ESP-IDF v5.3 Only Shows Secure Boot V1 in menuconfig (ESP32-D0WD-V3, Rev 3.1)
Vaibhav02
Postby Vaibhav02 » Fri May 16, 2025 5:45 am
Hi everyone,
I'm using ESP-IDF v5.3 on Windows (PowerShell), and my chip info is below:
PS C:\Users\Admin\Desktop\std_gw> esptool.py read_mac
esptool.py v4.8.1
Found 2 serial ports
Serial port COM10
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting....
Detecting chip type... ESP32
Chip is ESP32-D0WD-V3 (revision v3.1)
Crystal is 40MHz
MAC: cc:db:a7:2e:e8:44
Uploading stub...
Running stub...
Stub running...
Hard resetting via RTS pin...
According to the documentation, this chip supports Secure Boot V2.
However, when I go to:
idf.py menuconfig → Security Features → Enable hardware Secure Boot in bootloader → Select secure boot version
I only see Secure Boot V1, and there's no option to select V2.
I have already confirmed my ESP-IDF version:
ESP-IDF v5.3-dirty
What could be causing this? Do I need to configure something extra to enable Secure Boot V2 in menuconfig?
jcolebaker
Re: ESP-IDF v5.3 Only Shows Secure Boot V1 in menuconfig (ESP32-D0WD-V3, Rev 3.1)
Postby jcolebaker » Thu Nov 27, 2025 2:28 am
This is a bit late, but for anyone who finds this... I ran into the same issue using ESP-IDF v5.5.1
Secure Boot V2 is only supported on chip revisions 3.0 or later. To allow you to select secure boot V2, you also have to go to:
(Top) → Component config → Hardware Settings → Chip revision → Minimum Supported ESP32 Revision
And select "Rev v3.0 (ECO3)"
Secure boot V2 options will then be available.
Users browsing this forum: Baidu [Spider], ChatGPT-User, Qwantbot and 2 guests
