Weird issue with breakout boards
instantasset
Postby instantasset » Fri Mar 21, 2025 1:12 am
I have an esp32-wroom devkit c that works as intended. However, when I try to install it into a breakout board made for this dev kit, it enters an endless watchdog timer loop when I apply power (usb-c).
If I power the esp32 first, then install it into the breakout board, the esp32 functions correctly. If I install it, then power it up it malfunctions? I have tried 3 different breakout boards made by different companies and have the same result. Can anyone help me understand whats happening?
Code: Untitled.cpp Select all
Re: Weird issue with breakout boards
Postby Sprite » Fri Mar 21, 2025 2:12 am
Can you post the specific log that is generated when the ESP32 is in the situation where it resets because of the watchdog timeout? Also, just to confirm: aside from the devkit, the breadboard is empty, right?
Users browsing this forum: Applebot, Qwantbot and 1 guest
