-Werror=format= warnings about identical types
lotharyx
Postby lotharyx » Wed Apr 30, 2025 3:40 pm
I'm not sure if this is an ESP-IDF thing or a GCC thing, but I sometimes get printf format warnings about congruent types. Most commonly it's long unsigned int vs unsigned int, which are the same size, proven at runtime:
    ESP_LOGI("main", "sizeof(unsigned int) = %d", sizeof(unsigned int));
    ESP_LOGI("main", "sizeof(unsigned long) = %d", sizeof(unsigned long));
    ESP_LOGI("main", "sizeof(long unsigned int) = %d", sizeof(long unsigned int));
    ESP_LOGI("main", "sizeof(uint32_t) = %d", sizeof(uint32_t));
Output:
I (399) main: sizeof(unsigned int) = 4
I (399) main: sizeof(unsigned long) = 4
I (399) main: sizeof(long unsigned int) = 4
I (399) main: sizeof(uint32_t) = 4
I see this most often when using %u for a uint32_t:
esp_log_color.h:100:31: error: format '%u' expects argument of type 'unsigned int', but argument 7 has type 'long unsigned int' [-Werror=format=]
It seems to me that the compiler should be smart enough to realize that two unsigned 4-byte integer types are interchangeable. Why doesn't it?
MicroController
Re: -Werror=format= warnings about identical types
Postby MicroController » Wed Apr 30, 2025 9:56 pm
Different types are different types to gcc in this case. Note that you may compile the same C code for a different platform/architecture (e.g. 64-bit PC) with the same types having different sizes and/or layouts. I think int and long int being the same size is rather an exception than the norm across various platforms, so gcc tells you that your code may be erroneous and is at least not portable.
Users browsing this forum: Amazon [Bot], Bing [Bot], PetalBot and 3 guests
