uart 高频发送与接收问题
shiinakaze
uart 高频发送与接收问题
Postby shiinakaze » Sun Apr 27, 2025 10:43 am
发送部分:
#define TAG                "mic"
#define SAMPLE_RATE        8000
#define TP_MESH_SEND_ADDR  "FFBF"
 * dma_buffer_size = dma_frame_num * slot_num * slot_bit_width / 8
 * the `dma_frame_num` should be the multiple of `3` when the data bit width is 24.
 * the `channel_num` should be 1 when the slot mode is mono
#define I2S_BUFFER_SIZE    400
#define AT_CMD_BUFFER_SIZE (I2S_BUFFER_SIZE * 2 + 32)
uint8_t i2s_rx_buffer[I2S_BUFFER_SIZE] = {0};
char at_cmd_line[AT_CMD_BUFFER_SIZE] = {0};
void app_main(void) {
    gpio_config_t io_conf = {
        .pin_bit_mask = GPIO_NUM_18,
        .mode = GPIO_MODE_OUTPUT,
        .pull_up_en = GPIO_PULLUP_DISABLE,
        .pull_down_en = GPIO_PULLDOWN_DISABLE,
        .intr_type = GPIO_INTR_DISABLE,
    gpio_config(&io_conf);
    gpio_set_level(GPIO_NUM_18, 1);
    ESP_LOGI(TAG, "GPIO configured");
    i2s_chan_handle_t i2s_rx_handle;
    i2s_chan_config_t i2s_rx_chan_cfg = I2S_CHANNEL_DEFAULT_CONFIG(I2S_NUM_1, I2S_ROLE_MASTER);
    i2s_new_channel(&i2s_rx_chan_cfg, NULL, &i2s_rx_handle);
    i2s_std_config_t i2s_rx_std_cfg = {
        .clk_cfg = I2S_STD_CLK_DEFAULT_CONFIG(SAMPLE_RATE),
        .slot_cfg = I2S_STD_PHILIPS_SLOT_DEFAULT_CONFIG(I2S_DATA_BIT_WIDTH_32BIT, I2S_SLOT_MODE_MONO),
        .gpio_cfg = {
            .mclk = I2S_GPIO_UNUSED,
            .bclk = GPIO_NUM_5,
            .ws = GPIO_NUM_4,
            .dout = I2S_GPIO_UNUSED,
            .din = GPIO_NUM_6,
            .invert_flags = {
                .mclk_inv = false,
                .bclk_inv = false,
                .ws_inv = false,
    /* It is very important that the slot_mask needs to be configured according to the hardware design, otherwise the
     * microphone cannot correctly obtain complete data. */
    i2s_rx_std_cfg.slot_cfg.slot_mask = I2S_STD_SLOT_LEFT;
    i2s_channel_init_std_mode(i2s_rx_handle, &i2s_rx_std_cfg);
    i2s_channel_enable(i2s_rx_handle);
    ESP_LOGI(TAG, "I2S configured");
    uart_config_t uart_config = {
        .baud_rate = 460800,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
    // Configure UART parameters
    ESP_ERROR_CHECK(uart_param_config(UART_NUM_1, &uart_config));
    ESP_ERROR_CHECK(uart_set_pin(UART_NUM_1, GPIO_NUM_17, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
    ESP_ERROR_CHECK(uart_driver_install(UART_NUM_1, AT_CMD_BUFFER_SIZE, AT_CMD_BUFFER_SIZE * 5, 0, NULL, 0));
    ESP_LOGI(TAG, "UART configured");
    esp_err_t ret = ESP_OK;
    vTaskDelay(pdMS_TO_TICKS(5000));
    ESP_LOGI(TAG, "Start");
    while (1) {
        size_t bytes_read = 0;
        ret = i2s_channel_read(i2s_rx_handle, i2s_rx_buffer, I2S_BUFFER_SIZE, &bytes_read, 100);
        if (ret == ESP_OK) {
            if (bytes_read > 0) {
                ESP_LOGI(TAG, "I2S read %d bytes", bytes_read);
                // for (size_t i = 0; i < bytes_read; i++) {
                //     printf("%d\n", i2s_rx_buffer[i]);
                // printf("\n");
                // AT+SEND=<ADDR>,<LEN>,<DATA>,<TYPE>\r\n
                int at_cmd_line_len = snprintf(at_cmd_line, sizeof(at_cmd_line), "AT+SEND=%s,%u,", TP_MESH_SEND_ADDR, (unsigned int)bytes_read);
                char *uart_send_offset = at_cmd_line + at_cmd_line_len;
                    uart_send_offset += sprintf(uart_send_offset, "%02X", i2s_rx_buffer[i]);
                uart_send_offset += snprintf(uart_send_offset, AT_CMD_BUFFER_SIZE - (uart_send_offset - at_cmd_line), ",0\r\n");
                at_cmd_line_len = uart_send_offset - at_cmd_line;
                int byte_write = uart_write_bytes(UART_NUM_1, at_cmd_line, at_cmd_line_len);
                if (byte_write != at_cmd_line_len) {
                    ESP_LOGW(TAG, "UART write only wrote %d of %d bytes", byte_write, at_cmd_line_len);
                    ESP_LOGI(TAG, "Sent successfully, wrote %d bytes", byte_write);
            ESP_LOGE(TAG, "I2S read failed");
接收部分:
#define TAG                "speaker"
#define TAG_TPMESH         "TPMESH"
#define TP_MESH_ADDR       "FFBE"
uint8_t i2s_tx_buffer[I2S_BUFFER_SIZE] = {0};
     * dma_buffer_size = dma_frame_num * slot_num * slot_bit_width / 8.
     * the `dma_frame_num` should be the multiple of `3` when the data bit width is 24, set by i2s_chan_config_t.
     * the `channel_num` should be 1 when the slot mode is mono, set by i2s_std_config_t.
    i2s_chan_handle_t tx_handle;
    i2s_chan_config_t tx_chan_cfg = I2S_CHANNEL_DEFAULT_CONFIG(I2S_NUM_0, I2S_ROLE_MASTER);
    i2s_new_channel(&tx_chan_cfg, &tx_handle, NULL);
    i2s_std_config_t tx_std_cfg = {
        .gpio_cfg = {
            .bclk = GPIO_NUM_15,
            .ws = GPIO_NUM_16,
            .dout = GPIO_NUM_7,
            .din = I2S_GPIO_UNUSED,
            .invert_flags = {
                .mclk_inv = false,
                .bclk_inv = false,
                .ws_inv = false,
    tx_std_cfg.slot_cfg.slot_mask = I2S_STD_SLOT_LEFT;
    i2s_channel_init_std_mode(tx_handle, &tx_std_cfg);
    i2s_channel_enable(tx_handle);
    uart_param_config(UART_NUM_1, &uart_config);
    uart_set_pin(UART_NUM_1, UART_PIN_NO_CHANGE, GPIO_NUM_18, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
    uart_driver_install(UART_NUM_1, AT_CMD_BUFFER_SIZE, 0, 0, NULL, 0);
    // xTaskCreate(uart_event_task, "uart_event_task", 4 * 1024, NULL, 12, NULL);
    while (1) {
        int uart_read_len = 0;
        uart_read_len = uart_read_bytes(UART_NUM_1, at_cmd_line, sizeof(at_cmd_line), pdMS_TO_TICKS(100));
        if (uart_read_len > 0) {
            ESP_LOGI(TAG, "UART read length: %d", uart_read_len);
            printf("UART read data: %s\n", at_cmd_line);
            if (strncmp(at_cmd_line, "AT+SEND=", 8) == 0) {
                char dest[6], len[6], data[800];
                char *param_start = at_cmd_line + sizeof("AT+SEND=") - 1;
                if (sscanf(param_start, "%5[^,],%5[^,],%s", dest, len, data) == 3) {
                    size_t data_len = strlen(data);
                    uint8_t hex_data[400] = {0};
                    size_t hex_data_len = 0;
                    // Convert hex string to byte array
                    for (size_t i = 0; i < data_len; i += 2) {
                        if (i + 1 < data_len) {
                            char byte_str[3] = {data[i], data[i + 1], '\0'};
                            hex_data[hex_data_len++] = (uint8_t)strtol(byte_str, NULL, 16);
                    printf("Hex Data Array: ");
                    for (size_t i = 0; i < hex_data_len; i++) {
                        printf("0x%02X ", hex_data[i]);
                    printf("\n");
                    esp_err_t ret = i2s_channel_write(tx_handle, hex_data, hex_data_len, NULL, 100);
                    if (ret != ESP_OK) {
                        ESP_LOGE(TAG, "I2S write failed");
                    ESP_LOGW(TAG_TPMESH, "Invalid format");
                ESP_LOGW(TAG_TPMESH, "Invalid AT command");
出现数据接收不完整:
屏幕截图 2025-04-27 184158.png (447.11 KiB) Viewed 183 times
