matter usage of val
ravencarcass
matter usage of val
Postby ravencarcass » Tue Mar 04, 2025 5:57 pm
Hello creator and engineers,
I want to test some things with Matter. I made a custom program using the example of Matter. But I have problems with the data
esp_matter_attr_val_t *val
. I thought that the OnOff value passes a True or a False and I also thought that the LevelControl passes a value between 0 and 100. You can see this in the code as well.
result:
After connecting the app to the microcontroller, I can see that it receives data from my phone, but no output is changed. I think I mishandled the value *fall, but I'm not sure how to fix it.
main code
#include <esp_err.h>
#include <esp_log.h>
#include <nvs_flash.h>
#include <esp_matter.h>
#include <esp_matter_console.h>
#include <esp_matter_ota.h>
#include <common_macros.h>
#include <app_priv.h>
#include <app_reset.h>
#if CHIP_DEVICE_CONFIG_ENABLE_THREAD
#include <platform/ESP32/OpenthreadLauncher.h>
#endif
#include <app/server/CommissioningWindowManager.h>
#include <app/server/Server.h>
#ifdef CONFIG_ENABLE_SET_CERT_DECLARATION_API
#include <esp_matter_providers.h>
#include <lib/support/Span.h>
#ifdef CONFIG_SEC_CERT_DAC_PROVIDER
#include <platform/ESP32/ESP32SecureCertDACProvider.h>
#elif defined(CONFIG_FACTORY_PARTITION_DAC_PROVIDER)
#include <platform/ESP32/ESP32FactoryDataProvider.h>
#endif
using namespace chip::DeviceLayer;
#endif
static const char *TAG = "app_main";
uint16_t light_endpoint_id = 0;
uint16_t light_endpoint_id_1 = 0;
uint16_t light_endpoint_id_2 = 0;
uint16_t light_endpoint_id_3 = 0;
uint16_t light_endpoint_id_4 = 0;
uint16_t light_endpoint_id_5 = 0;
uint16_t light_endpoint_id_6 = 0;
uint16_t light_endpoint_id_7 = 0;
uint16_t light_endpoint_id_8 = 0;
uint16_t light_endpoint_id_9 = 0;
uint16_t light_endpoint_id_10 = 0;
uint16_t light_endpoint_id_11 = 0;
using namespace esp_matter;
using namespace esp_matter::attribute;
using namespace esp_matter::endpoint;
using namespace chip::app::Clusters;
constexpr auto k_timeout_seconds = 300;
extern const uint8_t cd_start[] asm("_binary_certification_declaration_der_start");
extern const uint8_t cd_end[] asm("_binary_certification_declaration_der_end");
const chip::ByteSpan cdSpan(cd_start, static_cast<size_t>(cd_end - cd_start));
#endif // CONFIG_ENABLE_SET_CERT_DECLARATION_API
#if CONFIG_ENABLE_ENCRYPTED_OTA
extern const char decryption_key_start[] asm("_binary_esp_image_encryption_key_pem_start");
extern const char decryption_key_end[] asm("_binary_esp_image_encryption_key_pem_end");
static const char *s_decryption_key = decryption_key_start;
static const uint16_t s_decryption_key_len = decryption_key_end - decryption_key_start;
#endif // CONFIG_ENABLE_ENCRYPTED_OTA
static void app_event_cb(const ChipDeviceEvent *event, intptr_t arg)
    switch (event->Type) {
    case chip::DeviceLayer::DeviceEventType::kInterfaceIpAddressChanged:
        ESP_LOGI(TAG, "Interface IP Address changed");
    case chip::DeviceLayer::DeviceEventType::kCommissioningComplete:
        ESP_LOGI(TAG, "Commissioning complete");
    case chip::DeviceLayer::DeviceEventType::kFailSafeTimerExpired:
        ESP_LOGI(TAG, "Commissioning failed, fail safe timer expired");
    case chip::DeviceLayer::DeviceEventType::kCommissioningSessionStarted:
        ESP_LOGI(TAG, "Commissioning session started");
    case chip::DeviceLayer::DeviceEventType::kCommissioningSessionStopped:
        ESP_LOGI(TAG, "Commissioning session stopped");
    case chip::DeviceLayer::DeviceEventType::kCommissioningWindowOpened:
        ESP_LOGI(TAG, "Commissioning window opened");
    case chip::DeviceLayer::DeviceEventType::kCommissioningWindowClosed:
        ESP_LOGI(TAG, "Commissioning window closed");
    case chip::DeviceLayer::DeviceEventType::kFabricRemoved:
            ESP_LOGI(TAG, "Fabric removed successfully");
            if (chip::Server::GetInstance().GetFabricTable().FabricCount() == 0)
                chip::CommissioningWindowManager & commissionMgr = chip::Server::GetInstance().GetCommissioningWindowManager();
                constexpr auto kTimeoutSeconds = chip::System::Clock::Seconds16(k_timeout_seconds);
                if (!commissionMgr.IsCommissioningWindowOpen())
                    /* After removing last fabric, this example does not remove the Wi-Fi credentials
                     * and still has IP connectivity so, only advertising on DNS-SD.
                    CHIP_ERROR err = commissionMgr.OpenBasicCommissioningWindow(kTimeoutSeconds,
                                                    chip::CommissioningWindowAdvertisement::kDnssdOnly);
                    if (err != CHIP_NO_ERROR)
                        ESP_LOGE(TAG, "Failed to open commissioning window, err:%" CHIP_ERROR_FORMAT, err.Format());
    case chip::DeviceLayer::DeviceEventType::kFabricWillBeRemoved:
        ESP_LOGI(TAG, "Fabric will be removed");
    case chip::DeviceLayer::DeviceEventType::kFabricUpdated:
        ESP_LOGI(TAG, "Fabric is updated");
    case chip::DeviceLayer::DeviceEventType::kFabricCommitted:
        ESP_LOGI(TAG, "Fabric is committed");
    case chip::DeviceLayer::DeviceEventType::kBLEDeinitialized:
        ESP_LOGI(TAG, "BLE deinitialized and memory reclaimed");
    default:
// This callback is invoked when clients interact with the Identify Cluster.
// In the callback implementation, an endpoint can identify itself. (e.g., by flashing an LED or light).
static esp_err_t app_identification_cb(identification::callback_type_t type, uint16_t endpoint_id, uint8_t effect_id,
                                       uint8_t effect_variant, void *priv_data)
    ESP_LOGI(TAG, "Identification callback: type: %u, effect: %u, variant: %u", type, effect_id, effect_variant);
    return ESP_OK;
// This callback is called for every attribute update. The callback implementation shall
// handle the desired attributes and return an appropriate error code. If the attribute
// is not of your interest, please do not return an error code and strictly return ESP_OK.
static esp_err_t app_attribute_update_cb(attribute::callback_type_t type, uint16_t endpoint_id, uint32_t cluster_id,
                                         uint32_t attribute_id, esp_matter_attr_val_t *val, void *priv_data)
    esp_err_t err = ESP_OK;
    if (type == PRE_UPDATE) {
        /* Driver update */
        app_driver_handle_t driver_handle = (app_driver_handle_t)priv_data;
        err = app_driver_attribute_update(driver_handle, endpoint_id, cluster_id, attribute_id, val);
    return err;
extern "C" void app_main()
    /* Initialize the ESP NVS layer */
    nvs_flash_init();
    /* Initialize driver */
    app_driver_handle_t light_handle = app_driver_light_init();
    app_driver_handle_t button_handle = app_driver_button_init();
    app_reset_button_register(button_handle);
    /* Create a Matter node and add the mandatory Root Node device type on endpoint 0 */
    node::config_t node_config;
    // node handle can be used to add/modify other endpoints.
    node_t *node = node::create(&node_config, app_attribute_update_cb, app_identification_cb);
    ABORT_APP_ON_FAILURE(node != nullptr, ESP_LOGE(TAG, "Failed to create Matter node"));
    /*extended_color_light::config_t light_config;
    light_config.on_off.on_off = DEFAULT_POWER;
    light_config.on_off.lighting.start_up_on_off = nullptr;
    light_config.level_control.current_level = DEFAULT_BRIGHTNESS;
    light_config.level_control.on_level = DEFAULT_BRIGHTNESS;
    light_config.level_control.lighting.start_up_current_level = DEFAULT_BRIGHTNESS;
    light_config.color_control.color_mode = (uint8_t)ColorControl::ColorMode::kColorTemperature;
    light_config.color_control.enhanced_color_mode = (uint8_t)ColorControl::ColorMode::kColorTemperature;
    light_config.color_control.color_temperature.startup_color_temperature_mireds = nullptr;*/
    dimmable_light::config_t light_config;
    // endpoint handles can be used to add/modify clusters.
    endpoint_t *endpoint = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    ABORT_APP_ON_FAILURE(endpoint != nullptr, ESP_LOGE(TAG, "Failed to create extended color light endpoint"));
    light_endpoint_id = endpoint::get_id(endpoint);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id);
    endpoint_t *endpoint_1 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_1);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_1);
    endpoint_t *endpoint_2 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_2);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_2);
    endpoint_t *endpoint_3 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_3);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_3);
    endpoint_t *endpoint_4 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_4);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_4);
    endpoint_t *endpoint_5 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_5);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_5);
    endpoint_t *endpoint_6 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_6);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_6);
    endpoint_t *endpoint_7 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_7);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_7);
    endpoint_t *endpoint_8 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
    light_endpoint_id = endpoint::get_id(endpoint_8);
    ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_8);
endpoint_t *endpoint_9 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
light_endpoint_id = endpoint::get_id(endpoint_9);
ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_9);
endpoint_t *endpoint_10 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
light_endpoint_id = endpoint::get_id(endpoint_10);
ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_10);
endpoint_t *endpoint_11 = dimmable_light::create(node, &light_config, ENDPOINT_FLAG_NONE, light_handle);
light_endpoint_id = endpoint::get_id(endpoint_11);
ESP_LOGI(TAG, "Light created with endpoint_id %d", light_endpoint_id_11);
    /* Mark deferred persistence for some attributes that might be changed rapidly
    attribute_t *current_level_attribute = attribute::get(light_endpoint_id, LevelControl::Id, LevelControl::Attributes::CurrentLevel::Id);
    attribute::set_deferred_persistence(current_level_attribute);
    attribute_t *current_x_attribute = attribute::get(light_endpoint_id, ColorControl::Id, ColorControl::Attributes::CurrentX::Id);
    attribute::set_deferred_persistence(current_x_attribute);
    attribute_t *current_y_attribute = attribute::get(light_endpoint_id, ColorControl::Id, ColorControl::Attributes::CurrentY::Id);
    attribute::set_deferred_persistence(current_y_attribute);
    attribute_t *color_temp_attribute = attribute::get(light_endpoint_id, ColorControl::Id, ColorControl::Attributes::ColorTemperatureMireds::Id);
    attribute::set_deferred_persistence(color_temp_attribute);
#if CHIP_DEVICE_CONFIG_ENABLE_THREAD && CHIP_DEVICE_CONFIG_ENABLE_WIFI_STATION
    // Enable secondary network interface
    secondary_network_interface::config_t secondary_network_interface_config;
    endpoint = endpoint::secondary_network_interface::create(node, &secondary_network_interface_config, ENDPOINT_FLAG_NONE, nullptr);
    ABORT_APP_ON_FAILURE(endpoint != nullptr, ESP_LOGE(TAG, "Failed to create secondary network interface endpoint"));
#endif
    /* Set OpenThread platform config */
    esp_openthread_platform_config_t config = {
        .radio_config = ESP_OPENTHREAD_DEFAULT_RADIO_CONFIG(),
        .host_config = ESP_OPENTHREAD_DEFAULT_HOST_CONFIG(),
        .port_config = ESP_OPENTHREAD_DEFAULT_PORT_CONFIG(),
    set_openthread_platform_config(&config);
#endif
    auto * dac_provider = get_dac_provider();
    static_cast<ESP32SecureCertDACProvider *>(dac_provider)->SetCertificationDeclaration(cdSpan);
    static_cast<ESP32FactoryDataProvider *>(dac_provider)->SetCertificationDeclaration(cdSpan);
#endif
    /* Matter start */
    err = esp_matter::start(app_event_cb);
    ABORT_APP_ON_FAILURE(err == ESP_OK, ESP_LOGE(TAG, "Failed to start Matter, err:%d", err));
    /* Starting driver with default values */
    app_driver_light_set_defaults(light_endpoint_id);
    err = esp_matter_ota_requestor_encrypted_init(s_decryption_key, s_decryption_key_len);
    ABORT_APP_ON_FAILURE(err == ESP_OK, ESP_LOGE(TAG, "Failed to initialized the encrypted OTA, err: %d", err));
#if CONFIG_ENABLE_CHIP_SHELL
    esp_matter::console::diagnostics_register_commands();
    esp_matter::console::wifi_register_commands();
    esp_matter::console::factoryreset_register_commands();
#if CONFIG_OPENTHREAD_CLI
    esp_matter::console::otcli_register_commands();
#endif
    esp_matter::console::init();
#endif
driver code
#include <stdlib.h>
#include <string.h>
#include "bsp/esp-bsp.h"
#include "driver/gpio.h"
#include "driver/i2c.h"
#include "driver/i2c_master.h"
#define I2C_MASTER_SCL_IO   8
#define I2C_MASTER_SDA_IO   10
#define I2C_MASTER_FREQ_HZ  400000
//#define 12C_MASTER_NUM      I2C_NUM_0
static const char *TAG = "app_driver";
extern uint16_t light_endpoint_id;
extern uint16_t light_endpoint_id_1;
extern uint16_t light_endpoint_id_2;
extern uint16_t light_endpoint_id_3;
extern uint16_t light_endpoint_id_4;
extern uint16_t light_endpoint_id_5;
extern uint16_t light_endpoint_id_6;
extern uint16_t light_endpoint_id_7;
extern uint16_t light_endpoint_id_8;
extern uint16_t light_endpoint_id_9;
extern uint16_t light_endpoint_id_10;
extern uint16_t light_endpoint_id_11;
void i2c_init(void){
    i2c_config_t confi2c = {
        .mode = I2C_MODE_MASTER,
        .sda_io_num = I2C_MASTER_SDA_IO,
        .scl_io_num = I2C_MASTER_SCL_IO,
        .sda_pullup_en = GPIO_PULLUP_ENABLE,
        .scl_pullup_en = GPIO_PULLUP_ENABLE,
        .master = { .clk_speed = I2C_MASTER_FREQ_HZ } // Correcte initialisatie
    i2c_param_config(I2C_NUM_0, &confi2c);
    i2c_driver_install(I2C_NUM_0,confi2c.mode,0,0,0);
void i2c_write_data(uint8_t byte1, uint8_t byte2) {
    uint8_t data[2] = {byte1, byte2};
    esp_err_t err = i2c_master_write_to_device (
        I2C_NUM_0,
        0x30,
        data,
        sizeof(data),
        pdMS_TO_TICKS(1000)
    if(err != ESP_OK) {
        printf("I2C write failed: %s\n", esp_err_to_name(err));
/* Do any conversions/remapping for the actual value here */
static esp_err_t app_driver_light_set_power(led_indicator_handle_t handle, esp_matter_attr_val_t *val)
#if CONFIG_BSP_LEDS_NUM > 0
    if (val->val.b) {
        err = led_indicator_start(handle, BSP_LED_ON);
        err = led_indicator_start(handle, BSP_LED_OFF);
    return err;
#else
    ESP_LOGI(TAG, "LED set power: %d", val->val.b);
    return ESP_OK;
#endif
static esp_err_t app_driver_light_set_brightness(led_indicator_handle_t handle, esp_matter_attr_val_t *val)
    int value = REMAP_TO_RANGE(val->val.u8, MATTER_BRIGHTNESS, STANDARD_BRIGHTNESS);
    return led_indicator_set_brightness(handle, value);
#else
    ESP_LOGI(TAG, "LED set brightness: %d", value);
    return ESP_OK;
#endif
static esp_err_t app_driver_light_set_hue(led_indicator_handle_t handle, esp_matter_attr_val_t *val)
    int value = REMAP_TO_RANGE(val->val.u8, MATTER_HUE, STANDARD_HUE);
    led_indicator_ihsv_t hsv;
    hsv.value = led_indicator_get_hsv(handle);
    hsv.h = value;
    return led_indicator_set_hsv(handle, hsv.value);
#else
    ESP_LOGI(TAG, "LED set hue: %d", value);
    return ESP_OK;
#endif
static esp_err_t app_driver_light_set_saturation(led_indicator_handle_t handle, esp_matter_attr_val_t *val)
    int value = REMAP_TO_RANGE(val->val.u8, MATTER_SATURATION, STANDARD_SATURATION);
    hsv.s = value;
#else
    ESP_LOGI(TAG, "LED set saturation: %d", value);
    return ESP_OK;
#endif
static esp_err_t app_driver_light_set_temperature(led_indicator_handle_t handle, esp_matter_attr_val_t *val)
    uint32_t value = REMAP_TO_RANGE_INVERSE(val->val.u16, STANDARD_TEMPERATURE_FACTOR);
    return led_indicator_set_color_temperature(handle, value);
#else
    ESP_LOGI(TAG, "LED set temperature: %ld", value);
    return ESP_OK;
#endif
static void app_driver_button_toggle_cb(void *arg, void *data)
    ESP_LOGI(TAG, "Toggle button pressed");
    uint16_t endpoint_id = light_endpoint_id;
    uint32_t cluster_id = OnOff::Id;
    uint32_t attribute_id = OnOff::Attributes::OnOff::Id;
    attribute_t *attribute = attribute::get(endpoint_id, cluster_id, attribute_id);
    esp_matter_attr_val_t val = esp_matter_invalid(NULL);
    attribute::get_val(attribute, &val);
    val.val.b = !val.val.b;
    attribute::update(endpoint_id, cluster_id, attribute_id, &val);
/*esp_err_t app_driver_attribute_update(app_driver_handle_t driver_handle, uint16_t endpoint_id, uint32_t cluster_id,
                                      uint32_t attribute_id, esp_matter_attr_val_t *val)
    if (endpoint_id == light_endpoint_id) {
        led_indicator_handle_t handle = (led_indicator_handle_t)driver_handle;
        if (cluster_id == OnOff::Id) {
            if (attribute_id == OnOff::Attributes::OnOff::Id) {
                err = app_driver_light_set_power(handle, val);
        } else if (cluster_id == LevelControl::Id) {
            if (attribute_id == LevelControl::Attributes::CurrentLevel::Id) {
                err = app_driver_light_set_brightness(handle, val);
        } else if (cluster_id == ColorControl::Id) {
            if (attribute_id == ColorControl::Attributes::CurrentHue::Id) {
                err = app_driver_light_set_hue(handle, val);
            } else if (attribute_id == ColorControl::Attributes::CurrentSaturation::Id) {
                err = app_driver_light_set_saturation(handle, val);
            } else if (attribute_id == ColorControl::Attributes::ColorTemperatureMireds::Id) {
                err = app_driver_light_set_temperature(handle, val);
    return err;
        if(cluster_id == LevelControl::Id)
            if(attribute_id == LevelControl::Attributes::CurrentLevel::Id)
                i2c_write_data(0xFE, 0xC5);
                i2c_write_data(0xFD, 0x04);
                i2c_write_data(0x00, 0x01);
                i2c_write_data(0x01, 0xFF);
                uint8_t tempVal = val->val.u8;    //problem with using the
                for(uint8_t i=0; i < tempVal; i++)
                    i2c_write_data(0xFD, 0x02);
                    i2c_write_data(i, 0x0F);
                    i2c_write_data(0xFD, 0x00);
                    i2c_write_data(i, 0xFF);
                for(int i=100-tempVal; i<=100; i++)
    if (endpoint_id == light_endpoint_id_1)
    if (endpoint_id == light_endpoint_id_2) {
        if(cluster_id == OnOff::Id)
            if(attribute_id == OnOff::Attributes::OnOff::Id)
                if(val == on)     //TRue or false
                    gpio_set_level(GPIO_NUM_15, 1);
                else
                    gpio_set_level(GPIO_NUM_15, 0);
    if (endpoint_id == light_endpoint_id_3) {
                if(val)     //TRue or false
                    gpio_set_level(GPIO_NUM_23, 1);
                else
                    gpio_set_level(GPIO_NUM_23, 0);
    if (endpoint_id == light_endpoint_id_4) {
                    gpio_set_level(GPIO_NUM_22, 1);
                else
                    gpio_set_level(GPIO_NUM_22, 0);
    if (endpoint_id == light_endpoint_id_5) {
                    gpio_set_level(GPIO_NUM_21, 1);
                else
                    gpio_set_level(GPIO_NUM_21, 0);
    if (endpoint_id == light_endpoint_id_6) {
                    gpio_set_level(GPIO_NUM_20, 1);
                else
                    gpio_set_level(GPIO_NUM_20, 0);
    if (endpoint_id == light_endpoint_id_7) {
                    gpio_set_level(GPIO_NUM_16, 1);
                else
                    gpio_set_level(GPIO_NUM_16, 0);
    if (endpoint_id == light_endpoint_id_8) {
                    gpio_set_level(GPIO_NUM_18, 1);
                else
                    gpio_set_level(GPIO_NUM_18, 0);
    if (endpoint_id == light_endpoint_id_9) {
                    gpio_set_level(GPIO_NUM_9, 1);
                else
                    gpio_set_level(GPIO_NUM_9, 0);
    if (endpoint_id == light_endpoint_id_10) {
                    gpio_set_level(GPIO_NUM_13, 1);
                else
                    gpio_set_level(GPIO_NUM_13, 0);
    if (endpoint_id == light_endpoint_id_11) {
                    gpio_set_level(GPIO_NUM_12, 1);
                else
                    gpio_set_level(GPIO_NUM_12, 0);
    return err;
esp_err_t app_driver_light_set_defaults(uint16_t endpoint_id)
    void *priv_data = endpoint::get_priv_data(endpoint_id);
    led_indicator_handle_t handle = (led_indicator_handle_t)priv_data;
    /* Setting brightness */
    attribute_t *attribute = attribute::get(endpoint_id, LevelControl::Id, LevelControl::Attributes::CurrentLevel::Id);
    err |= app_driver_light_set_brightness(handle, &val);
    /* Setting color */
    attribute = attribute::get(endpoint_id, ColorControl::Id, ColorControl::Attributes::ColorMode::Id);
    if (val.val.u8 == (uint8_t)ColorControl::ColorMode::kCurrentHueAndCurrentSaturation) {
        /* Setting hue */
        attribute = attribute::get(endpoint_id, ColorControl::Id, ColorControl::Attributes::CurrentHue::Id);
        err |= app_driver_light_set_hue(handle, &val);
        /* Setting saturation */
        attribute = attribute::get(endpoint_id, ColorControl::Id, ColorControl::Attributes::CurrentSaturation::Id);
        err |= app_driver_light_set_saturation(handle, &val);
    } else if (val.val.u8 == (uint8_t)ColorControl::ColorMode::kColorTemperature) {
        /* Setting temperature */
        attribute = attribute::get(endpoint_id, ColorControl::Id, ColorControl::Attributes::ColorTemperatureMireds::Id);
        err |= app_driver_light_set_temperature(handle, &val);
        ESP_LOGE(TAG, "Color mode not supported");
    /* Setting power */
    attribute = attribute::get(endpoint_id, OnOff::Id, OnOff::Attributes::OnOff::Id);
    err |= app_driver_light_set_power(handle, &val);
    return err;
app_driver_handle_t app_driver_light_init()
    gpio_set_direction(GPIO_NUM_15, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_23, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_22, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_21, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_20, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_16, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_18, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_9, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_13, GPIO_MODE_OUTPUT);
    gpio_set_direction(GPIO_NUM_12, GPIO_MODE_OUTPUT);
    /* Initialize led */
    led_indicator_handle_t leds[CONFIG_BSP_LEDS_NUM];
    ESP_ERROR_CHECK(bsp_led_indicator_create(leds, NULL, CONFIG_BSP_LEDS_NUM));
    led_indicator_set_hsv(leds[0], SET_HSV(DEFAULT_HUE, DEFAULT_SATURATION, DEFAULT_BRIGHTNESS));
    return (app_driver_handle_t)leds[0];
#else
    return NULL;
#endif
app_driver_handle_t app_driver_button_init()
    /* Initialize button */
    button_handle_t btns[BSP_BUTTON_NUM];
    ESP_ERROR_CHECK(bsp_iot_button_create(btns, NULL, BSP_BUTTON_NUM));
    ESP_ERROR_CHECK(iot_button_register_cb(btns[0], BUTTON_PRESS_DOWN, app_driver_button_toggle_cb, NULL));
    return (app_driver_handle_t)btns[0];
Users browsing this forum: ChatGPT-User, Qwantbot and 1 guest
