Invalid initializers used in esp-idf demos
justinmreina
Contact:
Postby justinmreina » Tue Apr 22, 2025 8:06 pm
Your demos are using zero-initializers which is not supported by your tool yet -
Issue:
Example:
generic_gpio: gpio_example_main.c
Zero Initializer Example.png (109.76 KiB) Viewed 8569 times
Yikes! This is why I also use memset for explicit initialization, and leave the declaration explicitly uninitialized to support this -
My Pref:
MyStruct example_struct;
//Init
memset(&example_struct, 0x00, sizeof(MyStruct));
Request:
  • Can we update the esp-idf to valid C17 initializers, or update the ESP-IDF to C23?
Thank you guys for your time, and for this tool! Enjoying my work here
Re: Invalid initializers used in esp-idf demos
Postby Sprite » Wed Apr 23, 2025 2:28 am
We use GCC, and the empty initializer being valid has been a GCC extension since forever. GCC will complain about it not being in the C specs if you ask it to be really pedantic, but esp-idf is not set to that mode, so it just happily does what you expect it to do even in C17 mode.
justinmreina
Contact:
Postby justinmreina » Wed Apr 23, 2025 4:27 am
Interesting!
Thanks for the detail Sprite, I will be in review I am learning a lot here now
Best,
Justin
justinmreina
Contact:
Postby justinmreina » Wed Apr 23, 2025 4:30 am
I have also had zero-initializers bug out in the past, on a few different platforms - unexpectedly. This is why I strictly employ memset() now for structure & array initializations
Back in a few
