No Sound Output from ES8374 Using ESP32 with I2S
shdr15
Postby shdr15 » Wed May 28, 2025 12:59 pm
Hello all,
I'm working on a project where I developed my own board using the ES8374 audio codec with an ESP32-WROOM-32E. I’ve read the official datasheet thoroughly and configured the registers step-by-step based on the required clocking and output path. I am trying to get just any sound from ES8374, but no success.
I verified that:
- I2C works correctly. (I have I2C_read registers and they were same as the ones I wrote)
- I2S lines (BCLK, LRCK) have expected signals. Using osciloscope, I verified that BCLK is square wave with 512kHz and LRCK is 16kHz
Despite all this, I’m not getting any sound, not even with a basic square wave tone.
My setup details are as follows.
-I2C: SDA=21, SCL=17
-I2S: BCLK=26, LRCK=25, DOUT=27 (DIN of ES8374)
-No MCLK used. PLL is used
-Sample rate: 16 kHz
-Bits/sample: 16-bit stereo
-Output: Only DAC to SPK, mic/ADC path not used
- I set CE pin of ES8374 to LOW to set address to 0x10
- I am using 0.5W 8 ohm Speaker. Vspeaker is 5V and VDD for analog and digital part is 3V3.
- I am using SPKP and SPKN pins for speaker.
#include <Wire.h>
#include "driver/i2s.h"
// === Pin Definitions ===
#define I2C_SDA 21
#define I2C_SCL 17
#define I2S_BCLK 26
#define I2S_LRCK 25
#define I2S_DOUT 27  // ESP32 -> ES8374 DIN
#define CE_PIN 16
#define ES8374_ADDR 0x10
int16_t squareWave[64];
void generateSquareWave() {
  for (int i = 0; i < 64; i += 2) {
    squareWave[i] = 8000;
    squareWave[i + 1] = -8000;
void es8374_write(uint8_t reg, uint8_t val) {
  Wire.beginTransmission(ES8374_ADDR);
  Wire.write(reg);
  Wire.write(val);
  Wire.endTransmission();
void initES8374() {
  es8374_write(0x00, 0x1F);
  delay(10);
  es8374_write(0x00, 0x80);
  delay(10);
  es8374_write(0x01, 0x33);  //0x30
  es8374_write(0x02, 0x08);
  es8374_write(0x03, 0x20);
  //es8374_write(0x04, 0x0C);
  es8374_write(0x06, 0x03);
  es8374_write(0x07, 0x00);
  es8374_write(0x08, 0x21);
  es8374_write(0x09, 0x03);  // PLL analog enable, reset ON
  delay(10);
  es8374_write(0x09, 0x43);  // PLL analog enable, reset OFF , dither off, VCO divide by 2
  es8374_write(0x0A, 0x49);  //3.3V, VCO gain 1, charge pump 4
  es8374_write(0x0B, 0x48);
  es8374_write(0x0C, 0x00);
  es8374_write(0x0D, 0x00);
  es8374_write(0x0E, 0x00);
  es8374_write(0x0F, 0x00);
  es8374_write(0x11, 0x0C);  // 0b00001100
  //0x12 and 0x13 are for startup delay, not used
  es8374_write(0x14, 0x12);
  es8374_write(0x15, 0x40);
  es8374_write(0x17, 0x10);
  es8374_write(0x18, 0x12);
  es8374_write(0x1A, 0x00);  // mono off
  es8374_write(0x1B, 0x00);  // lout off
  es8374_write(0x1C, 0x88);
  es8374_write(0x1D, 0x0B);
  es8374_write(0x1E, 0xA7);  // last 4 bit is volume, enable Class D
  es8374_write(0x1F, 0x0C);
  es8374_write(0x20, 0x08);
  es8374_write(0x21, 0xC0); // neglect
  es8374_write(0x22, 0x00); // neglect
  es8374_write(0x36, 0x04);//DAC mute off
  es8374_write(0x37, 0x00);
  es8374_write(0x38, 0x00);
  es8374_write(0x39, 0x00);
  pinMode(CE_PIN, OUTPUT);
  digitalWrite(CE_PIN, LOW);
  delay(200);
  Wire.begin(I2C_SDA, I2C_SCL);
  delay(100);
  initES8374();
  generateSquareWave();
  // === I2S Configuration ===
  i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX),
    .sample_rate = 16000,
    .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
    .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,  // stereo
    .communication_format = I2S_COMM_FORMAT_I2S,
    .intr_alloc_flags = 0,
    .dma_buf_count = 8,
    .dma_buf_len = 64,
    .use_apll = false,
    .tx_desc_auto_clear = true,
    .fixed_mclk = 0
  i2s_pin_config_t pin_config = {
    .bck_io_num = I2S_BCLK,
    .ws_io_num = I2S_LRCK,
    .data_out_num = I2S_DOUT,
  // Start I2S driver
  esp_err_t err = i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
  if (err != ESP_OK) {
    Serial.printf("❌ i2s_driver_install failed: %d\n", err);
    while (true)
  err = i2s_set_pin(I2S_NUM_0, &pin_config);
    Serial.printf("❌ i2s_set_pin failed: %d\n", err);
    while (true)
  int16_t test_buf[64];
  static bool toggle = false;
    test_buf[i] = toggle ? 10000 : -10000;
    test_buf[i + 1] = toggle ? -10000 : 10000;
  toggle = !toggle;
  size_t written;
  i2s_write(I2S_NUM_0, test_buf, sizeof(test_buf), &written, portMAX_DELAY);
Did I miss critical register that makes speaker off, or DAC mute or are there any known issues with ES8374 and ESP32? Thank you all for your help in advance.
Regards,
ahsrabrifat
Re: No Sound Output from ES8374 Using ESP32 with I2S
Postby ahsrabrifat » Tue Jun 03, 2025 8:31 am
Try this sequence instead:
void initES8374() {
  // Reset
  delay(10);
  delay(10);
  // Clock setup
  es8374_write(0x01, 0x32);  // Use internal PLL, MCLK off
  es8374_write(0x02, 0x10);  // DAC & ADC use same clock
  es8374_write(0x03, 0x20);  // MCLK = 256*Fs
  es8374_write(0x09, 0x03);  // Reset PLL
  delay(10);
  es8374_write(0x09, 0x43);  // PLL enable
  es8374_write(0x0A, 0x49);  // PLL settings
  // DAC setup
  es8374_write(0x14, 0x12);  // DAC I2S, 16-bit, normal polarity
  es8374_write(0x15, 0x40);  // DAC I2S format
  es8374_write(0x1A, 0x00);  // Mono off
  es8374_write(0x1B, 0x00);  // LOUT off
  es8374_write(0x1C, 0x80);  // DAC to SPK enable
  es8374_write(0x1D, 0x02);  // SPK gain
  es8374_write(0x1E, 0xA7);  // SPK enable, volume ~7
  es8374_write(0x1F, 0x6C);  // Mixer gain
  // Unmute DAC
  es8374_write(0x36, 0x00);  // DAC mute off
shdr15
Postby shdr15 » Wed Jun 25, 2025 2:39 pm
Thank you for your support.
I tried your suggested register sequence, but unfortunately it still didn’t produce any sound.
I have a batch of 10 ES8374 chips and tested 4 of them so far. Since everything else checks out, I’m starting to suspect that the chips themselves might be defective.
I will try sourcing new ES8374 chips from another vendor and test again.
Regards,
