Any code samples that work with the Fatuba Vacuum Fluorescent Display (vfd) when using esp-idf rather than arduino
Posted: Sat May 10, 2025 5:05 pm
by cheseremtitus
I have the following code for displaying content on the Fatuba 8 bit VFD.
/* Blink Example
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "led_strip.h"
#include "sdkconfig.h"
#include "driver/gpio.h"
#include "esp_timer.h"
#include <string.h>
#include "esp_rom_sys.h"
static const char *TAG = "example";
/* Use project configuration menu (idf.py menuconfig) to choose the GPIO to blink,
   or you can edit the following line and set a number here.
#define BLINK_GPIO 2
#define DIN_PIN     GPIO_NUM_23
#define CLK_PIN     GPIO_NUM_18
#define CS_PIN      GPIO_NUM_5
#define RESET_PIN   GPIO_NUM_4
static uint8_t s_led_state = 0;
#ifdef CONFIG_BLINK_LED_STRIP
static led_strip_handle_t led_strip;
static void blink_led(void)
    /* If the addressable LED is enabled */
    if (s_led_state) {
        /* Set the LED pixel using RGB from 0 (0%) to 255 (100%) for each color */
        led_strip_set_pixel(led_strip, 0, 16, 16, 16);
        /* Refresh the strip to send data */
        led_strip_refresh(led_strip);
    } else {
        /* Set all LED off to clear all pixels */
        led_strip_clear(led_strip);
static void configure_led(void)
    ESP_LOGI(TAG, "Example configured to blink addressable LED!");
    /* LED strip initialization with the GPIO and pixels number*/
    led_strip_config_t strip_config = {
        .strip_gpio_num = BLINK_GPIO,
        .max_leds = 1, // at least one LED on board
#if CONFIG_BLINK_LED_STRIP_BACKEND_RMT
    led_strip_rmt_config_t rmt_config = {
        .resolution_hz = 10 * 1000 * 1000, // 10MHz
        .flags.with_dma = false,
    ESP_ERROR_CHECK(led_strip_new_rmt_device(&strip_config, &rmt_config, &led_strip));
#elif CONFIG_BLINK_LED_STRIP_BACKEND_SPI
    led_strip_spi_config_t spi_config = {
        .spi_bus = SPI2_HOST,
        .flags.with_dma = true,
    ESP_ERROR_CHECK(led_strip_new_spi_device(&strip_config, &spi_config, &led_strip));
#else
#error "unsupported LED strip backend"
#endif
#elif CONFIG_BLINK_LED_GPIO
    /* Set the GPIO level according to the state (LOW or HIGH)*/
    gpio_set_level(BLINK_GPIO, s_led_state);
    ESP_LOGI(TAG, "Example configured to blink GPIO LED!");
    gpio_reset_pin(BLINK_GPIO);
    /* Set the GPIO as a push/pull output */
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
#else
#error "unsupported LED type"
#endif
void spi_write_data(uint8_t data) {
    for (int i = 0; i < 8; i++) {
        gpio_set_level(CLK_PIN, 0);
        gpio_set_level(DIN_PIN, data & 0x01);
        data >>= 1;
        gpio_set_level(CLK_PIN, 1);
void vfd_command(uint8_t command) {
    gpio_set_level(CS_PIN, 0);
    spi_write_data(command);
    gpio_set_level(CS_PIN, 1);
    esp_rom_delay_us(5);
void vfd_show() {
    spi_write_data(0xE8);  // Refresh Display
void vfd_init() {
    spi_write_data(0xE0);  // Set number of digits
    spi_write_data(0x07);  // 8 digits
    spi_write_data(0xE4);  // Set brightness
    spi_write_data(0xFF);  // Max brightness
void vfd_write_char(uint8_t pos, uint8_t chr) {
    spi_write_data(0x20 + pos);
    spi_write_data(chr);
void app_main(void)
    /* Configure the peripheral according to the LED type */
    configure_led();
    gpio_config_t io_conf = {
        .pin_bit_mask = (1ULL << DIN_PIN) | (1ULL << CLK_PIN) | (1ULL << CS_PIN) | (1ULL << RESET_PIN),
        .mode = GPIO_MODE_OUTPUT,
        .pull_up_en = GPIO_PULLUP_DISABLE,
        .pull_down_en = GPIO_PULLDOWN_DISABLE,
        .intr_type = GPIO_INTR_DISABLE,
    gpio_config(&io_conf);
    // Reset the VFD
    gpio_set_level(RESET_PIN, 0);
    gpio_set_level(RESET_PIN, 1);
    vfd_init();
    // Display "$1234"
    vfd_write_char(0, '$');
    vfd_write_char(1, '1');
    vfd_write_char(2, '2');
    vfd_write_char(3, '3');
    vfd_write_char(4, '4');
    vfd_show();
    while (1) {
        ESP_LOGI(TAG, "Turning the LED %s!", s_led_state == true ? "ON" : "OFF");
        blink_led();
        /* Toggle the LED state */
        s_led_state = !s_led_state;
        vTaskDelay(CONFIG_BLINK_PERIOD / portTICK_PERIOD_MS);
