Hi guys,
i have 2 ESP32-D0WD-V3 where i cant delete the flash. Nothing is attached to the devboard (all pins are not used).
Log:
.\esptool.exe --chip esp32 --port COM4 erase_flash
esptool.py v4.8.1
Serial port COM4
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.1)
Crystal is 40MHz
MAC: ec:e3:34:ce:61:00
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
Console:
[08:18:14]ets Jul 29 2019 12:21:46
[08:18:14]
[08:18:14]rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[08:18:14]invalid header: 0xefffffff
[08:18:14]invalid header: 0xcfffffff
What am i doing wrong? Is the device dead? Any way to reanimate it?
Regards,
Feos
Edit: Hold S1, press and release S2, release S1:
[08:20:24]rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[08:20:24]invalid header: 0xefffffff
[08:20:25]invalid header: 0xefffffff
[08:20:25]invalid header: 0x6fffffff
[08:20:25]ets Jul 29 2019 12:21:46
[08:20:25]
[08:20:30]rst:0x10 (Rets Jul 29 2019 12:21:46
[08:20:30]
[08:20:30]rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
[08:20:30]waiting for download
However, i still cant erase flash.
The flash_download_tool_3.9.8_w1 can read efuse and read the flash (64KB)
=== Run "summary" command ===
EFUSE_NAME (Block) Description = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
ADC_VREF (BLOCK0) True ADC reference voltage = 1086 R/W (0b10010)
Config fuses:
WR_DIS (BLOCK0) Efuse write disable mask = 0 R/W (0x0000)
RD_DIS (BLOCK0) Disable reading from BlOCK1-3 = 0 R/W (0x0)
DISABLE_APP_CPU (BLOCK0) Disables APP CPU = False R/W (0b0)
DISABLE_BT (BLOCK0) Disables Bluetooth = False R/W (0b0)
DIS_CACHE (BLOCK0) Disables cache = False R/W (0b0)
CHIP_CPU_FREQ_LOW (BLOCK0) If set alongside EFUSE_RD_CHIP_CPU_FREQ_RATED; the = False R/W (0b0)
ESP32's max CPU frequency is rated for 160MHz. 24
0MHz otherwise
CHIP_CPU_FREQ_RATED (BLOCK0) If set; the ESP32's maximum CPU frequency has been = True R/W (0b1)
rated
BLK3_PART_RESERVE (BLOCK0) BLOCK3 partially served for ADC calibration data = False R/W (0b0)
CLK8M_FREQ (BLOCK0) 8MHz clock freq override = 53 R/W (0x35)
VOL_LEVEL_HP_INV (BLOCK0) This field stores the voltage level for CPU to run = 0 R/W (0b00)
at 240 MHz; or for flash/PSRAM to run at 80 MHz.0
x0: level 7; 0x1: level 6; 0x2: level 5; 0x3: leve
l 4. (RO)
CODING_SCHEME (BLOCK0) Efuse variable block length scheme
= NONE (BLK1-3 len=256 bits) R/W (0b00)
CONSOLE_DEBUG_DISABLE (BLOCK0) Disable ROM BASIC interpreter fallback = True R/W (0b1)
DISABLE_SDIO_HOST (BLOCK0) = False R/W (0b0)
DISABLE_DL_CACHE (BLOCK0) Disable flash cache in UART bootloader = False R/W (0b0)
Flash fuses:
FLASH_CRYPT_CNT (BLOCK0) Flash encryption is enabled if this field has an o = 0 R/W (0b0000000)
dd number of bits set
FLASH_CRYPT_CONFIG (BLOCK0) Flash encryption config (key tweak bits) = 0 R/W (0x0)
Identity fuses:
CHIP_PACKAGE_4BIT (BLOCK0) Chip package identifier #4bit = False R/W (0b0)
CHIP_PACKAGE (BLOCK0) Chip package identifier = 1 R/W (0b001)
CHIP_VER_REV1 (BLOCK0) bit is set to 1 for rev1 silicon = True R/W (0b1)
CHIP_VER_REV2 (BLOCK0) = True R/W (0b1)
WAFER_VERSION_MINOR (BLOCK0) = 1 R/W (0b01)
WAFER_VERSION_MAJOR (BLOCK0) calc WAFER VERSION MAJOR from CHIP_VER_REV1 and CH = 3 R/W (0b011)
IP_VER_REV2 and apb_ctl_date (read only)
PKG_VERSION (BLOCK0) calc Chip package = CHIP_PACKAGE_4BIT << 3 + CHIP_ = 1 R/W (0x1)
PACKAGE (read only)
Jtag fuses:
JTAG_DISABLE (BLOCK0) Disable JTAG = False R/W (0b0)
Mac fuses:
MAC (BLOCK0) MAC address
= ec:e3:34:ce:61:00 (CRC 0xbf OK) R/W
MAC_CRC (BLOCK0) CRC8 for MAC address = 191 R/W (0xbf)
MAC_VERSION (BLOCK3) Version of the MAC field = 0 R/W (0x00)
Security fuses:
UART_DOWNLOAD_DIS (BLOCK0) Disable UART download mode. Valid for ESP32 V3 and = False R/W (0b0)
newer; only
ABS_DONE_0 (BLOCK0) Secure boot V1 is enabled for bootloader image = False R/W (0b0)
ABS_DONE_1 (BLOCK0) Secure boot V2 is enabled for bootloader image = False R/W (0b0)
DISABLE_DL_ENCRYPT (BLOCK0) Disable flash encryption in UART bootloader = False R/W (0b0)
DISABLE_DL_DECRYPT (BLOCK0) Disable flash decryption in UART bootloader = False R/W (0b0)
KEY_STATUS (BLOCK0) Usage of efuse block 3 (reserved) = False R/W (0b0)
SECURE_VERSION (BLOCK3) Secure version for anti-rollback = 0 R/W (0x00000000)
BLOCK1 (BLOCK1) Flash encryption key
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLOCK2 (BLOCK2) Security boot key
BLOCK3 (BLOCK3) Variable Block 3
Spi Pad fuses:
SPI_PAD_CONFIG_HD (BLOCK0) read for SPI_pad_config_hd = 0 R/W (0b00000)
SPI_PAD_CONFIG_CLK (BLOCK0) Override SD_CLK pad (GPIO6/SPICLK) = 0 R/W (0b00000)
SPI_PAD_CONFIG_Q (BLOCK0) Override SD_DATA_0 pad (GPIO7/SPIQ) = 0 R/W (0b00000)
SPI_PAD_CONFIG_D (BLOCK0) Override SD_DATA_1 pad (GPIO8/SPID) = 0 R/W (0b00000)
SPI_PAD_CONFIG_CS0 (BLOCK0) Override SD_CMD pad (GPIO11/SPICS0) = 0 R/W (0b00000)
Vdd fuses:
XPD_SDIO_REG (BLOCK0) read for XPD_SDIO_REG = False R/W (0b0)
XPD_SDIO_TIEH (BLOCK0) If XPD_SDIO_FORCE & XPD_SDIO_REG = 1.8V R/W (0b0)
XPD_SDIO_FORCE (BLOCK0) Ignore MTDI pin (GPIO12) for VDD_SDIO on reset = False R/W (0b0)
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V)
Using the --trace parameter shows this:
TRACE +0.001 Write 14 bytes: c0000a04000000000014a0f53fc0
TRACE +0.006 Read 1 bytes: c0
TRACE +0.000 Read 11 bytes: 010a0200000010010000c0
TRACE +0.000 Received full packet: 010a0200000010010000
TRACE +0.004 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=7c60f63f
TRACE +0.001 Write 14 bytes: c0000a0400000000007c60f63fc0
TRACE +0.005 Read 1 bytes: c0
TRACE +0.001 Read 11 bytes: 010a0200002004960000c0
TRACE +0.000 Received full packet: 010a0200002004960000
TRACE +0.003 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=14a0f53f
TRACE +0.000 Write 14 bytes: c0000a04000000000014a0f53fc0
TRACE +0.001 Read 11 bytes: 010a0200000010010000c0
TRACE +0.002 Received full packet: 010a0200000010010000
TRACE +0.005 command op=0xd0 data len=0 wait_response=1 timeout=120.000 data=
TRACE +0.000 Write 10 bytes: c000d0000000000000c0
TRACE +0.003 Read 1 bytes: c0
TRACE +0.002 Read 8 bytes: 01d0020000000000
flash_id:
PS C:\temp\esptool-v4.8.1-win64\esptool-win64> .\esptool.exe flash_id
esptool.py v4.8.1
Found 1 serial ports
Serial port COM4
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting..............
Detecting chip type... ESP32
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Manufacturer: 5e
Device: 4016
Detected flash size: 4MB
Flash voltage set by a strapping pin to 3.3V
Hard resetting via RTS pin...
ESP32-D0WD-V3 - erase_flash - fatal error
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
