Debug stopped working with Espressif IDE
justinmreina
Contact:
Postby justinmreina » Fri Mar 14, 2025 5:45 pm
Hi, Espressif IDE recently stopped being able to launch a Debug session to my ESP32 target. Here is a procedure to reproduce and illustrate my status -
Procedure:
1. Open VS Code
2. Setup Flash Method, Port & Device Target
3. Flash Device (works!)
Output after Step 3
VS Code Example.png (75 KiB) Viewed 1583 times
4. Close VS Code
5. Open Espressif IDE
6. Delete all ESP-IDF GDB Open OCD Debugging configurations
7. Select project from toolbar drop-down -> 'New Launch Configuration...'
______* Debug
______* ESP-IDF GDB OpenOCD Debugging
______* Leave settings default
8. Launch debug session (does not launch)
Output after Step 8
Espressif IDE Example.png (79.81 KiB) Viewed 1583 times
What happened? I am observing the same effect with all of my projects now, do I need to reinstall Espressif IDE?
justinmreina
Contact:
Re: Debug stopped working with Espressif IDE
Postby justinmreina » Sat May 03, 2025 3:41 pm
This problem has persisted, I can't figure this out.
I will try a full reset again
justinmreina
Contact:
Postby justinmreina » Sat May 03, 2025 9:03 pm
Wow! Here is what I found, I can debug now with VS Code but the Espressif-IDE is not working -
Status:
  • VS Code compiles & debugs project
  • Espressif-IDE will not compile or debug project (tried v3.1.0 & v3.3.0)
Where I followed this procedure to get VS Code working again -
Pre:
  • zip all locs for safety, uninstall and clean paths. restart machine, cleaning all install locs
0. Install ESP-IDF (ref)
- 0.1 Espressif-IDE 3.1.0 with ESP-IDF v5.3.1 (ref) (to set arch & init contents, select all procs)
  • @loc C:\Sw\Espressif
- 0.2 ESP-IDF v5.4.1 (ref) (target SDK)
1. Install Espressif-IDE (ref)
  • @warn This is risky! Go KISS & follow their base flow
  • "Download: Windows - Espressif-IDE-win32.win32.x86_64"
  • @loc C:\Sw\Espressif\tools\espressif-ide\3.3.0
- Open, install configure & check for updates
  • @wksp D:\Documents\MyWorkspaces\Espressif
- Select ESP-IDF (Espressif->ESP-IDF Manager)
- Run "C:\Users\Justin\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.13_qbz5n2kfra8p0\python.exe C:\Sw\Espressif\frameworks\esp-idf-v5.4.1\tools\idf_tools.py install" (to install missing tools)
- maybe? ESP_IDF_TOOLS_PATH C:\Sw\Espressif ?
- Update Git: C:\Sw\Espressif\tools\idf-git\2.44.0\bin
- Update Python: C:\Sw\Espressif\tools\idf-python\3.11.2\python.exe
- Use an existing ESP-IDF: C:\Sw\Espressif\frameworks\esp-idf-v5.4.1
- "python -m pip install websocket-client" (it calls for from console report in Espressif-IDE)
2. Test 'hello_world'
- set IDF_COMPONENT_MANAGER env variable to '1' & restart (ref)
3. Install Visual Studio Code (ref)
- @warn Default location (some tools depend on that)
- @loc C:\Users\Justin\AppData\Local\Programs\Microsoft VS Code
- Install ESP-IDF extension (auto-update: Y)
Advanced
- ESP-IDF: Find in your system
- ESP-IDF: C:\Sw\Espressif\frameworks\esp-idf-v5.4.1
- IDF_TOOLS_PATH: C:\Sw\Espressif
- Install pip
python -m ensurepip --upgrade
- 'Configure Tools'
- 'Download Tools'
- restart PC
4. Test Program
- VS Code: flash ok
- Install IDF Component Manager (ref)
- Espressif-IDE?
- Build Not Configured Correctly.png (worked before install of IDF Component Manager?)
- Open this hello_world dir and compile with VS_Code
- Debug: N
Result:
  • VS Code is now able to debug!!!!
  • Espressif-IDE is not able to compile or debug the project
Request:
  • How can I get debug working again for Espressif-IDE?
Thank you for your time
Best Regards,
Justin
justinmreina
Contact:
Postby justinmreina » Tue May 20, 2025 5:27 pm
Hi, now debug doesn't work in either environment. I have tried a full un-install and re-install, for both the Espressif-IDE and VS Code but this is not working
How can I get my debug sessions working again? I will try another round this morning, taking detailed notes for review
justinmreina
Contact:
Postby justinmreina » Wed Jun 04, 2025 1:24 am
The 'Build Not Configured Correctly.png' bug listed above happens a lot now -
Bug:
The error message where compilation stops
This clears it up -
Resolution:
  • Clean project, remove build and close project
  • Close & re-open Espressif-IDE
  • Open project
Might not need to do all of that, but this works
justinmreina
Contact:
Postby justinmreina » Fri Jun 06, 2025 3:09 am
Ok, with diligent method & research, this all works now.
VS-Code Debug Sessions:
Espressif-IDE Debug Sessions:
  • Select your project, then create your project's run or debug configurations by opening 'Run' -> 'Run Configurations...' and double click on either 'ESP-IDF Application' or 'ESP-IDF GDB OpenOCD Debugging' to generate these.
    • And if the configuration listing blanks out, which i have observed periodically which halts everything; just create a new workspace and bring in an ESP-IDF demo to get it started
    • Here is explicit detail from my example project if useful (config)
Switching between development environments:
  • With only VS-Code open, perform a full clean with VS-Code, and now either IDE becomes available
Build Not Configured Correctly:
  • Full clean & reset, as listed above
I use my esp32_proj to capture these details, and sharing if useful -
* esp32_proj - doc\ here has context for most of these solns
All good now, sharing above if useful for someone else 😊
Users browsing this forum: PetalBot and 2 guests
