ESP32 Reboot Loop - invalid header After Flashing (Flash Encryption Enabled)
Vaibhav02
Postby Vaibhav02 » Mon May 19, 2025 10:21 am
Hi everyone,
I'm facing an issue with my ESP32 where it keeps rebooting with the following log on serial monitor:
ets Jul 29 2019 12:21:46
invalid header: 0xf82bbea3
Context:
ESP32 Chip: ESP32-D0WD-V3 (rev 3.1)
ESP-IDF Version: v5.3
Baud rate: 115200
Flash encryption: Enabled (FLASH_CRYPT_CNT = 1)
DISABLE_DL_DECRYPT = True (seen in espefuse.py summary)
ahsrabrifat
Re: ESP32 Reboot Loop - invalid header After Flashing (Flash Encryption Enabled)
Postby ahsrabrifat » Mon May 19, 2025 3:59 pm
If you're using ESP-IDF:
Run the build and flash like this:
idf.py build
idf.py encrypted-flash
If you flash with esptool.py directly, use:
esptool.py --chip esp32 encrypt_flash \
  --keyfile encryption_key.bin \
  --addr 0x10000 firmware.bin
Make sure the bootloader and partition table are also encrypted if needed.
Vaibhav02
Postby Vaibhav02 » Tue May 20, 2025 6:24 am
Hi @ahsrabrifat,
Thank you for your response. I am using ESP-IDF and have already tried this using the monitor, but the same error occurs.
Users browsing this forum: Applebot, Barkrowler and 6 guests
