructions, so it makes sense to hand-roll assembly code for them (as the C compiler doesn't know of and wouldn't make use of those SIMD instructions). The -C series have plain RiscV-cores without any SIMD support, so it doesn't really make sense to hand-roll assembly for them; the compiler usually does a good enough job by itself when you use the ansi-c version.
Devtry
Postby Devtry » Sat Mar 01, 2025 2:18 pm
Thanks for the clarification. That was helpful.
