I have a ESP32E with AT commands enabled. When I connect to the ESP32 with pyserial-miniterm, I am able to get this code to work:
First example:
AT+CIPSTART="SSL","www.esp32.com",443
AT+CIPSEND=88
GET index.php HTTP/1.1
Host: www.esp32.com
Connection: close
Second example:
AT+CIPSTART="TCP","api.openweathermap.org",80
AT+CIPSEND=87
GET /data/2.5/weather?q=London,uk&APPID=fbd756d6387c660e650b533ff585c70e&units=metric
With those 2 examples, I get the HTTP data of the webpage and the weather data (second example). Miniterm EOL is CR+LF.
When I try Hercules program on PC, this works:
AT+CIPSTART="TCP","api.openweathermap.org",80$0D$0A
AT+CIPSEND=87$0D$0A
GET /data/2.5/weather?q=London,uk&APPID=fbd756d6387c660e650b533ff585c70e&units=metric$0D$0A
This on Hercules also works:
AT+CIPSTART="SSL","www.esp32.com",443$0D$0A
AT+CIPSEND=37$0D$0A
GET index.php$0D$0A
But in Hercules, I cant make this code work:
AT+CIPSEND=88
Host: www.esp32.com
Connection: close
I also tried with the $0D$0A at every line, still timeout.
I also tried Coolterm, this works:
AT+CIPSEND=87
But on Coolterm, this does not work:
AT+CIPSEND=84
Host: www.esp32.com
Connection: close
In coolterm, the whole situation:
CONNECT
OK
AT+CIPSEND=84
OK
Recv 84 bytes
SEND OK
+IPD,170:HTTP/1.1 408 Request Timeout
Date: Sun, 16 Mar 2025 11:09:39 GMT
Server: Apache
Content-Length: 221
Connection: close
Content-Type: text/html; charset=iso-8859-1
+IPD,221:<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>408 Request Timeout</title>
</head><body>
<h1>Request Timeout</h1>
<p>Server timeout waiting for the HTTP request from the client.</p>
</body></html>
CLOSED
As you see, I dont get the data back. Coolterm EOL:0D 0A
All in all, I believe the problem is somewhere with the EOL characters and the length of the message. This is what I tried:
Trying multiple CIPSEND lengths to fit new characters, new EOL characters, so in the finale I always get "SEND OK".
Tried multiple programs, I can try more, but I see that the problem is not with the AT commands themselves.
I tried adding multiple $0D$0A to every line, on both programs and different combinations of $0D$0A, but still timeout.
So yeah, I just want to have an ESP32 WIFI module I could add to any board and be able to communicate/send commands to it with any MCU. That is why I want AT commands.
ESP32 AT commands work in py-miniterm, but not in other terminal programs
Dominykas Litvaitis
Re: ESP32 AT commands work in py-miniterm, but not in other terminal programs
Hi, i don't think it is the issue about esp-at. it seems to be somethings with serial tool.
As an aid to debugging, you can turn on AT logs to see what is happening.
The AT log port output should give more logs.
python build.py menuconfig > Component config > Log output > Info (Or above Info)
python build.py menuconfig > Component config > AT > Enable ESP-AT Debug
python build.py menuconfig > Component config > AT > Enable ESP-AT Debug > Logging the data sent from AT to MCU (AT ---> MCU)
python build.py menuconfig > Component config > AT > Enable ESP-AT Debug > Logging the data sent from AT to MCU (AT ---> MCU) > The maximum length of the data sent from AT to MCU to be logged > 8192
python build.py menuconfig > Component config > AT > Enable ESP-AT Debug > Logging the data received by AT from MCU (AT <---- MCU)
python build.py menuconfig > Component config > AT > Enable ESP-AT Debug > Logging the data received by AT from MCU (AT <---- MCU) > The maximum length of the data received by AT from MCU to be logged > 8192
