Any code samples that work with the Fatuba Vacuum Fluorescent Display (vfd) when using esp-idf rather than arduino
cheseremtitus
Postby cheseremtitus » Sat May 10, 2025 5:05 pm
I have the following code for displaying content on the Fatuba 8 bit VFD.
/* Blink Example
#include <stdio.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "led_strip.h"
#include "sdkconfig.h"
#include "driver/gpio.h"
#include "esp_timer.h"
#include <string.h>
#include "esp_rom_sys.h"
static const char *TAG = "example";
/* Use project configuration menu (idf.py menuconfig) to choose the GPIO to blink,
   or you can edit the following line and set a number here.
#define BLINK_GPIO 2
#define DIN_PIN     GPIO_NUM_23
#define CLK_PIN     GPIO_NUM_18
#define CS_PIN      GPIO_NUM_5
#define RESET_PIN   GPIO_NUM_4
static uint8_t s_led_state = 0;
#ifdef CONFIG_BLINK_LED_STRIP
static led_strip_handle_t led_strip;
static void blink_led(void)
    /* If the addressable LED is enabled */
    if (s_led_state) {
        /* Set the LED pixel using RGB from 0 (0%) to 255 (100%) for each color */
        led_strip_set_pixel(led_strip, 0, 16, 16, 16);
        /* Refresh the strip to send data */
        led_strip_refresh(led_strip);
        /* Set all LED off to clear all pixels */
        led_strip_clear(led_strip);
static void configure_led(void)
    ESP_LOGI(TAG, "Example configured to blink addressable LED!");
    /* LED strip initialization with the GPIO and pixels number*/
    led_strip_config_t strip_config = {
        .strip_gpio_num = BLINK_GPIO,
        .max_leds = 1, // at least one LED on board
#if CONFIG_BLINK_LED_STRIP_BACKEND_RMT
    led_strip_rmt_config_t rmt_config = {
        .resolution_hz = 10 * 1000 * 1000, // 10MHz
        .flags.with_dma = false,
    ESP_ERROR_CHECK(led_strip_new_rmt_device(&strip_config, &rmt_config, &led_strip));
#elif CONFIG_BLINK_LED_STRIP_BACKEND_SPI
    led_strip_spi_config_t spi_config = {
        .spi_bus = SPI2_HOST,
        .flags.with_dma = true,
    ESP_ERROR_CHECK(led_strip_new_spi_device(&strip_config, &spi_config, &led_strip));
#else
#error "unsupported LED strip backend"
#endif
#elif CONFIG_BLINK_LED_GPIO
    /* Set the GPIO level according to the state (LOW or HIGH)*/
    gpio_set_level(BLINK_GPIO, s_led_state);
    ESP_LOGI(TAG, "Example configured to blink GPIO LED!");
    gpio_reset_pin(BLINK_GPIO);
    /* Set the GPIO as a push/pull output */
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
#else
#error "unsupported LED type"
#endif
void spi_write_data(uint8_t data) {
    for (int i = 0; i < 8; i++) {
        gpio_set_level(CLK_PIN, 0);
        gpio_set_level(DIN_PIN, data & 0x01);
        data >>= 1;
        gpio_set_level(CLK_PIN, 1);
void vfd_command(uint8_t command) {
    gpio_set_level(CS_PIN, 0);
    spi_write_data(command);
    gpio_set_level(CS_PIN, 1);
    esp_rom_delay_us(5);
void vfd_show() {
    spi_write_data(0xE8);  // Refresh Display
void vfd_init() {
    spi_write_data(0xE0);  // Set number of digits
    spi_write_data(0x07);  // 8 digits
    spi_write_data(0xE4);  // Set brightness
    spi_write_data(0xFF);  // Max brightness
void vfd_write_char(uint8_t pos, uint8_t chr) {
    spi_write_data(0x20 + pos);
    spi_write_data(chr);
void app_main(void)
    /* Configure the peripheral according to the LED type */
    configure_led();
    gpio_config_t io_conf = {
        .pin_bit_mask = (1ULL << DIN_PIN) | (1ULL << CLK_PIN) | (1ULL << CS_PIN) | (1ULL << RESET_PIN),
        .mode = GPIO_MODE_OUTPUT,
        .pull_up_en = GPIO_PULLUP_DISABLE,
        .pull_down_en = GPIO_PULLDOWN_DISABLE,
        .intr_type = GPIO_INTR_DISABLE,
    gpio_config(&io_conf);
    // Reset the VFD
    gpio_set_level(RESET_PIN, 0);
    gpio_set_level(RESET_PIN, 1);
    vfd_init();
    // Display "$1234"
    vfd_write_char(0, '$');
    vfd_write_char(1, '1');
    vfd_write_char(2, '2');
    vfd_write_char(3, '3');
    vfd_write_char(4, '4');
    vfd_show();
    while (1) {
        ESP_LOGI(TAG, "Turning the LED %s!", s_led_state == true ? "ON" : "OFF");
        blink_led();
        /* Toggle the LED state */
        s_led_state = !s_led_state;
        vTaskDelay(CONFIG_BLINK_PERIOD / portTICK_PERIOD_MS);
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 1 guest
