Subject : How much Heap Memory will BLE satck use in esp idf 5.0.7
Chip revision : ESP32 Chip is ESP32-D0WDQ6 (revision v1.0)
Configuration 16 Mb Flash memory, 2 Mb PSRAM
I Need this stack in my application
Zigbee
FOTA
WiFi
MQTT[Secure,Unsecure]
LED
Button
Memory Related 1 task
And BLE [Bluedroid]
Could you tell me how much minimum HEAP memory is required for BLE, Because it is using large number of heap [stack].
Regards,
Kesha
kesha.modhia
MicroController
Re: How much Heap Memory will BLE satck use in esp idf 5.0.7
This may help a bit:
https://docs.espressif.com/projects/esp ... tack-sizes
Also, you can call esp_bt_mem_release(ESP_BT_MODE_CLASSIC_BT) to regain some RAM.
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot], meta-externalagent and 3 guests
