USBCDC without DTR?
mgsmgs
USBCDC without DTR?
Postby mgsmgs » Wed Mar 26, 2025 10:19 am
Hi!
I successfully use serial port over cdc with a s3 otg board (2 usb ports).
I would like not to use the DTR on the computer side.
If I disable it (computer side) the data is not sent from the esp chip to the computer and my device serves as another device simulator to test some software implementation (which i cannot change).
Is there a way to bypass the DTR thing and let the chip send data to the computer even if its DTR flag is not enabled?
Thanks and kind regards!
I use the sample code from USB>USBSerial without any modification.
#ifndef ARDUINO_USB_MODE
#error This ESP32 SoC has no Native USB interface
#elif ARDUINO_USB_MODE == 1
#warning This sketch should be used when USB is in OTG mode
void setup() {}
void loop() {}
#else
#include "USB.h"
#if !ARDUINO_USB_CDC_ON_BOOT
USBCDC USBSerial;
#endif
static void usbEventCallback(void *arg, esp_event_base_t event_base, int32_t event_id, void *event_data) {
  if (event_base == ARDUINO_USB_EVENTS) {
    arduino_usb_event_data_t *data = (arduino_usb_event_data_t *)event_data;
    switch (event_id) {
      case ARDUINO_USB_STARTED_EVENT: Serial.println("USB PLUGGED"); break;
      case ARDUINO_USB_STOPPED_EVENT: Serial.println("USB UNPLUGGED"); break;
      case ARDUINO_USB_SUSPEND_EVENT: Serial.printf("USB SUSPENDED: remote_wakeup_en: %u\n", data->suspend.remote_wakeup_en); break;
      case ARDUINO_USB_RESUME_EVENT:  Serial.println("USB RESUMED"); break;
      default: break;
  } else if (event_base == ARDUINO_USB_CDC_EVENTS) {
    arduino_usb_cdc_event_data_t *data = (arduino_usb_cdc_event_data_t *)event_data;
    switch (event_id) {
      case ARDUINO_USB_CDC_CONNECTED_EVENT:    Serial.println("CDC CONNECTED"); break;
      case ARDUINO_USB_CDC_DISCONNECTED_EVENT: Serial.println("CDC DISCONNECTED"); break;
      case ARDUINO_USB_CDC_LINE_STATE_EVENT:   Serial.printf("CDC LINE STATE: dtr: %u, rts: %u\n", data->line_state.dtr, data->line_state.rts); break;
      case ARDUINO_USB_CDC_LINE_CODING_EVENT:
        Serial.printf(
          "CDC LINE CODING: bit_rate: %lu, data_bits: %u, stop_bits: %u, parity: %u\n", data->line_coding.bit_rate, data->line_coding.data_bits,
          data->line_coding.stop_bits, data->line_coding.parity
      case ARDUINO_USB_CDC_RX_EVENT:
        Serial.printf("CDC RX [%u]:", data->rx.len);
          uint8_t buf[data->rx.len];
          size_t len = USBSerial.read(buf, data->rx.len);
          Serial.write(buf, len);
        Serial.println();
      case ARDUINO_USB_CDC_RX_OVERFLOW_EVENT: Serial.printf("CDC RX Overflow of %d bytes", data->rx_overflow.dropped_bytes); break;
      default: break;
  Serial.setDebugOutput(true);
  USB.onEvent(usbEventCallback);
  USBSerial.onEvent(usbEventCallback);
  USBSerial.begin();
  USB.begin();
  while (Serial.available()) {
    size_t l = Serial.available();
    uint8_t b[l];
    l = Serial.read(b, l);
    USBSerial.write(b, l);
#endif /* ARDUINO_USB_MODE */
Users browsing this forum: Applebot, Qwantbot and 1 guest
