I am working for the Flash Encryption and Secure boot v2, where i am facing the issue
Module - ESP32-S3
IDF - 5.0.7
Building Hello World Example given in idf
Platform - windows, using cmd [command prompt] commands for building binaries
Work Done so Far,
Enabled Secure boot in menuconfig [devlopment mode]
Generated signed key for the images
Tickmarked sign image during build time in menuconfig
Upgraded the partitioon table as per requirement
Flashed bootloader.bin manually and flashed other application.bin, partition.bin with usin idf.py flash
Secure boot is done successgfully
As I am not able to read the contents from the flash and also unsigned images are not supported bu the module
Tested Only signed Bootloade.bin and upon that signed bianries only ups the board and allows to run the default hello world example
Now Trying with the Flash encryption
Enabled flash encryption
as want to enabled both at the same time
and again dumped the bootloader.bin in the module [this time not dumped the application.bin after duming the bootloader.bin]
Attaching the logs and sdkconfig
Kindly reply on high priority
Facing issue flash encryption+secure boot sbv2 combination in development mode for esp32s3
kesha.modhia
- 20250425_VM_flash_encryp_logs_SINGLE_FINAL_Reset_logs.txt
- Logs after flash encryption enabled
- (25.43 KiB) Downloaded 14 times
- sdkconfig.h
- sdkconfig
- (37.17 KiB) Downloaded 11 times
Re: Facing issue flash encryption+secure boot sbv2 combination in development mode for esp32s3
Hello.
When both Secure boot and Flash encryption enabled, you need to sign the binaries first (this is done automatically if you enabled `Sign binaries during build` in menuconfig) and then encrypt them (i.e. with `espsecure.py` if you generated the keys on PC).
I can walk you through how to do it (you don't need to do a step again if you have already done it).
I assume to work with ESP32-S3 and I won't do any recommended eFuse burning here unless necessary.
This is not a tutorial how to do it for the production, only to simply demonstrate how to make it work together.
I also highly recommend to use "Virtual eFuses" with "Keep eFuses in flash" option enabled (adding "efuse_em, data, efuse, , 0x2000," line to the partition table is needed for this option) when testing this so you don't brick your ESP: https://docs.espressif.com/projects/esp ... ual-efuses However I don't assume here it is enabled so if you have it enabled then maybe not all steps will be the same.
I followed this document: https://docs.espressif.com/projects/esp ... flows.html
- Go to your project directory
- Generate key for secure boot, it's digest and a key for flash encryption
espsecure.py generate_signing_key --version 2 --scheme rsa3072 secure_boot_signing_key.pem espsecure.py digest_sbv2_public_key --keyfile secure_boot_signing_key.pem --output digest.bin espsecure.py generate_flash_encryption_key my_flash_encryption_key.bin - Enable these setting in `idf.py menuconfig` -> `Security features`
This is not definitive list or anything, just what I used for this debug test
- "Enable hardware Secure Boot in bootloader"
- "Sign binaries during build" - optional
- "Allow potentially insecure options" - only for this debug test, do not enable in production
- "Enable flash encryption on boot"
- Potentially insecure options ->
- "Allow JTAG Debugging"
- "Allow additional read protecting of efuses"
- "Leave unused digest slots available (not revoke)"
- "Leave UART bootloader flash cache enabled"
- UART ROM download mode -> "UART ROM download mode (Enabled (not recommended))"
- Build you binaries and sign them
If you have `Sign binaries during build` enabled and correct path to the signing key (in `idf.py menuconfig -> Security features`):Code: Select all
idf.py buildIf you have `Sign binaries during build` disabled (don't sign the partition table):Code: Select all
# Use `copy` on Windows cp build/bootloader/bootloader.bin bootloader-signed.bin cp build/<NAME_OF_YOUR_APP>.bin <NAME_OF_YOUR_APP>-signed.binCode: Select all
espsecure.py sign_data --version 2 --keyfile secure_boot_signing_key.pem --output bootloader-signed.bin build/bootloader/bootloader.bin espsecure.py sign_data --version 2 --keyfile secure_boot_signing_key.pem --output <NAME_OF_YOUR_APP>-signed.bin build/<NAME_OF_YOUR_APP>.bin - Encrypt the binaries (I use `0x0` address for the bootloader because I assume ESP32-S3 chip)
You can get the addresses if you run `idf.py partition-table`.
espsecure.py encrypt_flash_data --aes_xts --keyfile my_flash_encryption_key.bin --address 0x0 --output bootloader-signed-enc.bin bootloader-signed.bin espsecure.py encrypt_flash_data --aes_xts --keyfile my_flash_encryption_key.bin --address <ADDRESS OF THE PART TABLE> --output partition-table-enc.bin build/partition_table/partition-table.bin espsecure.py encrypt_flash_data --aes_xts --keyfile my_flash_encryption_key.bin --address <ADDRESS OF THE APP> --output <NAME_OF_YOUR_APP>-signed-enc.bin build/<NAME_OF_YOUR_APP>-signed.bin - Flash the chip
esptool.py --before=default_reset --after=no_reset --no-stub write_flash --flash_mode dio --flash_freq 80m --flash_size keep 0x0 bootloader-signed-enc.bin --force esptool.py --before=default_reset --after=no_reset --no-stub write_flash --flash_mode dio --flash_freq 80m --flash_size keep <ADDRESS OF THE PART TABLE> partition-table-enc.bin esptool.py --before=default_reset --after=no_reset --no-stub write_flash --flash_mode dio --flash_freq 80m --flash_size keep <ADDRESS OF THE APP> secure_boot_flash_encryption_test-signed-enc.bin - Burn the eFuses
espefuse.py burn_key <e.g BLOCK_KEY0> digest.bin SECURE_BOOT_DIGEST0 espefuse.py burn_efuse SECURE_BOOT_EN espefuse.py burn_key <e.g BLOCK_KEY1> my_flash_encryption_key.bin XTS_AES_128_KEY espefuse.py burn_efuse SPI_BOOT_CRYPT_CNT - Run `idf.py monitor`
Users browsing this forum: Applebot, trendictionbot and 4 guests
