I2S audio distortion issue
Sophi9999
Postby Sophi9999 » Thu Mar 20, 2025 9:07 pm
hello!
I have an ESP32-S3-WROOM on a custom PCB.
I'm retrieving a wav file (a song) from an SD card via SPI and playing it through DAC PCM5102A using I2S.
I am able to retrieve any wav file from the SD card and write the name of the file to the shell.
I am also able to play a generated tone with I2C through the DAC.
The problem is that after the wav file plays for a split second, it gets distorted.
I have an oscilloscope here, and have test points on BCLK, LRCK, and DOUT lines.
I've seen this issue reported in a few places, Reddit, Arduino forum and others, but no solution.
I'm working in microPython but if microPython is missing support for a needed parameter I can switch.
Setup
i2s = I2S(
    0,  # I2S bus ID (use 0 or 1)
    sck=Pin(35),   # BCLK (Bit Clock)
    ws=Pin(36),    # LRCK (Word Select / Left-Right Clock)
    sd=Pin(37),    # DOUT (Data Out)
    mode=I2S.TX,   # Transmit mode
    bits=16,       # 16-bit audio
    #bits=32,       # 32-bit audio
    #format=I2S.STEREO,
    format=I2S.MONO,
    rate=44100,    # Standard audio rate (adjust as needed)
    #rate=22500,
    ibuf=100000     # Buffer size
def play_specific_sound():
    file_path = "/sd/final_pump_clip.wav"
    #if file_path not in os.listdir("/sd"):
    if "final_pump_clip.wav" not in os.listdir("/sd"):
        print("File not found:", file_path)
        return
    print("Playing:", file_path)
    with open(file_path, "rb") as f:
        f.read(44)  # Skip WAV header
        while True:
            audio_data = f.read(128)  # Read in chunks
            if not audio_data:
                break
            i2s.write(audio_data)  # Send to DAC
            # Convert 16-bit PCM to properly aligned I2S 16-bit format
    print("Playback finished")
Thank you!
ahsrabrifat
Re: I2S audio distortion issue
Postby ahsrabrifat » Fri Mar 21, 2025 10:40 am
You are able to retrieve wav files from the SD card and write the name of the file to the shell. You are also able to play a generated tone with I2C through the DAC. That means your PCB is working. It's not a matter of manufacturing error. The problems that you're facing may occur due to buffer handling, I2S format mismatches, or timing problems. You can check the answers here:
https://esp32.com/viewtopic.php?t=30561
MicroController
Postby MicroController » Fri Mar 21, 2025 1:10 pm
I'd try increasing the 'chunk' size first, like audio_data = f.read(1024) or f.read(2048) or even more.
xiqwertyui
Postby xiqwertyui » Fri Mar 21, 2025 3:26 pm
Hard to tell where exactly the problem is. But speaking with the parameter, It's not clear exactly which i2s format micropython calls the underlying i2s controller. Maybe check the format configuration (Pin16 of PCM5102A) in your PCB first.
Sophi9999
Postby Sophi9999 » Fri Mar 21, 2025 4:12 pm
Thanks all!
Pin 16 of PCM5102A is tied to GND: Audio format selection : I2S (Low) / Left-justified (High)
I am powering the PCM5102A DAC from a regulator on the board, not from ESP32 3.3V.
Supply looks stable.
Increasing f.read(2048) gives a timeout error. f.read(1024) does not help.
I downloaded more wavs to test and similar error... speed and sound distortion does all point to rate/ buffer errors.
However, short of trial and error, I don't know how to change these.
using ffmpeg to bring wavs to the same level does seems to change the wav but does not seem to match when I play the sound.
ffmpeg -i scuse_me.wav -acodec pcm_s16le -ar 44100 -ac 2 scuse_me2.wav
xiqwertyui
Postby xiqwertyui » Sun Mar 23, 2025 6:16 am
Assuming your PCB is ok, and assuming their library is ok, then the problem may be with your code. Is your wav file single channel, if not you can't write it to i2s directly like the example code you show does.
Users browsing this forum: DuckDuckGo [Bot], johnATdeveillance and 1 guest
