ESP32CAM (AI-thinker possibly?) not working with ESP-WHO
sims12345
Postby sims12345 » Wed Apr 23, 2025 8:33 pm
Hello, I was hoping for some help on setting up the examples with esp32CAM using esp-idf.
What I have done;
- Pulled the repo version v1.1.0 which is the old branch compatible with esp32
- secondly, I configured menuconfig with camera configuration to be "esp32 cam ai thinker" instead of the esp-eye
- thirdly, did idf.py set-target esp32
- and then further I just build, flashed and monitor the terminal example of human_face_detection.
The problem: When I monitor the esp32CAM I'm not receiving any error, but there's no output onto the terminal on my pc in terms face detected or not detected for some reason.
Does anyone know why that could be the issue? Below is the code of that example as well as the link to the code in the github 1.1.0V branch.
// examples/human_face_detection/terminal/main/app_main.cpp
#include "who_camera.h"
#include "who_human_face_detection.hpp"
static QueueHandle_t xQueueAIFrame = NULL;
extern "C" void app_main()
    // 1) Create a 2-deep queue of camera frames
    xQueueAIFrame = xQueueCreate(2, sizeof(camera_fb_t *));
    // 2) Start the camera driver (RGB565 @ QVGA)
    register_camera(PIXFORMAT_RGB565, FRAMESIZE_QVGA, 2, xQueueAIFrame);
    // 3) Hook up the face-detection task (no event/result queues → uses built-in print & draw)
    register_human_face_detection(
        xQueueAIFrame,
   // input frame queue
        NULL,
            // no on/off event queue  (always running)
        NULL,
            // no result status queue (results printed internally)
        NULL,
            // no frame-out queue
        true
             // return FB buffer automatically
Note: I am using an esp32cam from amazon that came with the usb to uart bridge where the esp32 cam plugs in.
Note 2: Only when I remove the camera does it start printing some output that it failed to get a frame.
����I (28) boot: ESP-IDF v5.0.8-436-ga7d6b07851 2nd stage bootloader
I (28) boot: compile time 22:08:22
I (28) boot: Multicore bootloader
I (33) boot: chip revision: v1.1
I (36) qio_mode: Enabling default flash chip QIO
I (42) boot.esp32: SPI Speed : 80MHz
I (46) boot.esp32: SPI Mode : QIO
I (51) boot.esp32: SPI Flash Size : 4MB
I (56) boot: Enabling RNG early entropy source...
I (61) boot: Partition Table:
I (64) boot: ## Label Usage Type ST Offset Length
I (72) boot: 0 factory factory app 00 00 00010000 003c0000
I (79) boot: 1 nvs WiFi data 01 02 003d0000 00004000
I (87) boot: 2 fr unknown 20 20 003e0000 00020000
I (94) boot: End of partition table
I (98) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=66404h (418820) map
I (222) esp_image: segment 1: paddr=0007642c vaddr=3ffb0000 size=03938h ( 14648) load
I (227) esp_image: segment 2: paddr=00079d6c vaddr=40080000 size=062ach ( 25260) load
I (236) esp_image: segment 3: paddr=00080020 vaddr=400d0020 size=65710h (415504) map
I (350) esp_image: segment 4: paddr=000e5738 vaddr=400862ac size=106c0h ( 67264) load
I (384) boot: Loaded app from partition at offset 0x10000
I (384) boot: Disabling RNG early entropy source...
I (395) cpu_start: Multicore app
I (396) quad_psram: This chip is ESP32-D0WD
I (397) esp_psram: Found 8MB PSRAM device
I (398) esp_psram: Speed: 80MHz
I (402) esp_psram: PSRAM initialized, cache is in low/high (2-core) mode.
W (409) esp_psram: Virtual address not enough for PSRAM, map as much as we can. 4MB is mapped
I (418) cpu_start: Pro cpu up.
I (422) cpu_start: Starting app cpu, entry point is 0x40081714
0x40081714: call_start_cpu1 at C:/Espressif/frameworks/esp-idf-v5.0-release/components/esp_system/port/cpu_start.c:147
I (0) cpu_start: App cpu up.
I (940) esp_psram: SPI SRAM memory test OK
I (948) cpu_start: Pro cpu start user code
I (948) cpu_start: cpu freq: 240000000 Hz
I (948) cpu_start: Application information:
I (951) cpu_start: Project name: human_face_detection_terminal
I (958) cpu_start: App version: v1.1.0-dirty
I (963) cpu_start: Compile time: Apr 23 2025 22:05:39
I (969) cpu_start: ELF file SHA256: 52e7b4789baf0d5d...
I (975) cpu_start: ESP-IDF: v5.0.8-436-ga7d6b07851
I (981) cpu_start: Min chip rev: v0.0
I (986) cpu_start: Max chip rev: v3.99
I (991) cpu_start: Chip rev: v1.1
I (996) heap_init: Initializing. RAM available for dynamic allocation:
I (1003) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1009) heap_init: At 3FFB6A50 len 000295B0 (165 KiB): DRAM
I (1015) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1022) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1028) heap_init: At 4009696C len 00009694 (37 KiB): IRAM
I (1035) esp_psram: Adding pool of 4096K of PSRAM memory to heap allocator
I (1043) spi_flash: detected chip: generic
I (1047) spi_flash: flash io: qio
I (1057) app_start: Starting scheduler on CPU0
I (1057) app_start: Starting scheduler on CPU1
I (1057) main_task: Started on CPU0
I (1067) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (1067) main_task: Calling app_main()
I (1077) who_camera: Camera module is AI-THINKER
I (1077) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:2
I (1087) cam_hal: cam init ok
I (1087) sccb: pin_sda 26 pin_scl 27
I (1097) sccb: sccb_i2c_port=1
I (1097) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1137) camera: Detected camera at address=0x30
I (1137) camera: Detected OV2640 camera
I (1137) camera: Camera PID=0x26 VER=0x42 MIDL=0x7f MIDH=0xa2
I (1217) esp32 ll_cam: node_size: 3840, nodes_per_line: 1, lines_per_node: 3, dma_half_buffer_min: 3840, dma_half_buffer: 15360,lines_per_half_buffer: 12, dma_buffer_size: 30720, image_size: 153600
I (1217) cam_hal: buffer_size: 30720, half_buffer_size: 15360, node_buffer_size: 3840, node_cnt: 8, total_cnt: 10
I (1227) cam_hal: Allocating 153600 Byte frame buffer in PSRAM
I (1237) cam_hal: Allocating 153600 Byte frame buffer in PSRAM
I (1247) cam_hal: cam config ok
I (1247) ov2640: Set PLL: clk_2x: 0, clk_div: 3, pclk_auto: 1, pclk_div: 8
I (1327) main_task: Returned from app_main()
E (331977) cam_hal: FB-SIZE: 15360 != 153600
cam_hal: EV-VSYNC-OVF
W (335937) cam_hal: Failed to get the frame on time!
W (339937) cam_hal: Failed to get the frame on time!
W (343937) cam_hal: Failed to get the frame on time!
W (347937) cam_hal: Failed to get the frame on time!
