What are the SDA and SCL pins
walter25
Postby walter25 » Fri May 09, 2025 10:11 pm
What are the SDA and SCL pins on this ESP32 model?, specifically ESP32-S3-WROOM-1U-N4
Re: What are the SDA and SCL pins
Postby Sprite » Mon May 12, 2025 7:04 am
The ESP32 series do not have dedicated I2C pins; you can use any IO-pin that is not otherwise occupied.
mosin jack
Postby mosin jack » Mon May 12, 2025 10:28 am
The SDA and SCL pins on the ESP32-S3-WROOM-1U-N4 are assignable. Common defaults are:
SDA: GPIO 8
SCL: GPIO 9
You can change these pins in your code based on your setup.
Users browsing this forum: Applebot, Google [Bot], PerplexityBot and 2 guests
