Execute Command Post Build - CMake
egionet
Postby egionet » Sat Mar 29, 2025 7:02 am
I am trying to execute two commands after a component is built, and I can't figure out how to set the TARGET properly for the CMake add custom command. I am using PlatformIO and realize that I can execute scripts post-build by configuring the .ini file, but I am trying to leverage CMake instead of a Python or Powershell script.
The CMakeList.txt in the component directory pre-build updates the component's version number in the header, idf_component.yml, and library.json files through templates. The last step that I am trying to figure out is publishing the components to PlatformIO library and ESP-IDF component registries via commands. Any help with this would be greatly appreciated.
CMakeList.txt
# Versioning Information for ESP-IDF Components with GitHub, GitVersion and CMake
# Inspired by: https://www.esp32.com/viewtopic.php?f=2&t=45054&p=146150#p146150
# Install Git-Version via command prompt: dotnet tool install --global GitVersion.Tool
# Create a GitVersion.yml file in the root of your project with the following content:
#   major-version-bump-message: '\+semver:\s?(breaking|major)'
#   minor-version-bump-message: '\+semver:\s?(feature|minor)'
#   patch-version-bump-message: '\+semver:\s?(fix|patch)'
#   commit-message-incrementing: Enabled
# Download CMake JSON-Parser: https://github.com/sbellus/json-cmake/blob/master/JSONParser.cmake
# Copy the CMake JSONParser.cmake file to the tools/cmake directory of your ESP-IDF installation.
# i.e. C:\Users\user\.platformio\packages\framework-espidf\tools\cmake
include($ENV{IDF_PATH}/tools/cmake/version.cmake)
include($ENV{IDF_PATH}/tools/cmake/JSONParser.cmake RESULT_VARIABLE JSONPARSER_FOUND)
# string compare JSONParser library availability
string(COMPARE NOTEQUAL "${JSONPARSER_FOUND}" "NOTFOUND" STR_CMP_RESULT)
# validate JSONParser library, version.h.in, pio_lib_sync.py, esp_cmp_sync.py,
# library.json.in, and idf_component.yml.in files are available for preprocessing
if(STR_CMP_RESULT EQUAL 1 AND EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/include/version.h.in"
    AND EXISTS "${COMPONENT_DIR}/include/library.json.in" AND EXISTS "${COMPONENT_DIR}/include/idf_component.yml.in")
    # Get latest versioning information from git repository with GitVersion
    execute_process(
        COMMAND dotnet-gitversion
        WORKING_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}
        OUTPUT_VARIABLE GIT_VERSION_OUTPUT
        OUTPUT_STRIP_TRAILING_WHITESPACE
    # Instantiate json variable
    sbeParseJson(GIT_VERSION_JSON GIT_VERSION_OUTPUT)
    # Parse versioning variables from json output
    set(GIT_VERSION_DATE  ${GIT_VERSION_JSON.CommitDate})
    set(GIT_SEM_VERSION   ${GIT_VERSION_JSON.MajorMinorPatch})
    set(GIT_VERSION_MAJOR ${GIT_VERSION_JSON.Major})
    set(GIT_VERSION_MINOR ${GIT_VERSION_JSON.Minor})
    set(GIT_VERSION_PATCH ${GIT_VERSION_JSON.Patch})
    set(GIT_FULL_SEM_VER  ${GIT_VERSION_JSON.FullSemVer})
    set(GIT_SHORT_SHA     ${GIT_VERSION_JSON.ShortSha})
    # Release json variable
    sbeClearJson(GIT_VERSION_JSON)
    # Parse component name from component path
    get_filename_component(COMPONENT_NAME "${COMPONENT_DIR}" NAME)
    # Components should be named as "esp_<component_name>"
    string(FIND "${COMPONENT_NAME}" "esp_" ESP_PREFIX)
    # Check if the component name starts with "esp_"
    if(ESP_PREFIX EQUAL -1)
        # Use the component name as is
        string(CONCAT COMPONENT_HEADER_NAME "" "${COMPONENT_NAME}")
    else()
        # Parse component file name from component name
        string(REPLACE "esp_" "" COMPONENT_HEADER_NAME "${COMPONENT_NAME}")
    endif()
    # Set the component header name to upper case
    string(TOUPPER "${COMPONENT_HEADER_NAME}" COMPONENT_HEADER_NAME_UPPER)
    # Generate C header file from template with versioning information
    configure_file( "${CMAKE_SOURCE_DIR}/include/version.h.in" "${COMPONENT_DIR}/include/${COMPONENT_HEADER_NAME}_version.h" @ONLY )
    # Generate json library file from template with versioning information
    configure_file( "${COMPONENT_DIR}/include/library.json.in" "${COMPONENT_DIR}/library.json" @ONLY )
    # Generate yml idf component file from template with versioning information
    configure_file( "${COMPONENT_DIR}/include/idf_component.yml.in" "${COMPONENT_DIR}/idf_component.yml" @ONLY )
endif()
# Register the component
idf_component_register(
    SRCS uuid.c
    INCLUDE_DIRS include
# Get global variables from idf build property
idf_build_get_property(cmp_reg_sync COMPONENT_REGISTRY_SYNC)
idf_build_get_property(cmp_reg_o COMPONENT_REGISTRY_OWNER)
# Validate if the component should be synchronized with esp-idf and platformio registries
string(COMPARE EQUAL "${cmp_reg_sync}" "ENABLED" STR_CMP_RESULT)
# Register the component with the ESP-IDF components and platformio registries
if(STR_CMP_RESULT EQUAL 1)
    #add_library(myPlugin MODULE uuid.c)
    #if(NOT CMAKE_BUILD_EARLY_EXPANSION)
        #add_custom_command(
        #    TARGET uuid.c
        #    POST_BUILD
        #    COMMAND powershell compote component register --name ${COMPONENT_NAME} --project-dir '${COMPONENT_DIR}' --dest-dir '${CMAKE_CURRENT_SOURCE_DIR}/log'
    #endif()
    # Package the component and upload it to the ESP-IDF component registry
    execute_process(
        COMMAND powershell compote component upload --name "${COMPONENT_NAME}" --project-dir '"${COMPONENT_DIR}"' --dest-dir '"${CMAKE_CURRENT_SOURCE_DIR}/log"'
        OUTPUT_FILE "${CMAKE_CURRENT_SOURCE_DIR}/log/esp_cmp_sync.log"
    endif()
    # Package the components and upload it to the platformio library registry
    #execute_process(
    #    COMMAND powershell pio pkg publish '"${COMPONENT_DIR}"' --owner "${cmp_reg_o}" --type library --no-interactive
    #    WORKING_DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}
    #    OUTPUT_FILE "${CMAKE_CURRENT_SOURCE_DIR}/log/pio_lib_sync.log"
endif()
Regards,
Eric Gionet P.Tech.(Eng.), CIOTP, SMIEEE
MicroController
Re: Execute Command Post Build - CMake
Postby MicroController » Sat Mar 29, 2025 8:24 am
You should be able to reference the target of the current component via ${COMPONENT_LIB}.
egionet
Postby egionet » Sat Mar 29, 2025 9:01 am
Thanks for the suggestion. I just gave it a go and got the following results.
If I register the component before calling add_custom_command, I do not get any errors, but the command isn't triggering an action.
    execute_process(
    else()
    endif()
endif()
        add_custom_command(
            TARGET ${COMPONENT_LIB}
            POST_BUILD
    endif()
    #execute_process(
    #    COMMAND powershell compote component upload --name "${COMPONENT_NAME}" --project-dir '"${COMPONENT_DIR}"' --dest-dir '"${CMAKE_CURRENT_SOURCE_DIR}/log"'
    #    OUTPUT_FILE "${CMAKE_CURRENT_SOURCE_DIR}/log/esp_cmp_sync.log"
    #endif()
    #execute_process(
endif()
    SRCS uuid.c
If I register the component at the end, per the above, I get an `add_custom_command Wrong syntax. TARGET or OUTPUT must be specified` error. And if I don't add the "if(NOT CMAKE_BUILD_EARLY_EXPANSION)" condition I get a "add_custom_command is not scriptable" error.
Regards,
egionet
Postby egionet » Sat Mar 29, 2025 2:28 pm
I am starting to suspect PlatformIO as the culprit. I disabled Make, CMake, and ESP-IDF extensions and I am no longer getting compile errors, but the custom triggers are not getting asserted as expected.
include( $ENV{IDF_PATH}/tools/cmake/version.cmake )
include( $ENV{IDF_PATH}/tools/cmake/JSONParser.cmake RESULT_VARIABLE JSONPARSER_FOUND )
string( COMPARE NOTEQUAL "${JSONPARSER_FOUND}" "NOTFOUND" STR_CMP_RESULT )
    execute_process(
    sbeParseJson( GIT_VERSION_JSON GIT_VERSION_OUTPUT )
    set( GIT_VERSION_DATE  ${GIT_VERSION_JSON.CommitDate} )
    set( GIT_SEM_VERSION   ${GIT_VERSION_JSON.MajorMinorPatch} )
    set( GIT_VERSION_MAJOR ${GIT_VERSION_JSON.Major} )
    set( GIT_VERSION_MINOR ${GIT_VERSION_JSON.Minor} )
    set( GIT_VERSION_PATCH ${GIT_VERSION_JSON.Patch} )
    set( GIT_FULL_SEM_VER  ${GIT_VERSION_JSON.FullSemVer} )
    set( GIT_SHORT_SHA     ${GIT_VERSION_JSON.ShortSha} )
    sbeClearJson( GIT_VERSION_JSON )
    get_filename_component( COMPONENT_NAME "${COMPONENT_DIR}" NAME )
    string( FIND "${COMPONENT_NAME}" "esp_" ESP_PREFIX )
        string( CONCAT COMPONENT_HEADER_NAME "" "${COMPONENT_NAME}" )
    else()
        string( REPLACE "esp_" "" COMPONENT_HEADER_NAME "${COMPONENT_NAME}" )
    endif()
    string( TOUPPER "${COMPONENT_HEADER_NAME}" COMPONENT_HEADER_NAME_UPPER )
endif()
    SRCS uuid.c
idf_build_get_property( cmp_reg_sync COMPONENT_REGISTRY_SYNC )
idf_build_get_property( cmp_reg_o COMPONENT_REGISTRY_OWNER )
string( COMPARE EQUAL "${cmp_reg_sync}" "ENABLED" STR_CMP_RESULT )
    add_custom_target(
        cmp_reg_sync ALL
        COMMAND python ${CMAKE_CURRENT_SOURCE_DIR}/stg/pio_lib_sync.py OK
        COMMENT "python testing with add_custom_command..."
    add_dependencies( ${COMPONENT_LIB} cmp_reg_sync )
    add_custom_command(
        POST_BUILD
endif()
Regards,
egionet
Postby egionet » Sun Mar 30, 2025 5:50 am
I implemented an example in VS Code with the ESP-IDF extension and encountered the same behavior i.e. commands are not getting asserted at specified build milestones. Additional details are available here: https://github.com/K0I05/cmake_components_20250329. Open any suggestions. In my case, I need the command or process to get asserted post-build.
Regards,
MicroController
Postby MicroController » Sun Mar 30, 2025 8:01 am
You may find some useful info here.
Btw, the "cmake way" to do what you want would be to define a dedicated target for the upload/... step and have it depend on the component build target.
egionet
Postby egionet » Fri Apr 04, 2025 8:58 am
I posted the same question in the CMake forum, and someone clarified a condition that has to be met: the target has to be in the same directory as the caller (i.e. CMakeLists.txt). VS-Code with PlatformIO builds the project in a cached folder; therefore, it will not trigger as expected. However, a suggestion was made to utilize a custom target with the custom command.
Regards,
Users browsing this forum: Applebot, Baidu [Spider], Google [Bot], RilasGckley and 1 guest
