I2C Issue with MPU6050 – ACK received, but WHO_AM_I always returns 0x00
mahfhjtyujrsftg
Postby mahfhjtyujrsftg » Wed May 21, 2025 11:46 pm
I'm using an ESP32 S3 with the MPU6050 connected via I2C using manual bit-banging (not using the Wire library).
I successfully get ACKs from both the device address (0x68) and the WHO_AM_I register (0x75), but the returned value is always 0x00.
Could this be due to missing pull-up resistors on SDA/SCL? Has anyone encountered a similar issue?
#define SDA                     (42)
#define SCL                     (41)
#define MPU6050_BASE_ADD        (0X68)
#define WHO_AM_I_REG            (0x75)
#define WRITE                   (0)
#define READ                    (1)
#define MPU5060_WRITE(address)  ((address << 1) | WRITE)
#define MPU5060_READ(address)   ((address << 1) | READ)
void i2c_delay() {
  delayMicroseconds(20);
void i2c_init()
  pinMode(SDA, OUTPUT);
  pinMode(SCL, OUTPUT);
  digitalWrite(SDA, HIGH);
  digitalWrite(SCL, HIGH);
  i2c_delay();
void i2c_start()
  pinMode(SDA, INPUT);
  i2c_delay();
  digitalWrite(SDA, LOW);
  i2c_delay();
  digitalWrite(SCL, LOW);
  i2c_delay();
void i2c_write_bit(bool bit)
  i2c_delay(); // 1
  digitalWrite(SDA, bit);
  i2c_delay();
  digitalWrite(SCL, HIGH); // slave read
  i2c_delay(); // 5
  i2c_delay(); // 2
bool i2c_read_ack()
  i2c_delay(); // 5
  bool ack = (digitalRead(SDA) == LOW);
  return ack;
bool i2c_write_byte(uint8_t byte)
  i2c_delay();
  uint8_t m = 1 << 7;
  while(m)
    i2c_write_bit(byte & m);
    m >>= 1;
  return i2c_read_ack();
uint8_t i2c_read_byte()
  uint8_t value = 0;
  int i = 0;
  for (i = 0; i < 8; ++i)
    i2c_delay();
    i2c_delay();
    value <<= 1;
    if (digitalRead(SDA))
      value |= 1;
  // end transmition and sending NACK
  digitalWrite(SDA, HIGH); // NACK
  i2c_delay();
  i2c_delay();
  i2c_delay();
  return value;
void i2c_stop()
  i2c_delay();
  i2c_delay();
void setup()
  delay(1000);
  Serial.println("Hello from LOLIN S3!");
  i2c_init();
void loop()
  delay(1000);
  i2c_start();
  bool ack = i2c_write_byte(MPU5060_WRITE(MPU6050_BASE_ADD));
  Serial.printf("ACK1=%d  (ADD)\n", ack);
  if(ack != true)
    Serial.println("no ack arrived. ERR 1.");
  ack = i2c_write_byte(WHO_AM_I_REG);
  Serial.printf("ACK2=%d  (WHO_AM_I)\n", ack);
  if(ack != true)
    Serial.println("no ack arrived. ERR 2.");
  i2c_start();
  ack = i2c_write_byte(MPU5060_READ(MPU6050_BASE_ADD));
  Serial.printf("ACK3=%d  (READ)\n", ack);
  if (ack != true)
    Serial.println("no ack arrived. ERR 3.");
  uint8_t value = i2c_read_byte();
  i2c_stop();
  Serial.printf("value: 0x%02X\n", value);
  Serial.println("delay");
  delay(1000);
and the output is:
ACK1=0  (ADD)
ACK2=0  (WHO_AM_I)
ACK3=1  (READ)
value: 0x00
delay
ACK1=1  (ADD)
ACK2=1  (WHO_AM_I)
ACK3=1  (READ)
value: 0x00
delay
