ESP32-C3 MQTT TCP
hoo_wave
ESP32-C3 MQTT TCP
Postby hoo_wave » Wed Apr 23, 2025 3:12 am
I clone mqtt tcp demo from github, set wifi ssid and password
After I flash it into esp32-c3 develop board, it can connect wifi and got ip successfully
But it stopped here, mqtt app didn't start
I put a esp_log in mqtt_app_start() function, it didn't print in terminal
How to start mqtt?
I (264) boot: Loaded app from partition at offset 0x10000
I (264) boot: Disabling RNG early entropy source...
I (276) cpu_start: Unicore app
I (285) cpu_start: Pro cpu start user code
I (285) cpu_start: cpu freq: 160000000 Hz
I (285) app_init: Application information:
I (288) app_init: Project name: mqtt_tcp
I (293) app_init: App version: 1
I (297) app_init: Compile time: Apr 23 2025 10:53:34
I (303) app_init: ELF file SHA256: e7f7e6213...
I (308) app_init: ESP-IDF: v5.3.1
I (313) efuse_init: Min chip rev: v0.3
I (318) efuse_init: Max chip rev: v1.99
I (323) efuse_init: Chip rev: v1.1
I (328) heap_init: Initializing. RAM available for dynamic allocation:
I (335) heap_init: At 3FC9A650 len 000259B0 (150 KiB): RAM
I (341) heap_init: At 3FCC0000 len 0001C710 (113 KiB): Retention RAM
I (348) heap_init: At 3FCDC710 len 0000294C (10 KiB): Retention RAM
I (355) heap_init: At 50000200 len 00001DE8 (7 KiB): RTCRAM
I (362) spi_flash: detected chip: generic
I (366) spi_flash: flash io: dio
W (370) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (383) sleep: Configure to isolate all GPIO pins in sleep state
I (390) sleep: Enable automatic switching of GPIO sleep configuration
I (397) main_task: Started on CPU0
I (407) main_task: Calling app_main()
I (407) mqtt_example: [APP] Startup..
I (407) mqtt_example: [APP] Free memory: 272468 bytes
I (407) mqtt_example: [APP] IDF version: v5.3.1
I (417) example_connect: Start example_connect.
I (417) pp: pp rom version: 74f9620
I (427) net80211: net80211 rom version: 74f9620
I (437) wifi:wifi driver task: 3fca2e78, prio:23, stack:6656, core=0
I (437) wifi:wifi firmware version: ccaebfa
I (437) wifi:wifi certification version: v7.0
I (447) wifi:config NVS flash: enabled
I (447) wifi:config nano formating: disabled
I (447) wifi:Init data frame dynamic rx buffer num: 32
I (457) wifi:Init static rx mgmt buffer num: 5
I (457) wifi:Init management short buffer num: 32
I (467) wifi:Init dynamic tx buffer num: 32
I (467) wifi:Init static tx FG buffer num: 2
I (477) wifi:Init static rx buffer size: 1600
I (477) wifi:Init static rx buffer num: 10
I (477) wifi:Init dynamic rx buffer num: 32
I (487) wifi_init: rx ba win: 6
I (487) wifi_init: accept mbox: 6
I (497) wifi_init: tcpip mbox: 32
I (497) wifi_init: udp mbox: 6
I (497) wifi_init: tcp mbox: 6
I (507) wifi_init: tcp tx win: 5760
I (507) wifi_init: tcp rx win: 5760
I (517) wifi_init: tcp mss: 1440
I (517) wifi_init: WiFi IRAM OP enabled
I (517) wifi_init: WiFi RX IRAM OP enabled
I (527) phy_init: phy_version 1180,01f2a49,Jun 4 2024,16:34:25
I (567) wifi:mode : sta (18:8b:0e:88:81:cc)
I (567) wifi:enable tsf
I (567) example_connect: Connecting to ZTE_E0D5B6...
W (567) wifi:Password length matches WPA2 standards, authmode threshold changes from OPEN to WPA2
I (577) example_connect: Waiting for IP(s)
I (3267) wifi:new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1, snd_ch_cfg:0x0
I (3267) wifi:state: init -> auth (0xb0)
I (3267) wifi:state: auth -> assoc (0x0)
I (3287) wifi:state: assoc -> run (0x10)
I (3307) wifi:connected with ZTE_E0D5B6, aid = 8, channel 1, BW20, bssid = 10:3c:59:e0:d5:b6
I (3307) wifi:security: WPA2-PSK, phy: bgn, rssi: -32
I (3307) wifi:pm start, type: 1
I (3307) wifi:dp: 1, bi: 102400, li: 3, scale listen interval from 307200 us to 307200 us
I (3317) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000
I (3327) wifi:AP's beacon interval = 102400 us, DTIM period = 3
I (4337) esp_netif_handlers: example_netif_sta ip: 192.168.0.134, mask: 255.255.255.0, gw: 192.168.0.1
I (4337) example_connect: Got IPv4 event: Interface "example_netif_sta" address: 192.168.0.134
static void mqtt_app_start(void)
    esp_mqtt_client_config_t mqtt_cfg = {
        .broker.address.uri = CONFIG_BROKER_URL,
    ESP_LOGI(TAG, "mqtt_app_start..."); //This is the esp_log which i insert
#if CONFIG_BROKER_URL_FROM_STDIN
    char line[128];
    if (strcmp(mqtt_cfg.broker.address.uri, "FROM_STDIN") == 0) {
        int count = 0;
        printf("Please enter url of mqtt broker\n");
        while (count < 128) {
            int c = fgetc(stdin);
            if (c == '\n') {
                line[count] = '\0';
            } else if (c > 0 && c < 127) {
                line[count] = c;
                ++count;
            vTaskDelay(10 / portTICK_PERIOD_MS);
        mqtt_cfg.broker.address.uri = line;
        printf("Broker url: %s\n", line);
        ESP_LOGE(TAG, "Configuration mismatch: wrong broker url");
        abort();
#endif /* CONFIG_BROKER_URL_FROM_STDIN */
    esp_mqtt_client_handle_t client = esp_mqtt_client_init(&mqtt_cfg);
    /* The last argument may be used to pass data to the event handler, in this example mqtt_event_handler */
    esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt_event_handler, NULL);
    esp_mqtt_client_start(client);
nopnop2002
Contact:
Re: ESP32-C3 MQTT TCP
Postby nopnop2002 » Wed Apr 23, 2025 6:38 am
Here is my log output.
I (3362) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000
I (3432) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (4462) esp_netif_handlers: example_netif_sta ip: 192.168.10.113, mask: 255.255.255.0, gw: 192.168.10.1
I (4462) example_connect: Got IPv4 event: Interface "example_netif_sta" address: 192.168.10.113
I (4462) example_common: Connected to example_netif_sta
I (4472) example_common: - IPv4 address: 192.168.10.113,
I (4472) mqtt_example: Other event id:7
I (4482) main_task: Returned from app_main()
I (5172) mqtt_example: MQTT_EVENT_CONNECTED
It looks like you're hanging inside example_connect.
Do you have other AP?
hoo_wave
Postby hoo_wave » Wed Apr 23, 2025 7:57 am
OK,Thanks for your reply!!
As I change another AP, the problem solved.
It seems like something wrong with previous AP,it stoped at Got IPv4 event, befor Connected to example_netif_sta
Could you please tell me what's probably wrong with the AP? or how to configure my project
The AP can not be changed
nopnop2002
Contact:
Postby nopnop2002 » Fri Apr 25, 2025 3:19 pm
Here is the explanation for the example_connect() Function.
https://github.com/espressif/esp-idf/tr ... connection
The simple example_connect() function does not handle timeouts, does not gracefully handle various error conditions, and is only suited for use in examples. When developing real applications, this helper function needs to be replaced with full Wi-Fi / Ethernet connection handling code. Such code can be found in examples/wifi/getting_started/ and examples/ethernet/basic/ examples.
Users browsing this forum: Bing [Bot] and 2 guests
