Code: Untitled.txt Select all
USAGE ➜ cargo run --release
Finished `release` profile [optimized] target(s) in 0.29s
Running `espflash flash --monitor target/xtensa-esp32s3-espidf/release/s3-test`
[2025-02-27T15:46:18Z INFO ] Detected 2 serial ports
[2025-02-27T15:46:18Z INFO ] Ports which match a known common dev board are highlighted
[2025-02-27T15:46:18Z INFO ] Please select a port
[2025-02-27T15:46:19Z INFO ] Serial port: '/dev/cu.usbserial-110'
[2025-02-27T15:46:19Z INFO ] Connecting...
[2025-02-27T15:46:22Z INFO ] Using flash stub
Chip type: esp32 (revision v1.1)
Crystal frequency: 40 MHz
Flash size: 4MB
MAC address: 3c:8a:1f:d5:22:6c
App/part. size: 406,512/4,128,768 bytes, 9.85%
[00:00:01] [========================================] 17/17 0x1000 [00:00:00] [========================================] 1/1 0x8000 [00:00:24] [========================================] 234/234 0x10000 [2025-02-27T15:46:51Z INFO ] Flashing has completed!
Commands:
CTRL+R Reset chip
CTRL+C Exit
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:7104
load:0x40078000,len:15576
load:0x40080400,len:4
ho 8 tail 4 room 4
load:0x40080404,len:3876
entry 0x4008064c
I (31) boot: ESP-IDF v5.1-beta1-378-gea5e0ff298-dirt 2nd stage bootloader
I (31) boot: compile time Jun 7 2023 07:48:23
I (33) boot: Multicore bootloader
I (37) boot: chip revision: v1.1
I (41) boot.esp32: SPI Speed : 40MHz
I (45) boot.esp32: SPI Mode : DIO
I (50) boot.esp32: SPI Flash Size : 4MB
I (55) boot: Enabling RNG early entropy source...
I (60) boot: Partition Table:
I (64) boot: ## Label Usage Type ST Offset Length
I (71) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (78) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (86) boot: 2 factory factory app 00 00 00010000 003f0000
I (93) boot: End of partition table
I (97) esp_image: segment 0: paddr=00010020 vaddr=3c050020 size=03fd8h ( 16344) load
[b]E (106) esp_image: Segment 0 0x3c050020-0x3c053ff8 invalid: bad load address range
E (114) boot: Factory app partition is not bootable
E (120) boot: No bootable app partitions in the partition table[/b]
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 8 tail 4 room 4
entry 0x4008064c
I (60) boot: ESP-IDF v5.1-beta1-378-gea5e0ff298-dirt 2nd stage bootloadercargo generate esp-rs/esp-idf-template cargo
Flashing a ESP32-Cam via a CH340C Mother board, purchased with the device.
Can build and flash esp32c3 chips no issue.
Thank you in advance for any help, google searches have not provided much info
