ESP32-P4 Example Build Error
Posted: Mon Mar 24, 2025 7:42 pm
I am trying to build the ESP32-P4 "esp_brookesia_phone" example, but I am getting errors. I'm using IDF V5.4 and followed the readme instructions. Any ideas would be appreciated. Here's the log file output. The error is near the bottom.
info: INFO: Symbol BSP_I2S_NUM defined in multiple locations (see below). Please check if this is a correct behavior or a random name match:
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\common_components\bsp_extra\Kconfig:2
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\esp_brookesia_phone\managed_components\espressif__esp32_p4_function_ev_board\Kconfig:30
info: INFO: Symbol ESP_SDIO_PIN_D1 defined in multiple locations (see below). Please check if this is a correct behavior or a random name match:
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\esp_brookesia_phone\managed_components\espressif__esp_hosted\Kconfig:487
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\esp_brookesia_phone\managed_components\espressif__esp_hosted\Kconfig:461
ninja: error: mkdir(esp-idf/esp_wifi/CMakeFiles/__idf_esp_wifi.dir/C_/esp-dev-kits/examples/esp32-p4-function-ev-board/examples/esp_brookesia_phone/managed_components/espressif__esp_wifi_remote): No such file or directory
