ESP32 auto reset unexpectedly
cyborglol0110
Postby cyborglol0110 » Fri May 16, 2025 10:14 am
Hello. I am currently working with BLE-MESH on ESP32-WROOM-32. However, sometimes it auto resets unexpectedly even I don't reset it. I tried to find out the reason by esp_reset_reason() and it returned:
ESP_RST_PANIC
Why it this happened and how to fix it? Thank you.
This is the console output when the ESP32 initialize and get auto reset.
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6276
load:0x40078000,len:15748
load:0x40080400,len:4
--- 0x40080400: _init at ??:?
ho 8 tail 4 room 4
load:0x40080404,len:3860
entry 0x4008063c
I (31) boot: ESP-IDF v5.4.1-dirty 2nd stage bootloader
I (31) boot: compile time May 16 2025 16:31:05
I (31) boot: Multicore bootloader
I (33) boot: chip revision: v3.1
I (36) boot.esp32: SPI Speed      : 40MHz
I (40) boot.esp32: SPI Mode       : DIO
I (43) boot.esp32: SPI Flash Size : 2MB
I (47) boot: Enabling RNG early entropy source...
I (51) boot: Partition Table:
I (54) boot: ## Label            Usage          Type ST Offset   Length
I (60) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (67) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (73) boot:  2 factory          factory app      00 00 00010000 00177000
I (80) boot: End of partition table
I (83) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=1fbd4h (130004) map
I (135) esp_image: segment 1: paddr=0002fbfc vaddr=3ff80000 size=0001ch (    28) load
I (135) esp_image: segment 2: paddr=0002fc20 vaddr=3ffbdb60 size=003f8h (  1016) load
I (139) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=97b50h (621392) map
I (358) esp_image: segment 4: paddr=000c7b78 vaddr=3ffbdf58 size=050a0h ( 20640) load
I (366) esp_image: segment 5: paddr=000ccc20 vaddr=40080000 size=189f0h (100848) load
I (418) boot: Loaded app from partition at offset 0x10000
I (418) boot: Disabling RNG early entropy source...
I (428) cpu_start: Multicore app
I (437) cpu_start: Pro cpu start user code
I (437) cpu_start: cpu freq: 160000000 Hz
I (437) app_init: Application information:
I (437) app_init: Project name:     mesh-gateway
I (441) app_init: App version:      b3e342f-dirty
I (446) app_init: Compile time:     May 16 2025 16:31:00
I (451) app_init: ELF file SHA256:  b31126932...
I (455) app_init: ESP-IDF:          v5.4.1-dirty
I (459) efuse_init: Min chip rev:     v0.0
I (463) efuse_init: Max chip rev:     v3.99
I (467) efuse_init: Chip rev:         v3.1
I (471) heap_init: Initializing. RAM available for dynamic allocation:
I (477) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (482) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (488) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (493) heap_init: At 3FFCC180 len 00013E80 (79 KiB): DRAM
I (498) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (503) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (509) heap_init: At 400989F0 len 00007610 (29 KiB): IRAM
I (516) spi_flash: detected chip: generic
I (518) spi_flash: flash io: dio
W (521) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (534) coexist: coex firmware version: e727207
I (538) main_task: Started on CPU0
I (548) main_task: Calling app_main()
I (558) gpio: GPIO[2]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1758) BTDM_INIT: BT controller compile version [dc1cd58]
I (1758) BTDM_INIT: Bluetooth MAC: 08:a6:f7:a0:8e:42
I (1758) phy_init: phy_version 4860,6b7a6e5,Feb  6 2025,14:47:07
I (2098) BLE_MESH(lib): Bluetooth Mesh v1.1 commit: [meshlib:8a5446cb8d]
I (2098) BLE_MESH: Relay not supported
I (2098) BLE_MESH: GATT Proxy not supported
I (2098) BLE_MESH: Friend not supported
I (2188) BLE_MESH: NetKeyIndex 0x000, NID 0x49
I (2188) BLE_MESH: NetKey 43505f66524a8fd8d9687e855c25542b
I (2188) BLE_MESH: Primary address 0x0001, element�ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 8 tail 4 room 4
entry 0x4008063c
ahsrabrifat
Re: ESP32 auto reset unexpectedly
Postby ahsrabrifat » Fri May 16, 2025 3:04 pm
Since Mesh logs say:
Relay not supported
Try disabling features you’re not using from sdkconfig or code to reduce memory usage.
Users browsing this forum: Barkrowler, ChatGPT-User and 4 guests
