I'm trying to implement my own baremetal solution to setup the GPIO pins on ESP32, but unfortunately I've come up across a confusion when reading the SoC documentation.
I want to implement a generic function to get the IO_MUX_GPIOX_REG address, in order to properly control it.
Referring to the Register 6.34 section, we have the following description:
That shows on parenthesis how to calculate the register address relative to the IO MUX base, as specified by the section 6.13.2:
6.13.2 IO MUX Registers
The addresses in parenthesis besides register names are the register addresses relative to the IO MUX base
addresses provided in Table 3.3-6 Peripheral Address Mapping in Chapter 3 System and Memory. The
absolute register addresses are listed in Section 6.12.2 IO MUX Register Summary.
From the table 3.3-6, we have the IO MUX base address to be 0x3FF49000.
So, I was expecting that if, for example, I wanted the address for IO_MUX_GPIO0_REG, I should calculate 0x3FF49000 + 0x10 + 4 * 0, which is 0x3FF49010.
But instead, the IO_MUX_GPIO0_REG is mapped to 0x3FF49044 according to Table 6.12-2.
What I'm getting wrong about the formula on Register 6.34? There's any way to write one that generalizes it without having to write my own Lookup Table?
