External Antenna Requirements with ESP32-S3-MINI-1U
Ahtisham_A
Postby Ahtisham_A » Fri May 23, 2025 10:27 am
I am designing a PCB that uses the ESP32-S3-MINI-1U module with an external antenna.
My question is: What are the requirements for using an external antenna with the ESP32? I understand that the impedance should be 50 ohms and that the central frequency should be 2.4 GHz. Are there any other requirements I should be aware of? The antenna I am using for prototyping is
Will this antenna work for both Wifi and BLE? What are some other options for antennas that could serve as alternatives to this one? My case scenario involves a device that will be placed inside a metal box, with the antenna located outside of the box. I found a suction cup antenna, but it is quite expensive. Are there any cheaper alternatives available? Has anyone used an affordable option for this purpose? If I follow this, will it affect the CLC matching circuit I am using? I cannot change the module. What will be the consequences if we add an SMA connector and an IPEX connector? All SMA and IPEX connectors are rated for 50 Ohm impedance and frequencies above 2.4 GHz.
I hope you understand my application scenario
Users browsing this forum: Barkrowler and 3 guests
