Hello y'all!
I managed to get a few ESP32-C3 boards from aliexpress before the tarrifs, and everything is working great so far, except programming via OTA / wifi.
Thats the board that I bought:
https://www.aliexpress.us/item/32568073 ... pt=glo2usa
What I did so far:
- flash the OTAbasic sample from the Arduino IDE via usb-c (ssid and pw are set)
- verify that the esp32 got assigned an IP address
- I can successfully ping the esp32
Then I try to flash the same sketch, but this time I select the ESP32 @192.168.0.197 from the "port" menu.
Compiling starts, but after a while it always errors out with :
Uploading: [========= ] 15%
13:53:23 [ERROR]: Error Uploading: [Errno 32] Broken pipe
Failed uploading: uploading error: exit status 1
Not sure if it makes sense to provide the sketch that I used, as its the standard sample that comes with the arduino ide.
Wifi and power supply are both stable. Flashing via USB-C works like a charm....
Any ideas what the issue might be?
Thx in advance!
Sebastian
cant flash ESP32-C3 via OTA/ wifi
lbernstone
Re: cant flash ESP32-C3 via OTA/ wifi
Set Core Debug level to verbose in the Tools menu and upload new firmware. You should get additional information in the log about what is failing.
