ESP32-S3-BOX-3 SCREEN and ARDUINO IDE
antares.atlantide
Postby antares.atlantide » Mon Apr 14, 2025 12:57 pm
I would like to know if it's possible to simply display "Hello World" on the ESP32-S3-Box-3 screen using the Arduino IDE. Since I've turned the program , it's almost impossible. ESP32_Display_Panel is intended for ESP32 boards, not ESP32S3 boards. I'm waiting for a clear and simple answer. I would be delighted if you could suggest a simple test solution that works.
#include "TFT_eSPI.h"
#include "SPI.h"
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
tft.init();
tft.setRotation(1);
tft.fillScreen(TFT_RED);
tft.setTextColor(TFT_WHITE, TFT_YELLOW);
tft.setTextSize(2);
tft.setCursor(0, 0, 2);
tft.printf("HELLO WORLD");
void loop{
Lvhaiyu
Re: ESP32-S3-BOX-3 SCREEN and ARDUINO IDE
Postby Lvhaiyu » Tue Apr 15, 2025 11:54 am
The example code you shared is not from the ESP32_Display_Panel library, but rather from the TFT_eSPI library. For information on how to use ESP32_Display_Panel, please refer to the following link:
https://github.com/esp-arduino-libs/ESP ... st-example
