Only Flash Changed Partitions
lotharyx
Postby lotharyx » Tue Apr 29, 2025 3:59 pm
I'm developing against ESP32-C3-MINI-1 with Visual Studio Code in Windows 10.
My project involves providing a captive Wi-Fi portal that presents a control interface for a device. This, of course, means my ESP32 project involves httpd and web content.
Following some suggestions I've seen around, I've set up custom partitions so that my web content files are separate from my application code. The idea, of course, being that I'll most likely be modifying one or the other during a test cycle, and want to save time and FLASH wear by only writing the partition that changed.
So far, whenever I use the ESP-IDF extension to flash the device, it always writes all partitions. This makes sense, because I haven't told it not to do that.
How do I tell it to only flash the partition(s) that changed?
MicroController
Re: Only Flash Changed Partitions
Postby MicroController » Wed Apr 30, 2025 10:43 pm
I guess you'll have to 'manually' flash only the desired .bin files. (See the generated files in "build", like "flash_app_args", "flash_bootloader_args", "flash_project_args", &c.)
It may be possible to summon some CMake magic to detect which .bins changed and generate corresponding flashing arguments, but AFAICT that's not available out-of-the-box with the IDF.
Users browsing this forum: Amazon [Bot] and 3 guests
