boot_comm: mismatch chip ID, expected 0, found 10710
axellin
Postby axellin » Thu May 29, 2025 5:36 am
I'm testing ESP32-WROOM-32E-N8R2 module.
Sometimes the boot log shows mismatch chip ID:
e.g.
ets Jul 29 2019 12:21:46
configsip: 153911750, SPIWP:0xee
mode:2, clock div:2
secure boot v2 enabled
secure boot verification succeeded
load:0x3fff00c0 len:0x2548
load:0x40078000 len:0x58c4
load:0x40080400 len:0xea0
--- 0x40080400: _invalid_pc_placeholder at /home/axel/esp/esp-idf/components/xtensa/xtensa_vectors.S:2235
entry 0x400805ec
--- 0x400805ec: bootloader_common_check_long_hold_gpio_level at /home/axel/esp/esp-idf/components/bootloader_support/src/bootloader_common.c:39
E (53) boot_comm: mismatch chip ID, expected 0, found 10710
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
mode:2, clock div:2
entry 0x400805ec
E (73) boot_comm: mismatch chip ID, expected 0, found 10710
mode:2, clock div:2
entry 0x400805ec
I (646) cpu_start: Multicore app
I (738) cpu_start: Pro cpu start user code
I (738) cpu_start: cpu freq: 240000000 Hz
I (738) app_init: Application information:
It seems reset twice and then boot ok.
I can reproduce this if I repeat executing idf.py monitor many times.
What could cause the mismatch chip ID issue?
axellin
Re: boot_comm: mismatch chip ID, expected 0, found 10710
Postby axellin » Thu May 29, 2025 5:44 am
One of the reset also shows:
Sig block 0 invalid: Image digest does not match
secure boot verification failed
But in the end it also successfully boot.
mode:2, clock div:2
entry 0x400805ec
mode:2, clock div:2
entry 0x400805ec
mode:2, clock div:2
entry 0x400805ec
mode:2, clock div:2
entry 0x400805ec
mode:2, clock div:2
entry 0x400805ec
mode:2, clock div:2
entry 0x400805ec
mode:2, clock div:2
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
mode:2, clock div:2
entry 0x400805ec
W (75) boot.esp32: PRO CPU has been reset by WDT
W (75) boot.esp32: WDT rst info: PRO CPU PC=0x2b7d2bc2
W (75) boot.esp32: WDT rst info: APP CPU PC=0xebfa1413
I (652) cpu_start: Multicore app
I (744) cpu_start: Pro cpu start user code
I (744) cpu_start: cpu freq: 240000000 Hz
I (744) app_init: Application information:
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 1 guest
